Old Jan 29, 2013, 07:12 AM
addictedtoplanes is offline
Find More Posts by addictedtoplanes
and helis!
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
sweet! hows it fly?
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Jan 29, 2013, 08:06 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Originally Posted by Watts cooking View Post
I know I'm new the conversation but with the board facing this direction the control rods will have to drag over the servo gears causing the binding of the servo. I know because I ran into the the same problem when turning a guillows javelin rubberband plane into rc. I don't know if you have seen this issue causing a problem or your design allows for the clearance. Hope it helps and good luck on the build its looking good.
Thanks for your concern I counter sunk the brick so the control rods come out on an angle to meet the control horns narrowly avoiding the servo spurs
This is my first attempt dabbling with a scratch built/designed profile plane, if it turns out crap so be it, I can rebuild the thing easy enough.
But I have faith in the design and electronics layout, only time will tell if my faith was rightly placed
In other news, while Im waiting on some parts to arrive, namely BL goodies, I am just about to put another one of my designs into production
The P-38 lightening has been one of my favorite aircraft of all time (followed closely by the ME-262, then the P-51 D) so I knocked up this design last night using MS Paint again (that programs seriously underrated)
Like the Mustang I used actual schematics to get the out lines so its very true to scale despite being a profile design.
The only exception is that I made the vertical stabiliser a bit taller, and the tail booms a bit wider for added strength. Oh! and also the motor/tail booms on the schematics were slightly toed-out (when looking at them from above), so I straightened them out.
...And of course the control surfaces are larger than scale, but not as extreme as my Mustang
Electronics:
UM mosquito brick motors and props
3x 1.7g servos
260mah lipo
navigation lights
Controls:
Dual rudders
Ailerons
Elevator
Throttle
...And a uni-flap
Wingspan:
520mm
Length:
Haven't measured it yet
Weight:
Fully equipped I'm hoping for around 60g (15g lighter than the Mosquito)
Airfoil:
KFm2
PDF's and build thread coming soon
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jan 29, 2013, 08:20 AM
SuperBarlow is offline
Find More Posts by SuperBarlow
No place like cloud base......
SuperBarlow's Avatar
United States, VT
Joined Aug 2012
Instead of MS paint, try Paint.NET. http://www.getpaint.net/download.html
For me, having alpha, different layers, and a magic wand key helps alot
SB
SuperBarlow is offline Find More Posts by SuperBarlow
Old Jan 29, 2013, 08:21 AM
United States, VT
Joined Aug 2012
Also, I have a book of 3 views of airplanes, and I think that the P-38 is in there. I could post a scan of the page?
Old Jan 29, 2013, 10:04 AM
miatamama is online now
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
valiant, most computers have paint program. Can you give a class on how to make a drawing like the p-38 in paint. One that Us non computer operators can understand?
JCS
miatamama is online now Find More Posts by miatamama
Old Jan 29, 2013, 10:09 AM
mtflyr is online now
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Love the P-38 I've done a few Micro P-38's including a micro profile one it flys great using 2 PZ P-51
motors/gear.http://www.rcgroups.com/forums/showt...il+p+38&page=3
I've since made a clear canopy and scale spinners (act Speedy01 made the scale spinners for me) for the Profile P-38, I think it helps it look better.
Pete
mtflyr is online now Find More Posts by mtflyr
Old Jan 29, 2013, 10:14 AM
BryanEW710 is online now
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Very cool!
BryanEW710 is online now Find More Posts by BryanEW710
Old Jan 29, 2013, 10:49 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
SB
I actually have that program, but I found it tricky to use, especially selecting colors. I'll have to put more time into it though, I see there's measurement tools, which will prove very handy indeed
Thanks for the offer, but Google seems to be working out well for schematics.
JCS
Its seriously dead simple, it just takes patience and a steady hand.
First I find schematics in google then paste them into paint.
Then I lassoo everything I can, and clean up the rest with the eraser.
Nows the fun part, line out where you want the control surfaces, airfoil, etc.
Finally cut up the image and paste the sections into MS publisher, fit the sections on an A4 page, save as a PDF and you're done
Pete
AWESOME!!!
I want to offset the brick to one side and run the rudder control linkage down one side to the vert. stab. Then connect both vert. stabs. together. Putting the battery on the other side should even out the weight.
Old Jan 29, 2013, 11:17 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Pete
Seriously though, how much
3d astronaut is offline Find More Posts by 3d astronaut
Old Jan 29, 2013, 11:42 AM
Centreville,VA,USA
Joined Apr 2001
Hey Valiant,
I've also made a full fuselage Micro P-38 for my friend Speedy01. It has ailerons, rudders, and elevator. I used the PZ Mossy e-gear. I did put the brick in one boom and the battery in the other. It works fine.
Pete
Old Jan 29, 2013, 02:19 PM
BryanEW710's Avatar
Joined Sep 2010
I'm wondering the same thing. A micro P-38 would be kinda neat to have.
Old Jan 29, 2013, 03:00 PM
Centreville,VA,USA
Joined Apr 2001
You can see the builds here in this Micro Indoor Forum. It is one of the harder Micro paper to Depron build esp because of the twin rudders but it can be done and it's a nice flyer. My last full bodied one White 33 came in at 1.9 oz. again it uses the Mossy e-gear and props. Here's some pic's of it next to others I've done one BL with folding props way too fast for me it can eat up a field pretty quick.
I do really like the profile and the Mossy e-geared P-38.
Pete
Old Jan 29, 2013, 03:13 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Here's one in the works .. Pres Bruning SBC-4 Hell Diver free flight.. 18 inch wingspan .. rudder elevator .. i am still trying to decide on tissue covering or solarfilm..
Vyceroy is offline Find More Posts by Vyceroy
Old Jan 29, 2013, 03:23 PM
yosemitealoha is offline
Find More Posts by yosemitealoha
sambino
Waterloo Ontario Canada
Joined Mar 2010
Micro Aeronca C3
Here's one I posted recently on another thread but there's more traffic here so it's the place to be. Obviously an Aeronca C-3 based on the old Tern Aero kit but I enlarged it by 150%. The gear is all Hobbyzone Champ and the performance is surprisingly lively for a 27" 42 gram model. Covering is Esaki tissue with two coats of 75/25 nitrate dope. The color change between the two shots is just from different lighting. The second shot one is closer to the actual colour.
Sam
yosemitealoha is offline Find More Posts by yosemitealoha
Old Jan 29, 2013, 06:36 PM
Brent Slensker is offline
Find More Posts by Brent Slensker
Weni, wedi, Java...
Brent Slensker's Avatar
Casper, Wyoming
Joined Nov 2009
yosemitealoha Great Aeronca C-3 build ! More pics!
Brent Slensker is offline Find More Posts by Brent Slensker
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
