Old Jan 31, 2013, 02:49 AM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Originally Posted by dbacon View Post
Yes since the lights are probably 30 mA, the battery should last a couple hours or more, BUT, you must catch it before it drags the battery down below 3.3 Volts!
Yes I must remember that.. although I have a load of those little cells salvaged from some 'so called dead' micro helis I bought for parts....10 helis for 15 on ebay.. all the parts worked, they were just rubbish flying helis..lol..
I havnt done an Amp measurement yet, but the model wont get that long a flying time in any one weeks evening sesssion, so a recharge each time will keep it ok..
nice P38's ... a while back...
davereap is online now Find More Posts by davereap
Old Jan 31, 2013, 02:55 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Picked up another mosquito in a trade and have a spare set of mosquito electronics to sell. Looking to get $50 shipped for every electronic out of the plane. They all work perfectly. receiver, both motors, ailerons etc. shoot me a pm if you are interested!
3d astronaut is offline Find More Posts by 3d astronaut
Old Jan 31, 2013, 07:40 AM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by valiantGLX View Post
Switch off the as3x and keep the flaps and mixing.
How do you do this????
Gene K
speedy01 is offline Find More Posts by speedy01
Old Jan 31, 2013, 07:56 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Gene K
1. You need the programming card first.
2. Then you switch your computers region to Germany, our numerical system uses commas instead of full stops, which temporarily corrupts the model config setups.
3. Do what you'd normally do to program it, until...
4. You select the model config setup, you'll know its worked if you get the following error:
5. Continue the rest of the programming process as normal.
6. When you put the brick back in the plane there will be no AS3X.
7. To restore AS3X just change your computer region back to where it was previously set, and reprogram the brick as normal.
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jan 31, 2013, 09:07 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
So now I have a difficult choice to make:
Run dual ailerons with flaps, and have elevator/flap mixing. However only one aileron will have the gyro on it.
or
Connect the ailerons with a Y harness both running with the gyro. However loose the flaps and mixing.
or
What would you guys do
I went for the second solution, but Im not happy about loosing my flaps though
But, forget Y harnesses, check this out!
Old Jan 31, 2013, 05:45 PM
arauser is offline
Find More Posts by arauser
Ozark,AR
Joined Nov 2005
It's been a while since I've had anything to post, but I trashed my little Cessna looking plane and had to build something to put the electronics in. I'm a big fan of the cat type jets as you may notice, so I took the plans from the the 24 inch plans ( the middle one) and shrunk them down to 60%. I ended up with a cat with 14.5" wingspan and 1.05 ounces minus the battery. It flys good, still experimenting with props and balance though. I haven't decided on a color scheme yet.
arauser is offline Find More Posts by arauser
Old Jan 31, 2013, 05:57 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Wow that looks really cool
Old Jan 31, 2013, 07:16 PM
arauser is offline
Ozark,AR
Joined Nov 2005
Thanks Valiant,
I'm waiting for the weather to get better, we've had some storms come through in the last few days and now it's cold and really windy.
Jeff
Old Jan 31, 2013, 09:11 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
18 inch span GeeBee Y .. all that's left is gear and covering ..
Vyceroy is offline Find More Posts by Vyceroy
Old Jan 31, 2013, 09:26 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Beautiful, as usual.
Is it from a kit, and if so, whose?
Gene K
Old Jan 31, 2013, 09:32 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Pres Bruning Free Flight plans .. just do a google search for press bruning geebee y plans ..
Old Jan 31, 2013, 09:33 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
or send me a private message with your email and i will send them to you along with the parts pdf i made ..
Old Jan 31, 2013, 10:50 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Thanks.
What gear will you be installing?
Gene K
Old Jan 31, 2013, 10:52 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
P-51 gear ar6400 rudder elvator control .. tissue covering.. had this one in a box on my building table and covered it with plans and forgot about it .. built it 2 weeks ago ..
Old Feb 01, 2013, 06:55 AM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Thanks. Looking forward to more progress pictures!
Gene K
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 05:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 07:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 12:05 PM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 08:11 PM
