Old Jan 15, 2013, 02:07 PM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
I wish HK would stop using the term "JST" when those are clearly Molex PicoBlades.
And the Corona 919MG servos I found on HK say they're 12.5g, not 1.25g. The size of that thing and the huge torque (compared to the others) should alert someone to an anomaly.
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Jan 15, 2013, 04:51 PM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
glen2626,
Thanks for catching that, I completely missed it, duhhh....
I used to be smart, once... can't remember when I lost it.
dbacon is offline Find More Posts by dbacon
Old Jan 16, 2013, 01:27 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
I know its out there I just cant find it.. A collection of ar6400 replacement airframe kits. Most are just planes with pre cut foam/balsa but for the life of me, I cannot find them.
3d astronaut is offline Find More Posts by 3d astronaut
Old Jan 16, 2013, 02:35 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
here are a collection ..from the UK
http://www.micronradiocontrol.co.uk/model_browser.html
micro, JST,1mm 1,25mm 1.5mm pins, molex, nano... the connectors are a mess up... its a nightmare...
a lot of the products not only have different connectors they are also wired up differently, so every thing has to be checked and checked again...servos , connection leads, ...what a pain!!!.....
note... on servos you also have to check the opperating voltages...some are really only for 1 cell 4v use, some are for 4.8-6V, so the 1 cell servos are not so suited for the voltage that comes back from a 2 cell esc....despite that, people still use them with no problems at the higher voltage... however I supose that you could use a diode to reduce the voltage back to the rec...
They have not even standardised the way they name the bits, even though there are correct names for the diferent types
and HK is only one of many that doesn't help with their descriptions... HK also doesnt sell a full range of plugs and sockets to make it possible to change your own about...
I bought from HK a selection of different rec's like the orange, supermicro, and some micro servos.. and got all of the main 3 types of plugs and sockets, and both voltages for the servos (deliberately)... and I am still trying to organise them so they work together...
davereap is offline Find More Posts by davereap
Old Jan 16, 2013, 04:01 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Or from Robot birds again in the UK
http://robotbirds.com/catalog/index....ath=29_208_308
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Jan 16, 2013, 05:09 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Daverap,
Thank you for the "heads-up" on the servo voltages, it makes sense to look at that too.
I am quite amazed by the similarity among different RC manufacturers, there doesn't seem to be any standards committee out there for this, but they do have a lot in common anyway. I can think of many other commercial activities that share even less interchangeability, such as Cars, TVs, Power tools, Furniture, Sports equipment, and others. So I think we are pretty lucky for what we have.
Thanks again for the warning.
Old Jan 16, 2013, 06:13 AM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
I have three foam kits listed in my blog that are designed around the 2 cell UMX systems. The Yak-54, Jumping Bean and MiG-29 are all laser cut depron and ply and include all required carbon fiber bits.
Dr John
pmpjohn is offline Find More Posts by pmpjohn
Old Jan 16, 2013, 07:01 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Be extra sure to check polarity if you get any leads for batteries..I bought some from ebay to go on 1 cell lipos...the red and black wiring was all in reverse...
lightweight covering materials...
youve seen my xmas foil ar 6400 size models..this foil is 40 microns and 22gsm , ok but lighter is better..its similar to a celophane material in that it will tear very easily when cut or slit , but is strong against a simple pull
So now Ive tried some cheapo plastic bag material..12 microns for the standard bags or 18microns for bottle bags... 50 bags or 100 ,
http://www.ebay.co.uk/itm/2510547276...84.m1423.l2649 from ebay
The results are interesting...
The material is some kind of polythene.. its softer than the Xmas foil, it can be stretched, and it doesnt tear when cut..which is a bonus
I covered a small section using uhu por glue, then I tried hot air heat shrinking... its looking good.. next I must try the digital non stick modeling iron
Old Jan 16, 2013, 04:18 PM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Originally Posted by davereap View Post
I need to work on a method to make the rec blocks easily swappable.. my few are all in models that are flying... until these get killed, which may take a while, I am stuck with building experiments only..
