Old Dec 26, 2012, 09:50 AM
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
I use Minwax Water based polyurethane.
Richard Cox is offline Find More Posts by Richard Cox
Old Dec 27, 2012, 02:18 AM
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Originally Posted by ziper_it View Post
Here's my Christen Eagle still WIP.
What does WIP mean?
Andy2No is offline Find More Posts by Andy2No
Old Dec 27, 2012, 05:19 AM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Work in progress
dbacon is offline Find More Posts by dbacon
Old Dec 27, 2012, 05:50 AM
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I see. Thanks.
Old Dec 27, 2012, 08:48 AM
RandyL's Avatar
Silver Lake, Ks USA
Joined Dec 2000
Sig FF 15
I finshed my SIG rubber band conversion. It is kit FF-15, one that you glue the sticks directly onto printed paper then cut out the parts.
Flew my 2X rubber conversion called a stringless kite for a couple of years with this gear so it was just time for a change.
All up weight with large 300mah batt it 1.4 oz. Only 2 quick flight due to wind, but it appears it will be just fine.
Randy
RandyL is offline Find More Posts by RandyL
Old Dec 27, 2012, 08:57 AM
RandyL's Avatar
Silver Lake, Ks USA
Joined Dec 2000
Double size Stringless Kite
This is my 2X, scratch built Stingless Kite rubber band conversion that I just took the gear out of. Nice flyer but had to have something new...
Randy
Old Dec 27, 2012, 09:10 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
what covering material did you use on your kite
davereap is online now Find More Posts by davereap
Old Dec 27, 2012, 10:07 AM
RandyL's Avatar
Silver Lake, Ks USA
Joined Dec 2000
It is a very thin cellophane product from a craft store...Hobby Lobby. It comes in many colors. Cut with a sharp knife and glue edges down..once torn at all, it rips easily. I think they decorate gift baskets with it normally.
http://shop.hobbylobby.com/products/...e-film-799726/
Old Dec 27, 2012, 11:51 AM
IWC
Joined Feb 2003
do you have a video of the 2X flying you could post?
IWC is offline Find More Posts by IWC
Old Dec 29, 2012, 10:21 AM
RandyL's Avatar
Silver Lake, Ks USA
Joined Dec 2000
I looked on my youtube stuff, and my current computer drive. I don't see any video of it. Will look on some saved drives and post it, if there is any...just don't remember.
Randy
Old Dec 29, 2012, 12:21 PM
davereap's Avatar
Joined Feb 2005
I ordered some of that cellophane film, and also ordered some holographic present wrap.. the holographic comes in a range of colors being colored on one side and silver on the other.. ( ebay Xmas holographic wrap)
Here is another micro build...A Nutball at 14" diameter.. with no gear it is at 20.5gms, so a target of 35-37gms for a wing loading of 1.235ozsqft
edit 6jan 2013... AUW missed the target and went to 41gms for a wing loading of just under 1.5ozsqft
edit ...the cellophane film (florists wrap from ebay) I ordered has arrived and feels very much like the holographic material... it resists being hand torn, its tough enough, but when cut it will tear along from the cut line easily
edit2 on topic tip... for poorly fitting prop savers and to help fit a gws prop use some 4mmx2mm CF tube.. on the 1.5mm motor shaft slide a bit of the 1.5mm bore heatshrink.. a perfect fit .....which then goes into the 2mm hole in the tube and the whole lot is then centralized on the motor shaft and it doesn't matter that the prop saver isn't fitting the prop as the band holds it all together nicely
Old Dec 29, 2012, 01:12 PM
wagner112's Avatar
United States, NJ, Clementon
Joined Oct 2011
Hey guys have umx extra 3d guts up if anyone is interested thanks
http://www.rcgroups.com/forums/showthread.php?t=1797583
wagner112 is offline Find More Posts by wagner112
Old Jan 04, 2013, 10:01 PM
United States, IN, Elberfeld
Joined Feb 2011
slowly figuring out the paper covering thing. For the first tome I cane say succes, I think 20" wingspan, AUW 106 gramms, p-51 guts+diode+ 1811 2900kc 2s motor
kzart is offline Find More Posts by kzart
Old Jan 05, 2013, 02:31 AM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Nice plane, good work. I see you had help, that's even better!
Thanks for sharing.
Old Jan 05, 2013, 08:47 PM
GymDandy Flyer
Ken Spencer's Avatar
Webb City, Missouri
Joined Apr 2004
Aero Bat II
See Build Log at : http://www.rcgroups.com/forums/showthread.php?t=1802794
Keep Them Flying ! Your friend, Ken
Ken Spencer is offline Find More Posts by Ken Spencer
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 126 Mar 26, 2013 06:30 AM
Cool Show off your Parkzone Micro P-51!!! P-51C Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
Gallery Show off your planes texan Wimberley Valley Flyers 4 Apr 13, 2006 02:10 AM
