Old Oct 22, 2012, 10:55 PM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Here is one that is 0.4 gram
http://www.hobbyking.com/hobbyking/s...ro_Motors.html
Here is a buzzer for less than $3, possibly you could modify it.
http://www.hobbyking.com/hobbyking/s...y_Buzzer_.html
dbacon is offline Find More Posts by dbacon
Old Oct 23, 2012, 01:13 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Originally Posted by dbacon View Post
The motor output will have one polarity, then the other polarity, and it may be a smaller voltage than the supply. So you need two things:
1. A diode in series with your circuit so current flows only in the proper direction.
2. A way to provide the voltage needed for the flasher.
Some of those high power LEDs want almost 4 volts to work, and your single cell may not have enough voltage to do it.
You might add an NPN transistor (like a 2N3904) to switch on the flasher with collector on the flasher negative wire and emitter on the negative battery connection. Then you could put a diode and a series current limiting resistor to the base, and tie it to one (or the other) motor output wire. Put the positive wire of your flasher circuit to the positive battery connection.
WOW! what a wealth of information Thanks, although most of it is over my head, but I learn more and more every time I log into RCG
I ended up wiring the flashing tail to be constantly on, and the other lights are on the remote switch. Its not the best solution but it works However I wish I saw your post before doing it.
Originally Posted by UNGN View Post
I have used these simple, lightweight brushed ESC's to turn on LED's. A good thing about a brushed ESC is you can adjust the voltage to light LED "Just Right" and not need a resistor (using the travel extents in the TX).
Here is an ESC I have used:
Brushed ESC's are getting tougher to find, however.
The ESC sounds like the way to go, thanks
0.4g you cant go wrong I'll definitely be buying a few of these for future projects.
I actually have one of those buzzers laying around, I used to use it on my LOSI SCT until I figured out how to set the failsafe
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Oct 23, 2012, 06:23 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
There are two at HK, one buzzes when you lose signal (yours?), the other when you command it on through a channel (I think this one might be easier to use).
I got a Losi SCT, the Strike, and I have beefed it up as the boys would break things on theirs (bought five all told, the boys play rough) I can share a few things, but on another forum to be polite.
Old Oct 23, 2012, 09:04 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Yeah mine is a signal loss buzzer, so it is probably no good for this application
Here are some of my 1:24 SCT Builds:
http://www.microtforum.com/forum/viewtopic.php?t=20626
http://www.microtforum.com/forum/viewtopic.php?t=20640
http://www.microtforum.com/forum/viewtopic.php?t=18308
I just figured out that I can actually dial down the lights with the servo guts remote switch too
Therefore I think the best and most inexpensive option would be to use the guts of one of these. 10bux for a brushed esc that you are only going to butcher is a bit steep.
http://www.hobbyking.com/hobbyking/s...c_0_075kg.html
look at me!!! To think a few hours ago I didnt even know what a remote switch was lol. I would like to thank you guys for your support and suggestions. None of this would have been possible without you two
Old Oct 23, 2012, 09:55 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
If weight isn't super critical, you might just have the servo push a brass contact on the servo arm to short two wires glued down some where. This "dry contact" will operate anything, any Amps (within reason) any voltage, no monkey business.
Old Oct 23, 2012, 10:12 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I have thought about this before for an FPV setup to switch between a tail mounted and a cockpit cam. I wanted to do this to my CC panorama, but both weight and cash flow is a bit of an issue at the moment
Old Oct 23, 2012, 10:23 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Well just be sure to test the device you want to operate at a reduced voltage, because I am sure the servo motor output will be less than the source voltage.
I love those servos, 1.7 gram, no open gears, rotary output allows more mechanical options, and easier to deal with for mounting, etc.
Old Oct 23, 2012, 10:58 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
It shouldnt be an issue with SMD leds though.
Yeah I love these servos too, they are precise, quick and they have proven to be quite strong for their size. No issues running with SPEKTRUM equipment too; they seem to flawlessly match my dx6i's stick movements
Old Oct 23, 2012, 01:08 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
With a servo board, you could engineer two color LED's and have one with + voltage and one with - voltage
UNGN is offline Find More Posts by UNGN
Old Oct 23, 2012, 01:43 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Now that's cool...
Old Oct 23, 2012, 01:44 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I actually stumbled across this by mistake/coincidence The motor wires snapped off the servo board from over handling it and I lost track of the +/- wires, so I soldered on 2 leds to determine the polarity. When I plugged it in and toggled the switch I was pleasantly surprised, but unfortunately I had no use for this in my current application.
Anyways I have now completed my setup, and Im pretty happy with it. I'll get a vid up soon.
Hopefully I can get a night flight or two in soon too. At least the pesky kite flyers wont be an issue at night
Old Oct 23, 2012, 01:48 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Now that's cool...
Especially if you had dual coloured SMD LEDS, you could have a scale setup but at the flick of a switch have whatever freaky colours you desire.
Here's an example of a dual coloured SMD in action:
My mCX2 S300 SMD LED Tail Light Conversion 1.avi (0 min 32 sec)
Old Oct 23, 2012, 05:22 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Got a link to this esc other than the link to the picture of it ?
Petefoss is offline Find More Posts by Petefoss
Old Oct 23, 2012, 06:20 PM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
For remotely switched lights you could go with Hansen's NERS and PERS products...
http://hansenhobbies.com/products/onboardacc/ers/
They look pretty foolproof and 100% done and ready to use.
Glenn
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Oct 23, 2012, 06:58 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Not any more. I bought them from bidproduct.com. The image is still there, but I can't find the actual esc.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
