http://www.hobbyking.com/hobbyking/s...vo_Tester.html If you use a 12V power supply, make sure it can deliver a few amps. You don't really need that many volts though, unless you're trying to make a big cutter. For something small, just three of four rechargeable AAs would do - or the minimum number the ESC will work with. |
Joined Aug 2004
Here's the second - 1/32 sheet balsa clone of Carl Goldberg Cessna 180 circa 1957. 20" span 1.25 ounces. Same setup as the Shoestring. Another excellent flyer! These models were downloaded for free from Paul Bradleys excellent website linked below. Russ Farris
http://www.parmodels.com/index.htm |
United States, GA, Jasper
Joined May 2012
... speaking of which ... CHRISTMAS IS COMING!!!
and many of us are on a pretty tight budget. Where can the best deals be found on um P51 Motors and gear boxes, AR6400 receivers and transmitters that work with the ar6400? Thanks |
| Thread Tools | |
| Pictures: When planes were able to show off, at air shows | Patrick Plawner | Life, The Universe, and Politics | 126 | Mar 26, 2013 06:30 AM |
| Cool Show off your Parkzone Micro P-51!!! | P-51C | Indoor and Micro Models | 938 | Nov 20, 2012 06:49 PM |
| Discussion Show us those planes you really need to replace! | JimTMich | Parkflyers | 8 | Apr 26, 2012 11:05 AM |
| Discussion Show off those home made camera gimbals! | ben1101 | Aerial Photography | 2 | Jul 22, 2009 07:11 PM |
| Gallery Show off your planes | texan | Wimberley Valley Flyers | 4 | Apr 13, 2006 02:10 AM |