A couple of options to look at.
Zeke at Parkscalemodels.com has a neat system where the 1S motor and gearbox and the brick are mounted on a removable tray. Stub pushrods are mounted on the brick that connect to pushrod extensions in the plane with magnets.
Mark at http://retrorc.us.com/ has designed a system where the brick clips in with plywood parts.
Petefoss is online now Find More Posts by Petefoss
Old Jan 17, 2013, 03:18 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
have you a link to the actual page...I cant find it...thanks ..dave
Ive been working on micro kites...trying the combination of CF rods and film to get a light weight structure.
I am still getting to grips with selecting the rod sizes, usually I make these for blue wonder motors..and larger
Both kites made are stronger than needed for the micro system, they would easily take 10gm motors , however they are both light enough to fly with a 2 cell brushless ar 6400 micro setup...or the geared setup from the micro SU
The first kite I covered with the Xmas foil... the second I am going with the carrier bag material...the bag material is a lot lighter and doesn't tear as easily
Using the digital iron 110 degrees gets a good shrink, the first test part didn't distort at all...now I am wondering how light I can build , shrink cover and not get distortion..
Old Jan 17, 2013, 10:46 AM
Richard Cox is online now
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
There is an error in post 3400 regarding the 820 ohm resistor. It should be gray-red-brown,
8-2 and one zero.
Richard Cox is online now Find More Posts by Richard Cox
Old Jan 17, 2013, 12:51 PM
Joined Sep 2011
Thanks guys!
Old Jan 17, 2013, 01:08 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Richard Cox,
Oh My! You are so right, I made that mistake in two places!! I edited them both, THANKS!
Old Jan 19, 2013, 04:42 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
I put my gear ito the IFO?BUG and the final AUW was 35gms which with the 5gm brushless gave me just enough thrust to hover... good.. however the motor started to fail to initialize, down to a wire becoming detached.. rewiring it still didn't work.. testing with a meter and I had no power to the esc... so rewired again.. and got power but in testing I shorted out the b***** thing and now the esc signal on the block is dead and the brushless esc on the block is dead...
Its just too easy to short something with these tiny blocks...and up it goes in a puff of smoke..
However the block and servos work so Ive now got to figure a mix that will let me control the brushless esc through the spare servo channel... .. if possible...
On the micro topic for anyone in the uk, these are from ebay and are usefull for parts..
http://www.ebay.co.uk/itm/3207696836...84.m1439.l2649
The big twin motor gearbox uses the same motor size as on many of our micro models , the motors can be moved so one or both work a single shaft, giving more or less power as you like
..the tail rotor motors are the same size as used in the tiny linear servos..and on the twin AA planes...
the lipos are 85mA ...
plus there are multi colored LEDs, USB 1 cell charger leads and various other connectors and switches..
I dare say the TX boxes will have some bits in as well .. at the very least they have a charge connection lead plug..edit thats all that was worth salvaging from the tx...
Old Jan 19, 2013, 05:11 AM
GoAround is offline
Find More Posts by GoAround
Can't fly 3D for toffee ...
GoAround's Avatar
United Kingdom, Taunton
Joined Dec 2012
I hope this isn't off topic but I have an ageing and abused PZ T-28UM. This means an AR6400 plus aileron servo (long throw in my case, a replacement of the original) and brushed 1S set up. I also have 5 nice 190mAh Miniaviation 1S batteries.
Is there any kit that the entire guts of this Trojan would fit into? I want something more aerobatic than the Trojan, ideally.
I have found that 40 will buy me all the body and rod parts for a micro Su-26. I'm sure this would be good, even though the elevator and rudder would not quite have the throw of the original. However, this is a lot to spend when you consider any of the parts I put in could give up the ghost very soon.
I would prefer a cheaper solution. Those Donuts models would be great but I have almost no modelling experience and no idea how I would get them working so I probably need something more user friendly.
GoAround is offline Find More Posts by GoAround
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
