Old Dec 23, 2012, 02:48 PM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Thats what we are like...old farts brought up on feet and inches before we went metric.. now using foam in mm thicknesses... we don't get confused but we confuse others...lol
The units showed as inches so that the area when I selected it, read out in square inches... I can envision my models in ozsqft.. but the metric equivalent baffles me
The span on my Xmas delta is 19"... I forgot to add that to my sketchup drawing..the final weight without the battery is 37gms.... 1.321429oz... 0.892ozsqft the glide at this weight is great.. slow and steady... so not much power will be needed to get it flying..
It should go well on the stock setup from the micro SU model.. that is about 35gms but only has 52"sq area..
COG the markups on the plan were made using the online flying wing calculator.. at the moment I am behind both by about 0.5" and the glide is superb.. adding a battery will move my COG forward..
A smaller version would go at less weight..obviously.. and be a lot faster...
construction is from 3mm depron two layers with the foil between...uhu por used for the lamination..
there is a spline under which includes the tailfin of 2 layers x 2mm.. The elevons are 3mm depron as are the tip fins
I made a small depron block from odd scrap to take the thin ply motor mount.. the motor is screwed to the ply then cool melt glued to the front.. The leading edge is shaped and taped for strength..There is also a 3mm CF flat spar in the top layer
This flys a real treat
davereap is offline Find More Posts by davereap
Old Dec 23, 2012, 03:56 PM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Well, my guess was close, within 1.6"
Thanks for the rest of the info, looks like a good flier.
dbacon is offline Find More Posts by dbacon
Old Dec 24, 2012, 12:48 AM
ziper_it is offline
Find More Posts by ziper_it
Joined Jan 2007
Here's my Christen Eagle still WIP.
Description:
Description:
Description:
ziper_it is offline Find More Posts by ziper_it
Old Dec 24, 2012, 05:44 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
You do good WIP. Graphics are stunning, how did you attach the strips?
Old Dec 24, 2012, 06:49 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Here is my Oshkosh Special 20. It is setup with a Vapor brick with a "Steve" converter for a brushless esc. Plans are here http://www.rcgroups.com/forums/showp...&postcount=437
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Dec 24, 2012, 08:22 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Ken,
Nice plane, nice plans, thanks for the Christmas gift!
I might try it in 3mm Depron, as I have some of it at the moment. I also have some of those wheels from HK.
How did you get such a nice finish, is it paint?
What was your airframe and/or final weight?
Thanks for the info and have a Merry Christmas.
-Dave
Old Dec 24, 2012, 09:24 AM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Dave,
This one is made from 2mm Depron. Empty airframe weight (gear in another model ATM) is 16.4g.
Most of the finish is the natural foam. The red is acrylic paint brushed on. Black lines and windows are Sharpie marker.
Ken
Old Dec 24, 2012, 10:21 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Ken,
That sounds pretty light, maybe it is a good idea to just get some 2mm Depron, because I will have balance issues with 3mm Depron, as more weight will be in the rear.
I downloaded the great plans, so it will go in the "to-do" box for now. Thanks
-Dave
Old Dec 24, 2012, 01:06 PM
ziper_it is offline
Joined Jan 2007
I used very thinned vinavil, almost 70% water, then sprayed with transparent acrylic.
Old Dec 24, 2012, 02:14 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Interesting, what is Vinavil? I asked myself, and found:
http://www.vinavil.com/EN/
But I still don't understand, can you 'splain?
Thanks -Dave
Old Dec 24, 2012, 07:09 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
I have started a build thread for the Jumping Bean UMX here...
http://www.rcgroups.com/forums/showt...3#post23612687
Dr John
pmpjohn is offline Find More Posts by pmpjohn
Old Dec 24, 2012, 07:19 PM
ziper_it is offline
Joined Jan 2007
It's a brand for a glue, but commonly used here to refer to the white glue used primarily for wood but also other porous materials. I did a research and the English term should be PVA glue.
See http://artemarcia.com/mosaico/grout-...store=italiano and
Old Dec 25, 2012, 08:43 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Or Elmers here in the states.
Petefoss is offline Find More Posts by Petefoss
Old Dec 25, 2012, 03:17 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Thanks guys, now I must ask, what's it for? Is it a primer, filler, bonding agent?
Because I found floral spray colors to work well on Depron and EPP.
Krylon for plastic does too.
Merry Christmas
-Dave
Old Dec 25, 2012, 05:11 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Weldbond works great!
jrjr is offline Find More Posts by jrjr
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
