Old Jan 09, 2013, 04:44 PM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Finally got a video uploaded for the P-80! Sorry it's in the RCG Video Gallery though. But its the best I know how to do. 100mph Looks great! As I get a bit older I need colors to help me see, let alone fly my planes. Great Design btw.
Keith
MUTCAKE is offline Find More Posts by MUTCAKE
Old Jan 11, 2013, 04:45 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Both my Xmas models have flown now... both fly very well but lack power, so I need to find out what are the best setups to use...
They are both flying on 1 cell 160mA with a 4500kv 5gm brushless and 5x3 prop..they both weigh around the 40+ gms
I am only getting enough thrust for a good climb rate, but not for any vertical so I am very dissapointed there...
davereap is offline Find More Posts by davereap
Old Jan 11, 2013, 05:45 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Vertical isn't really possible with 1s brushless direct drive. You can get 60g of thrust with a 5043 prop and a UM gearbox with a Bravo SX motor though. Also you'll need a lipo with at least a 25c rating
Hobbyking alsso have a micro 1s BL setup with a gearbox. If you want to remain BL thats your best bet, although its pricy.
EDIT: I had a closer look at your pics, they look like very nice planes. But more to the point I see that you already have decent batteries, and the way you plugged in the ESC is inefficient. Try connecting the battery directly to the ESC, with only the one signal wire going to the RX
valiantGLX is offline Find More Posts by valiantGLX
Old Jan 11, 2013, 01:13 PM
100mph is offline
Find More Posts by 100mph
Our God's Alive
100mph's Avatar
United States, NE, Bennet
Joined Mar 2011
Here is a video of it flying:
micro 3-channel RC plane (2 min 0 sec)
100mph is offline Find More Posts by 100mph
Old Jan 11, 2013, 03:29 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Nice ! reminds me of my nutball
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Jan 11, 2013, 05:53 PM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
Terry
Thanks, that is sort of what I had in mind when I made it. It actually flies better than a nutball, it flies better inverted and glides and harriers a little better.
Old Jan 12, 2013, 04:12 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
I have started a micro thread to discuss what power setups we use on what models etc
how do they perform etc
http://www.rcgroups.com/forums/showthread.php?t=1806752
I would be pleased if you will also show your models on there , describing your exact power setup in use..
eventually It will give us all the info needed to avoid getting poor results
Its also worth describing what didnt work, so it can be avoided
Also worth adding are products available .. gearboxes motors ..how do they perform ..are their quoted specs accurate...
Any usefull info
Old Jan 12, 2013, 06:27 AM
dbacon is online now
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Davereap,
I went there and saw all the responses, I will add my stuff too.
It would be good for all if you used one of your first posts as an index to those that state their performance results. You could put:
Motor----Battery-----Prop----ESC-----Post Number
I know it would be extra work for you, but it might become one of the best references out there.
You might even arrange a Google Spreadsheet where everybody could make entries and have even more columns, such as RPM, Thrust, Amps, Watts, and other things, and it would be open to all, or you could restrict it to a password you give by PM.
dbacon is online now Find More Posts by dbacon
Old Jan 13, 2013, 09:39 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
yes I will certainly keep post 1 updated and linked to the results...please keep that thread for micro motors ans small stuff only though .... say up to 10gm on the motors....
Here is something of interest to you micro fliers.. not a plane , but Ive been playing with LED lights after watching some night vapors flying..
I have already done a night kites thread and put some info on DIY lighting.. so I started playing with the bits already on hand..
I had various colors in 3mm that came with resistors to run them from a 12v(3 cell is fine) but they are all rated at around 3.6V...so the first trial was a direct connection to 1 cell..
they all go well but use near 100mA as they run..
So I then used the resister for the 12V setup and they still work... nowhere as bright but only about 2
mA when running, and certainly visible enough, because normally they are over bright..
Here is a short video showing the B>G>W and then what happens with the flasher, which sits between the blue and the green...every time the red on the flasher comes on , all the others go off...
mind you I might use it like that
to stop geting bored at the video you only need to watch a few seconds at the start, then move to near the end..
LED lights for micro rc plane models (1 min 3 sec)
Next I tried different colours...running and wired individually... blue was good...white a bit brighter ..green good...yellow dim.. red dim.. flashing red/blue ok..although the red componant was dimmer
The yellow and red wanted about 4mA to run...higher than the others
Next I wired 1 resistor in the circuit and put on all the lights at once...
Results are odd to me but I am sure there are members who will give the explanation..
I found that I could run the white blue and green all together nicely...
Adding either of the Yellow or Red.. the B>G>W would stop working and the other color worked dimly by itself....
Adding the R/B flasher... the B>G>W would all flash, but all 4 worked ok.... testing the 4 were using 3mA only, so will hardly dent your little 1 cells when compared to the motors draw...
Old Jan 13, 2013, 10:00 AM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
davereap
When using LEDs, you must read the voltage they drop across it. You said "3.6V", but it will differ on each color by about 0.5v among them.
The LED must get that voltage or they don't produce light at all, and they TRY to draw unlimited current, so the resistor is used to limit the current.
