Old Dec 13, 2012, 12:45 PM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
Dumas 17.5 inch Tiger Moth conversion
Here is my very short build thread pictures
The Dumas 17 inch Walnut kits make great conversion projects. This is the 3rd model I have done in that series. They have all flown as good as they look. This one flies on a Hyperion 1 cell 180mah. Really looks great in the air at 1/2 throttle.
ducatirdr is offline Find More Posts by ducatirdr
Old Dec 13, 2012, 04:05 PM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
very nice, what do you seal your tissue with?
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Dec 14, 2012, 07:32 AM
ducatirdr's Avatar
Joined Aug 2006
I used old fashion 50/50 Dope/thinner with a brush. Simple and easy to do although fumes are really strong and require serious ventilation.
Old Dec 14, 2012, 07:35 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Originally Posted by rcjim11 View Post
Are there any pics of how people set up the push rods on these micro planes?
Cheers
Jim
I like using the ends from Parkzone micros with my own carbon rod.
http://www.hobby-lobby.com/champ_rtf...28729_prd1.htm
Or you can bend your own. I really like the prebent ones because the Z bends are really tight. Shrink tubing and CA to attach the wire ends to the carbon rod.
Petefoss is offline Find More Posts by Petefoss
Old Dec 14, 2012, 09:32 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
I presume you use a heat gun (soldering irons work well, too) to shrink the tubing, right?
BryanEW710 is offline Find More Posts by BryanEW710
Old Dec 14, 2012, 10:14 AM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Cheers pete!
Do have an idea of the diameter shrink tube?
Jim
rcjim11 is offline Find More Posts by rcjim11
Old Dec 14, 2012, 10:19 AM
BryanEW710's Avatar
Joined Sep 2010
Cheers pete!
Jim
I would try to match it up to the size of the carbon rod you're using, right?
Old Dec 14, 2012, 11:04 AM
alset is online now
Find More Posts by alset
Gunbarrel, CO
Joined Dec 2006
The shrink tube that comes with the Parkzone pushrod/end-pieces is smaller than the smallest shrink tube an electronics parts store carries. So where can one get this very small shrink tube?
alset is online now Find More Posts by alset
Old Dec 14, 2012, 12:26 PM
glenn2626 is online now
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
3/64ths shrink tube works fine for me - lots of places to find it and I just happen to sell it in small quantities, should get to you really quickly as we're both in Colorado.
Glenn
RC-Connectors.com
glenn2626 is online now Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Dec 14, 2012, 12:44 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
www.buyheatshrink.com
Only drawback is $25.00 minimum order.
Dr John
pmpjohn is offline Find More Posts by pmpjohn
Old Dec 14, 2012, 01:02 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
HH Heat shrink is .8mm which is about 1/32" (smaller than 3/64")
The Cheapest source for this is Dealextreme.com... just a couple bucks.
UNGN is offline Find More Posts by UNGN
Old Dec 14, 2012, 01:25 PM
JohnC is offline
Find More Posts by JohnC
Senior Moments...I forgot
JohnC's Avatar
New Hyde Park, NY
Joined Mar 2001
In a pich I use the smallest blue shrunk tubing from DuBro. I wish I could get the HH stuff alone. I hate to buy a pushrod set to get shrunj tubing.
John
JohnC is offline Find More Posts by JohnC
Old Dec 14, 2012, 01:38 PM
glenn2626's Avatar
Thanks Chris, I didn't realize it was that small. I will order some and stock it from now on. Perhaps have a cheaper shipping option (than my standard $2.50) if all you order is shrink wrap.
Glenn
Old Dec 14, 2012, 02:34 PM
ziper_it is offline
Find More Posts by ziper_it
Joined Jan 2007
One question, do you CA before putting the shrink tube?
ziper_it is offline Find More Posts by ziper_it
Old Dec 14, 2012, 03:01 PM
BryanEW710's Avatar
Joined Sep 2010
I do it after. Basically, the CA becomes the last "line of defense" to keep the rods together, with the shrink tube being the first. Just put a drop or two of CA on either end of your shrink tube once you've shrunk it.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
