Old Feb 20, 2013, 02:36 PM
United Kingdom, Taunton
Joined Dec 2012
Has anybody built one of these? (Hobbyko Pitts for AR6400 & 1S)
It looks perfect to put my T28 guts into. My T28 is still flyable but not that much fun. I was wondering what this Pitts flies like. I have tried searching but have found very little about it.
GoAround is offline Find More Posts by GoAround
Old Feb 20, 2013, 05:10 PM
Quad/3D/DLG/FPV-I fly anything
SuperBarlow's Avatar
United States, VT
Joined Aug 2012
It's a little bit more pricey, but I think you would get more enjoyment out of this: http://www.profileplanes.com/index.p...&product_id=50
SuperBarlow is offline Find More Posts by SuperBarlow
Old Feb 20, 2013, 05:18 PM
Joined Dec 2012
It looks very good but costs more and I would have to import it. The Pitts has the advantage of being dirt cheap, available in the UK and needing the same number of aileron servos that I have ... one. Thanks for the suggestion, though, I have had difficulty finding much in the way of aerobatic models needing a Parkzone UM donor.
Old Feb 20, 2013, 05:21 PM
Master of Micro Modding
valiantGLX's Avatar
Joined Sep 2011
How to Build a Remote Switch for Lights on/off
If you have arrived at this page via my BLOG, please click HERE to access the entire entry
valiantGLX is offline Find More Posts by valiantGLX
Old Feb 21, 2013, 11:28 AM
numanair's Avatar
United States, WA, Kirkland
Joined Sep 2010
Originally Posted by SuperBarlow View Post
Nice glue holder lol
numanair is offline Find More Posts by numanair
Old Feb 25, 2013, 12:04 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
has anyone found a good small 3 pin plug and socket for small brushless to esc connections?
davereap is offline Find More Posts by davereap
Old Feb 25, 2013, 05:37 AM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Yes Hobby King has an in-line plug that fits their small ESCs. Big advantage with an in-line plug it it is easy to reverse the motor.
Here is the 3A ESX:
http://www.hobbyking.com/hobbyking/s...ntroller_.html
Another thing you could do is to get an Integrated Circuit socket DIP (Dual Inline Package) and saw out a section with three contacts on it. Most DIP sockets will have solder pins that go through the board, of the same size as the IC it accepts, so they can be used to plug into them selves in a "stacked" manner.
dbacon is offline Find More Posts by dbacon
Old Feb 25, 2013, 06:25 AM
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Deans makes a 3 pin mini connector with equal pin spacing for easy reversal. I am sure you can find it elsewhere but Astro Flight sold them under part #520. They also make a similar connector with one offset pin that cannot be reversed. Be sure you are ordering the proper style.
Dr John
pmpjohn is offline Find More Posts by pmpjohn
Old Feb 25, 2013, 06:41 AM
valiantGLX's Avatar
Joined Sep 2011
JST-PH 3 pin, also used for UMX 2s battery connectors, very handy items especially if you build your own batteries
Old Feb 25, 2013, 06:52 AM
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
BSD micro has one too that's reversible.
Petefoss is offline Find More Posts by Petefoss
Old Feb 25, 2013, 12:55 PM
United States, AZ, Tucson
Joined Apr 2012
Dollartree foam w/ 26" hot wire cut styrofoam wing, AR6400L, 6A ESC, HobbyKing 2403 w/8040 prop, 2S 350mA, AUW 100 grams
Yak 55 (3 min 47 sec)
boa2110 is offline Find More Posts by boa2110
Old Feb 25, 2013, 02:14 PM
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
What're you using for ailerons?
BryanEW710 is offline Find More Posts by BryanEW710
Old Feb 25, 2013, 02:19 PM
Joined Apr 2012
I Just cut them out of the wing. The styrofoam was strong enough that I didn't need a spar.
Old Feb 25, 2013, 05:00 PM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
That is exciting! Looks so simple to build, I sure hope you publish details. I will make nice drawings out of your sketches if you like...
-Dave
Old Feb 26, 2013, 03:10 AM
davereap's Avatar
Joined Feb 2005
lovely flier... looks like a yak54... and a nice find on that motor...
re.... 3pin connectors... Ive been using these pic1 but they are not a good fit...
the micro deans look good but so far they are expensive over here... £2.45 for one pair
In the end I am going with standard servo connections.. they are a bit over weight at 1.5gms with about 30mm wire at each end, but at least they are reversible so its easy to change the motor direction and they are a tight fit..best of all I can get 50 pairs made as extension leads for £6.20
note the deans weigh 1gm with no wire...
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 126 Mar 26, 2013 06:30 AM
Cool Show off your Parkzone Micro P-51!!! P-51C Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
Gallery Show off your planes texan Wimberley Valley Flyers 4 Apr 13, 2006 02:10 AM