So a 3.6V LED in series with a resistor, across 12V causes the resistor to drop 8.4 Volts, no matter what the value of the resistor is. Most 3mm LEDs draw about 10mA, so find the appropriate resistor value by dividing the dropped voltage by the desired current, or:
8.4V / .010A = 840 Ohms. Then select the nearest standard value or 820 Ohms, or Grey-Red-Brown meaning "8"-"2"- and 1 zero.
If you can "fit" a couple of LEDs in a string - volts-wise that is, you can be more economical of your current, you just have to figure a new resistor. So two x 3.6V = 7.2V then our dropping resistor would be 12V - 7.2V = 4.8V And the value would be 4.8V / 0.01 = 480 Ohms, which is near 470 Ohms or Yel-Vio-Brown.
Note that with all these resistors there will be a tolerance color band of Gold or Silver, and there may be another band for temperature tolerance, so this may help you know which end to start with when reading the bands. I have worked with them for years, and I practically just see the numbers (sort of).
Now, pursuing that power saving thing above, you could put 3 in series: 3 x 3.6 = 10.8V, and then your resistor needs to drop just 1.2V. You would use a resistor of 1.2V / .01A = 120 Ohms. With this you get three lit up for the power of one! BUT, when the voltage drops, the LEDS will reduce in intensity, to the point of going out entirely at a supply voltage of 10.8 volts.
You can get fancy and make an active series current regulator, and I will help people through that if they so desire, but it is hardly worth it for these applications. Remember that a 10mA load on a 160mAh battery will run 16 hours, so efficiency is not important...
Almost missed this, if you use a one cell battery, you have about 4.2V to 3.3V, so there will be some LEDs you can't run. You can read the Voltage across various LEDs you have with a 12V supply and an 820 Ohm resistor in series. While it is on, read the volts across the LED itself. Some LEDs will operate with only 2.2V across them, and they would be best for one cell applications.
Whatever LED you select, do this:
1. Put in in a circuit that allows about 10mA to flow
2. Read the voltage across the LED
3. Figure what your preferred supply voltage is, and subtract the voltage in step 2
4. Figure the resistor needed by taking that voltage found in step 3 divided by 0.01
Put that value or near that in series with the LED.
Here are "standard" 5% tolerance values, this is what you will have available for your experiments:
http://www.swarthmore.edu/NatSci/ech...ardValues.html
You will use ones from the "Brown" column.
Last edited by dbacon; Jan 17, 2013 at 01:06 PM. Reason: Color codes on resistors, 3rd band
Old Jan 13, 2013, 11:55 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
different colors draw different ammounts. elecricity takes the path of least resistance, so when i wired white, red and green, only the red lit.
i ended up running resistors to each one. this also lest you 'tune' the light brightness.
white i run at 12 ma, and green as well, or green at 20ma, and usualy run red at 40ma.
the eyes dont like to see red, most of its invisable.
nemoskull is offline Find More Posts by nemoskull
Old Jan 13, 2013, 12:53 PM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
NemoSkull,
Did you wire White-Red-Green in series and feed it through a series resistor, OR
Did you wire White,Red,& Green in parallel, and feed it through a series resistor (...as I suspect).?
If the latter, then the one with the lowest "firing" voltage would light, and keep the voltage too low for the others. Hence the "path of least resistance", as you stated.
The 40mA sounds a little high, I hope it can tolerate that.
Old Jan 13, 2013, 03:07 PM
nemoskull's Avatar
Joined Sep 2009
most leds specs say 30ma, max, but thats at 1000 hours. if i get only 100 hours of life, (10% ife span) im happy ( thats a LOT of stick time )
i wire red, green, white in parallel and put resistors on the pos wire of each led. (just for visual refference)
wiring in series i never tried, cuz the voltage drop for three different leds. as far as the voltage, its not much of an issue. the LED is far more concerned with amps than volts. at any rate, the life rating goes waaay down, but it still very high.
(example: usb stick drives. when was the last time one died on you? they have a limited life, and some manufactures make a big deal of 'last twice as long as the comtitition', but were still talking years of lief out of usb drives. practicaly speaking, most planes (micro) dont get that long of life.)
i once ran ebay white LEDS with no resistors (50mah total) through an AVR procesor as a flasher unit, 0.4 seconds on, 3.5 off, for a week with no failure. in the end i sold it as i figured 7*24 - 168 hours. 5 minute a flight, = 2000 flights.
this was the worst abuse i have ever thrown at the leds, and it did fine.
perhaps the guy i sold it to can chime in???
besides, the brushed motors are the same. datasheets show 1000 hour life, but at 1V. we run them a 400% and get maybe 10- hours and are okay with that.
Old Jan 13, 2013, 03:36 PM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Very interesting, I never thought of LEDs in these creative ways. Thanks for the input.
Old Jan 14, 2013, 02:11 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Thanks for the LED/resistor maths... I am going to use the colors that are compatible for the single cell use..the white , blue and green.. that will give me enough variety for the micro models orientation without adding too much weight... it will be close up flying so just the few lights will be plenty, and the fact that they are a bit dimmer than their brightest wont matter...
When I use LED's on my night kites on 3 cell power I wire them in parallel harnesses like nemoskull , often they are often over bright...they can be seen for miles...and I use 20-50 lights on the model, so that can draw up to 1/2A...
I measured the current drawn wired as in the video and the 4 LED's were using between 3 and 4 mA total only so that wont loose me much flight time...
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
