Old Jan 28, 2013, 07:15 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Originally Posted by speedy01 View Post
valiant,
Those great little servos now come in white!!
Gene K
I know, I have the old school versions that come in Spektrum orange lol
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jan 28, 2013, 07:30 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Here's some thrust test with various props:
E-flite and GWS prop thrust tests with the 1s UM motor and gearbox.wmv (1 min 30 sec)
Old Jan 28, 2013, 08:18 AM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Gene K & Speedy01
If those servos you speak of are the HK 5320, they are in stock right now!
dbacon is offline Find More Posts by dbacon
Old Jan 28, 2013, 08:57 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Originally Posted by valiantGLX View Post
Where do you guys think I should mount the brick. Note that I have a programming card so it doesnt matter whether I mount it horizontally or vertically.........
Too late, I counter sunk the brick into the tail section:
Old Jan 28, 2013, 09:19 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Looks like the best place to me!
You will be able to counterbalance this with battery and motor right?
I hope the wiring weight is small as you must go all the way to the front for the battery and motor.
Old Jan 28, 2013, 09:22 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
You are going to need to remount the brick.
#1 it will be tragically tail heavy
#2 it's backwards and the AS3X won't work properly (even with the programming card)
UNGN is offline Find More Posts by UNGN
Old Jan 28, 2013, 09:28 AM
BryanEW710 is online now
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Just now thought about it, but those are some massive control surfaces for a Mustang!
BryanEW710 is online now Find More Posts by BryanEW710
Old Jan 28, 2013, 10:22 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Me too
Battery and motor even it out nicely, with the KFm2 CG sits between 35 and 40% of the chord.... And when I get the ESC I'll have even more weight to move around to balance the CG
Wiring shouldnt be too much of an issue, once I have my ESC only 1 wire will need to go to the brick for the motor. The servos use 32awg wire which doesnt weigh much.
#1 - see above
#2 - crap I think you're right
Elevator- works properly
rudder - is backwards, reversing the channel doesnt help
Ailerons - havent tried, need to solder the connectors on
Thanks for catching that before I got too far in the build
EDIT: Double checked software, and there's a sensor output direction, so I CAN make it work where it is, phewfff
Hehe! Im definately not going for scale performance
__________________________________________________ __________________________________________________ ___________________________________________
With the software its a pitty you cant add your own sensitivity settings, theres only a handful of settings you can choose from, Im just going to have to go for 3D/aerobatic and hope for the best :
Old Jan 28, 2013, 11:20 AM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Put your wing on and balance before mounting everything. Looks like you will need a very heavy batt to balance. Hope im wrong.
JCS
miatamama is offline Find More Posts by miatamama
Old Jan 28, 2013, 11:53 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
JCS
Do you guys think this bricks made of lead?
Its only around 1g heavier than the ar6400's.
At the moment its kind of nose heavy I need the battery towards the rear center of the wing to even it out at 35-40% CG. Things will change once I have the linkages on, but not that much, even if it does I can put the battery under the nose in the worst case scenario
Besides with AS3X the CG doesnt need to be spot on.
Old Jan 28, 2013, 04:47 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
With the gears facing rearward I still think your going to have major issues, sensor output direction or not. Your brick is doing the opposite it thinks it is.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Jan 28, 2013, 06:09 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
TODD
Thanks for the warning, but I'll see how it goes. If I crash it or it doesn't work I'll make a new one, no biggie really, after all its just a piece of foam
Where it sits at the moment makes the most sense to me, the control linkages can be shorter and the servo wires dont need to be tangled around them. Plus the CG works where it is, and the red light on the RX is even facing the right way for navigation
Old Jan 28, 2013, 07:44 PM
Watts cooking is offline
Find More Posts by Watts cooking
Watts cooking's Avatar
United States, CA, Corona
Joined Oct 2012
I know I'm new the conversation but with the board facing this direction the control rods will have to drag over the servo gears causing the binding of the servo. I know because I ran into the the same problem when turning a guillows javelin rubberband plane into rc. I don't know if you have seen this issue causing a problem or your design allows for the clearance. Hope it helps and good luck on the build its looking good.
Watts cooking is offline Find More Posts by Watts cooking
Old Jan 28, 2013, 10:33 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Gene K & Speedy01
Thanks - I already have four on hand, and have ordered several 1.9g 5330s - also in white!
Gene K
speedy01 is offline Find More Posts by speedy01
Old Jan 29, 2013, 12:09 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
I'm sure you guys have seen them but I am pretty excited about this thing. Its a micro skykart that I did some re-enforcing on. I had a similar one a while back but the foam warped so bad from its own weight that I had to trash it. So I have taken some thin flat strips of cf and used foam tac to cement them into place.
3d astronaut is offline Find More Posts by 3d astronaut
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
