Old Dec 17, 2012, 12:35 PM
alset is offline
Find More Posts by alset
Gunbarrel, CO
Joined Dec 2006
Addition to above post: Superglue not a good idea for me on the pushrod connections because I like to reuse the Parkzone end-pieces after unrecoverable crashes (which always happen at some point in time)
alset is offline Find More Posts by alset
Old Dec 17, 2012, 01:29 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Not a problem just squash the heatshrink with pliers and the superglue will crack and you can pull the bits apart
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Dec 17, 2012, 01:54 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Cyanoglue (Superglue) disolve nicely in acetone!
coriolan is offline Find More Posts by coriolan
Old Dec 17, 2012, 02:00 PM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Here is 2mm shrink tube from Hobby King US warehouse, 25 cents for one meter.
That's about 1/32 inch...
http://www.hobbyking.com/hobbyking/store/__5205__turnigy_2mm_heat_shrink_tube_black_1mtr_.h tml
I WAS WRONG, see post 3323...
dbacon is offline Find More Posts by dbacon
Old Dec 17, 2012, 02:30 PM
seitz2c is offline
Find More Posts by seitz2c
P. Seitz
United States, IA, Mechanicsville
Joined Jan 2006
3/64 will shrink down tight around .010 carbon fiber ! how much smaller can you go?
seitz2c is offline Find More Posts by seitz2c
Old Dec 17, 2012, 02:36 PM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
nice micro stingray... I love wings... thats another on the build list...
davereap is offline Find More Posts by davereap
Old Dec 17, 2012, 02:39 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Seitz2c,
I think they didn't want to shrink it. But it should be easy to protect the foam with a piece of metal under the push rod.
Old Dec 17, 2012, 02:44 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
2mm is .080.
that is closer to 3/32" than 1/32"
.8mm is .030. That is what HH uses. Dealextreme.com
UNGN is offline Find More Posts by UNGN
Old Dec 17, 2012, 04:06 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
You can get 3/64th all over the Internet, which is even smaller than the Dealextreme.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Dec 17, 2012, 04:33 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
TODD
3/64 = .046"
.8mm is .030"
3/64's is available @ radioshack, but it will slip if you use .015" wire on .030" rods and don't use glue.
.8mm won't slip.
Old Dec 17, 2012, 04:57 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
Originally Posted by UNGN View Post
3/64 = .046"
.8mm is .030"
.8mm won't slip.
Dealextreme .8mm on the left, Internet 3/64th on the right.
Old Dec 17, 2012, 09:58 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That doesn't look like the .8mm I received from DX.
I don't have any 3/64", because I have no use for it, but here is .8mm compared to Heat shrink from a HH Pushrod kit:
Old Dec 17, 2012, 10:30 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
dont forget the shrink rate. usual 3:1 but i have seen some at 2:1.
nemoskull is offline Find More Posts by nemoskull
Old Dec 18, 2012, 01:48 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
UNGN,
You're right,
3/32=0.09375
1/32=0.03125
2mm=0.080
Sorry, bad math...
Old Dec 18, 2012, 04:59 AM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
[QUOTE=UNGN;23556153]That doesn't look like the .8mm I received from DX.
I know it's my DX shrink because it's about 12' long now and has (0.8) printed on it.
TODD
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
