Old Jan 29, 2013, 07:58 PM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Hey guys what are the differences between these items?
Motor (PKZUM1016)
Gearbox (PKZUM1027)
Found in the SU26XP
Motor (PKZ3616)
Gearbox (PKZ3527)
Found in recent warbird releases
I need to pick up some new gearboxes namely the PKZ3527, but I found that these ones were half the price but looked more or less the same PKZUM1027
valiantGLX is offline Find More Posts by valiantGLX
Old Jan 29, 2013, 08:00 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
oops, double post
Latest blog entry: Please ignore....... for now
Old Jan 29, 2013, 11:25 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
As far as what I have heard around here, the p51 gearbox/motor setup is the fastest/most powerful. Whether or not this information is correct, is beyond me. I just know I use the p51 motor gearbox combo for all my scratch builds/replacement parts and they work perfectly.
3d astronaut is offline Find More Posts by 3d astronaut
Old Jan 30, 2013, 01:06 AM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
The difference is probably lead length and how far the posts on the gearbox or something like that, I would assume the actual power components are identical.
airpower is offline Find More Posts by airpower
Old Jan 30, 2013, 05:50 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Thanks guys.
__________________________________________________ __________________________________
New BLH3904 BL UM gearbox conversion thread
Old Jan 30, 2013, 05:55 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Motor (PKZUM1016)
Gearbox (PKZUM1027)
Found in the SU26XP
Motor (PKZ3616)
Gearbox (PKZ3527)
The difference between the motors is the wire length. The PKZUM1016 has short leads, the PKZ3616 has mid length wires. The EFL9052 has the longest wires (and is usually the cheapest).
The above motor mounts are the same. The difference is the PKZUM1027 has a clear "champ style" nut, while the PKZ3527 has a white, hard plastic nut on the back of the shaft.
UNGN is offline Find More Posts by UNGN
Old Jan 30, 2013, 06:06 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Do you know of any differences in the gearing, or do both gearboxes run the same spurs?
Old Jan 30, 2013, 12:07 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
All the gearing of Every Parkzone, Eflight, Hobbyzone or Kyosho 8.4mm motor's plane is exactly the same (they all use the same size pinion and spur gear)
8.4mm helicopters or 6mm motor gearboxes can have different gear ratios, but the 8.4mm planes are all the same.
Old Jan 30, 2013, 12:45 PM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
After a midair chopped the covering on my micro kite, it got recovered...now its also got lights... AUW now 40.5gms.. but I have used an 85Mah to run the lights.. they are running well below their optimum amps so the tiny lipo should last for ages
davereap is offline Find More Posts by davereap
Old Jan 30, 2013, 02:16 PM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Yes since the lights are probably 30 mA, the battery should last a couple hours or more, BUT, you must catch it before it drags the battery down below 3.3 Volts!
dbacon is offline Find More Posts by dbacon
Old Jan 30, 2013, 02:18 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I have to say that I'm almost at breaking point my my stupid as3x brick.
1. It took me hours to install the programming software on win7, stupid drivers wouldnt attach to it.
2. After programing it I have lost the AS3X function, not one of the 3 gyros work anymore. I cant even revert back to the factory settings. I have tried every model config setup but still no as3x.
3. I just found out you cant run dual ailerons, in such a way that they work as flaps too. Well you can get them to work but the gyros only on 1 aileron.
4. there is no ch1 output for BL ESCs, you have to use a different ch and mix it to the throttle. This sucks up a ch and a mix setting.
Im disappointed with HH on this one, for such a prestigious company they sure didnt think the as3x programming through
Edit: I got my AS3X to function again. Because Im in germany on a german computer the region was set to germany, duh! In the german numerical system they use ',' instead of '.', this somehow corrupted the model config files, so I had to change the region to Australia where full stops are full stops and commas are commas. After reprogramming it under the australian region the AS3X now works again
EDITED AGAIN: I just got the dual ailerons to work too both have as3x and both act as flaps I activated dual ailerons on my DX6i and on the brick
Old Jan 30, 2013, 04:28 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
From rags to riches all in one post.
good work!
jrjr is offline Find More Posts by jrjr
Old Jan 30, 2013, 08:49 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
good work!
Back to rags The dual aileron setup doesnt work after all
At first I just plugged some servos in and tested if they moved when flicking the switches/sticks, which they did, however I didnt pay attention to the direction they were moving.
After setting everything up properly the ailerons were actually moving in the same direction, but so were the flaps
So now I have a difficult choice to make:
Run dual ailerons with flaps, and have elevator/flap mixing. However only one aileron will have the gyro on it.
or
Connect the ailerons with a Y harness both running with the gyro. However loose the flaps and mixing.
or
Switch off the as3x and keep the flaps and mixing.
What would you guys do
Old Jan 30, 2013, 09:12 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
thanks
Old Jan 30, 2013, 10:30 PM
Alfredo Rubio is offline
Find More Posts by Alfredo Rubio
Moderador.
Alfredo Rubio's Avatar
guadalajara, jalisco, mexico
Joined Sep 2002
Originally Posted by Vyceroy View Post
Here's one in the works .. Pres Bruning SBC-4 Hell Diver free flight.. 18 inch wingspan .. rudder elevator .. i am still trying to decide on tissue covering or solarfilm..
If you let me to say... your plane will needs dihedral nice model.
Alfredo Rubio is offline Find More Posts by Alfredo Rubio
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
