Old Dec 18, 2012, 08:19 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Instead of the normal Z bends have you tried this... it enables you to rotate the link through the hole in the tiny servo arms, by rotating the whole pushrod...but seems to hold in just fine, as the whole rod has to rotate back for it to release, which doesnt happen as with a close fitting rod/hole there is always a lot of resistance to the arm as it goes round the bends in the wire, once its on the straight bit of rod, it stays there... a normal Z at the other end will fully lock it , but so far has proved not to be needed..
It does make it easier to fit the connection in restricted areas
davereap is offline Find More Posts by davereap
Old Dec 18, 2012, 11:18 AM
Martin Irvine is online now
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
It is also easier to bend with any pair of pliers.
Martin
Martin Irvine is online now Find More Posts by Martin Irvine
Old Dec 19, 2012, 09:55 AM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
I do that on all of my planes now!
Free
Free is offline Find More Posts by Free
Old Dec 19, 2012, 10:09 AM
acheyj is online now
Find More Posts by acheyj
Joined Mar 2012
The ERC Micro Stik and I think the Mini Boomerang use this method makes link replacement a breeze. Use it for all my HB micros now, BTW can not get heat shrink tube less than 2mm here in Aus dammn !
ron
acheyj is online now Find More Posts by acheyj
Old Dec 19, 2012, 11:37 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
When I cant get the right heatshrink I have used insulation stripped off a suitable wire. Not as good but if secured with a bit of Por smeared on the link you can get it apart if you need to. Por fill gaps better than CA
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Dec 19, 2012, 07:59 PM
Peter Mack is offline
Find More Posts by Peter Mack
Mack
Peter Mack's Avatar
Australia, VIC, Mentone
Joined Jun 2004
I am presenting my ancient Cri Cri as a Christmas offering to humour RC Groupers over the festive season. The original stems from the famous modelling eccentric, Ray Malmstrom, who created many outrageous, rubber-powered models back in the 1950s. Ray's model was all balsa, but mine, first made about 5 years ago, is mostly 2mm Depron and originally was designed for a Bitcharger Rx, actuator rudder only and powered by two 6mm motors of doubtful origin. A powered glide was the best it could do, so up to the attic she went.
A great believer in recycling, when I rediscovered Cri Cri I wondered whether it would be possible to rebirth her with an ar6400 and two 7mm motors up front, attached by stiff wires so that incidence angles can be altered. My indoor meeting friends were polite, very sceptical, but kindly provided advice, such as wiring the motors in parallel rather than in series as I stupidly had done! The last indoor meeting for the year had passed so I ventured out on what I thought would be a calm morning at the nearby football field. The outcome is described in doggerel:
Miracles at Christmastime
Miracles happen at Christmas time,
One has just happened - and so this rhyme.
This morn I ventured unto the field,
With Cri Cri in hand, aloft to wield.
And though wind blew (I would'st best gone home),
Up to the heavens Cri Cri was blown.
She wobbled and swung, but I do declare,
With careful tweaking, she rode on air!
Well, for quite some time, though on descent,
She flew into a tree - her tail was bentů
But to all those disbelieving sods,
Who doubt the miracle-making gods,
My head and chest are somewhat grown,
My cute-iful Cri Cri at last has flown!
A merry, model-making Christmas to all RC Groupers.
Peter
Peter Mack is offline Find More Posts by Peter Mack
Old Dec 19, 2012, 08:22 PM
dbacon is online now
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
What a great way to tell a story, thanks for sharing!
dbacon is online now Find More Posts by dbacon
Old Dec 20, 2012, 05:39 AM
UK, Bedworth
Joined Apr 2004
Peter
Nice model glad you got it going - Oh the joys of new technology
Terry
Old Dec 21, 2012, 06:49 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
new model made... overweight at 45gms AUW.. and I need a better balanced power setup in it
too heavy...binned...
Old Dec 22, 2012, 11:14 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Take a look at post 52 for more details on my MITKID skeleton cub.
http://www.rcgroups.com/forums/showt...4#post23593738
Petefoss is offline Find More Posts by Petefoss
Old Dec 22, 2012, 11:30 AM
C-ME-FLY is offline
Find More Posts by C-ME-FLY
C-ME-FLY's Avatar
Wilmington NC
Joined Aug 2010
Here are mine. First was my Fokker d7 built from scraps. Second is yellow amd.black lazy bee then the red and white lazybee then the stagger bee
C-ME-FLY is offline Find More Posts by C-ME-FLY
Old Dec 23, 2012, 09:55 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
I cant stop building.. I wanted a slow wing so I have made this Xmas wing which is at 23gms without the gear
Edit this ended up at 41gms AUW and flies a real treat with a 5gm brushless 4500kv and a 5x3prop.. 3A esc...160 lipo
Old Dec 23, 2012, 11:28 AM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
That is light for a 21.6" wingspan.
BTW, thanks for using inches, isn't metric the popular format in England?
Old Dec 23, 2012, 11:50 AM
UK, Bedworth
Joined Apr 2004
I use both sometimes in the same measurement like 3 feet 2cm.
Terry
Old Dec 23, 2012, 12:01 PM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
OMG you are truly bi-lingual, Engineering-wise anyway.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 05:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 07:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 12:05 PM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 08:11 PM
