Old Jan 05, 2013, 09:53 PM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Now that is cool, need to fly it over Gotham City...
Does it have ailerons?, I see rudders, and elevator, but not any dihedral...
Oh- I see the dihedral in the build thread, nice work by the way. How does it fly? Wild, docile, floater, what?
dbacon is offline Find More Posts by dbacon
Old Jan 05, 2013, 10:11 PM
Ken Spencer is offline
Find More Posts by Ken Spencer
GymDandy Flyer
Ken Spencer's Avatar
Webb City, Missouri
Joined Apr 2004
Aero Bat II
See Build Log at : http://www.rcgroups.com/forums/showthread.php?t=1802794
Keep Them Flying ! Your friend, Ken
Sorry, dbacon " No Ailerons " but Dihedral.
Ken Spencer is offline Find More Posts by Ken Spencer
Old Jan 06, 2013, 09:58 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Ahh yes, the new picture shows it nicely, very cool, I should build a big one to entertain the geese that come to our lake. the other residents hate them, but I find that they come here to play, and they honk loudly to get my attention. So I comply, with my Apparition electric boat or my Capricorn foamy, and they dance and play, and when satisfied, they move on to another place, probably looking for more games and play.
I would have to make it float, so I can be right in with the geese, or they won't feel that I am doing my best for their recreation.
Old Jan 08, 2013, 10:35 AM
MUTCAKE is online now
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
P-80 Shooting Star
Even without a thrust tube this little jet flies very well! It will rise off any smooth surface w/out landing gear. Loop from a slight dive for most of the flight, and is a lot of fun to fly. Speeds are very scale like. It is also very easy to make having only parts!
Specs:
16" wingspan
Vapor Rx
Weight 21grams w/o battery 25.4 with 150mah 27.7gms w/200mah
GWS 30mm edf unit
Parkzone UMX P51 Motor produces 25gms thrust
MUTCAKE is online now Find More Posts by MUTCAKE
Old Jan 08, 2013, 11:05 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Very nice
Do you have plans for this?
Specs:
16" wingspan
Vapor Rx
GWS 30mm edf unit
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jan 08, 2013, 12:02 PM
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Razor, That's the problem I need someone to show me how to make my line drawings into plans cause I'd really like as many people to build one of these as possible. If someone wants to take my drawings to the next level I'd appreciate it.
Old Jan 08, 2013, 12:08 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Nice one Mutcake
Just scan your line drawings into a pdf add dimensions and I expect folks will be able to take it from there.
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Jan 08, 2013, 12:54 PM
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Thanks Terry, will do after work today. Oh yeah nice flying videos of the mini vapor!
Keith
Old Jan 08, 2013, 01:51 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Keith,
Nice Shooting Star! 6 blade rotor I imagine? What thickness foam did you use, and type? I did a 40mm using bluecore once, but it was heavy for it's time and liked to snap roll often Your 30mm has great power to weight ratio! Great job!
I'm working on learning Sketchup again. Wish me luck. Maybe someday I could do a print for you also!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jan 08, 2013, 09:50 PM
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Fred, I used Great Planes Pro-Formance foam 3mm. Not Cellfoam 88 which I like better but is heavier. I usually don't like the pro-formance foam cause it's really soft and will only sand well with finer grit foam sanding blocks. But the weight savings is significant! I was surprised at having a finished airframe, rx and fan minus battery at 21.1 grams. I am pretty proficient at Sketchup but haven't been able to print without distortions (cause I don't know what I'm doing) so much for proficiency. This thing glides forever and I have crashed into the sides of the gym floor quite a bit but since the weight is so low the damage was minimal. I am drawing up plans tonight to scan and attach. If all goes well I will get a video soon.
Oh yeah, it's the 6 blade rotor.
Old Jan 09, 2013, 12:44 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Keith,
Thanks. I never used or even touched Por-Formance foam but I was also amazed at your measuerd weight. I am sure it helps having that AR6400 brick, but still amazing. Thanks for the info on the foam and fans for sure. I bought some of those P-51 motors but have yet to marry them to an actual fan setup. I get off on tangents you see......
I too am amazed how light arcraft suffer little damage when they hit things. I think I am going to try Dave Reap's printing of sketchup to cutepdf file, then play with it using acrobat reader for actual paper printing. I have also been trying out Open Office lately because it can open pdf, and save to pdf, and may have some alternate potential.
Carry on and good to see some more of your designs and magic at work.
Fred
Old Jan 09, 2013, 09:28 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
my preference at the moment is to use sketchup for any line drawings..then drop a pdf with cute pdf...
however with multi page printouts I always have problems lining up the pages of print, trimming and taping, so I put the pdf's through scaleandtile3 which puts a grid on them..the faint grid makes it easy to line up and fix your pages together .....
http://www.rcgroups.com/forums/showt...1560478&page=3 for info
davereap is offline Find More Posts by davereap
Old Jan 09, 2013, 01:18 PM
100mph is offline
Find More Posts by 100mph
Our God's Alive
100mph's Avatar
United States, NE, Bennet
Joined Mar 2011
Here is one I made in 20 minutes, it flies great. It can fly fast, or slow down nicely in a harrier.
Description:
Description:
100mph is offline Find More Posts by 100mph
Old Jan 09, 2013, 01:34 PM
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Nice plane 100mph! I bet that would look fantastic with Color!
Old Jan 09, 2013, 04:43 PM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
Added some color, I also found out you can do a vertical takeoff.
Description:
Description:
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 05:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 07:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 12:05 PM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 08:11 PM
