Old Nov 10, 2012, 02:39 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Originally Posted by Petefoss View Post
You just bind both receivers to the same model memory on the TX.
Correct
pmpjohn is offline Find More Posts by pmpjohn
Old Nov 10, 2012, 04:30 PM
Free is online now
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
How do you do that with "ModelMatch"?
Isn't supposed to stop that?
When you bind to another rx, it unbinds from the original rx?
Free
Free is online now Find More Posts by Free
Old Nov 10, 2012, 04:59 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Bind the two receivers at the same time perhaps ?
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Nov 10, 2012, 08:30 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
I bound rx #2 after binding and turning off rx #1. They are both DSMX. I doubt it would work with a DSM2 and DSMX together although I have not tried it. Since it is not uncommon to use redundant receivers in giant scale aircraft, me thinks the designers didn't want to lose that market share. Model Match will prevent a rx from responding to a different memory.
John
Old Nov 10, 2012, 08:34 PM
Modarius is offline
Find More Posts by Modarius
"Watch out for...CRUNCH!!
United States, CA, Sacramento
Joined Jul 2008
Ahh, gotcha. I some how read your post to mean that both rx controlled a motor and a control surface. Your just using the one rx basically as an esc then.
Modarius is offline Find More Posts by Modarius
Old Nov 10, 2012, 09:02 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
There is no reason that each rx could not control a motor and a control surface. If I was going to continue to use separate batteries for each rx I would move the elevator servo over to rx #2 to help equalize the load on each pack. Since I just ordered a Hyperion 2s 500mah 35c pack from RCBABBLE with two output leads that becomes a moot point.
John
Old Nov 10, 2012, 09:34 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
Here we have basic colors applied. Should help with orientation without adding to much weight.
John
Old Nov 10, 2012, 10:49 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
Originally Posted by pmpjohn View Post
I I doubt it would work with a DSM2 and DSMX together although I have not tried it.
John
you might be intrested to know the DSM2/X tx module in the spektrum bricks have 3 modes, DSM2 only, france mode (same power IIRC, but missing some of the 2.4ghz band) and a DSM2/DSMX mode. generally this is what they run, at least the DX5e made in the past few years.
might work. i dunno either.
nemoskull is offline Find More Posts by nemoskull
Old Nov 11, 2012, 12:32 PM
Free is online now
Free's Avatar
Joined Jan 2012
thanks
Old Nov 11, 2012, 07:20 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
A few homemade stickers and a little sharpie time later.... Looking forward to getting some more air time.
John
Old Nov 11, 2012, 08:37 PM
seitz2c is offline
Find More Posts by seitz2c
P. Seitz
United States, IA, Mechanicsville
Joined Jan 2006
F3f-2
Finally got it done! Maiden went fine. I had to add 4 grams to the nose to hit the CG AUW ended up at 49 grams. I'll add a dummy radial after the nose weight is permantly installed.
Paul
seitz2c is offline Find More Posts by seitz2c
Old Nov 11, 2012, 10:50 PM
nemoskull's Avatar
Joined Sep 2009
very pretty! what type of foam you use?
Old Nov 12, 2012, 09:20 AM
UK, Bedworth
Joined Apr 2004
VERY NICE ! a work of art I hope it flies as well as it looks, any chance of a video ?
Terry
Old Nov 12, 2012, 06:15 PM
seitz2c is offline
P. Seitz
Joined Jan 2006
I use fanfold blue foam sanded down to 2mm. with 80 grit sandpaper it takes about 5 min to do enough for a 16 " micro.
sorry no vidio
Paul
Old Nov 12, 2012, 07:09 PM
Not Free is offline
Find More Posts by Not Free
Foamies for life! #f3p
Not Free's Avatar
Joined Sep 2011
John
That is pretty!!!
Not Free is offline Find More Posts by Not Free
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
