Old Oct 04, 2012, 12:52 PM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
A few coats of dope and some Krylon. With the near constant humidity here, I dope all my tissue planes to combat sagging.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Oct 04, 2012, 12:57 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Thanks. Hope you post some videos when you get it water-ready. The floats make an already good looking airplane even more beautiful.
Are the floats scratch built?
Gene K
speedy01 is offline Find More Posts by speedy01
Old Oct 04, 2012, 01:15 PM
Eclipse_7's Avatar
Joined Nov 2003
I sent an e-mail to Mark at seaplanesupply and he custom cut a pair for me. I think it was around $20 shipped for the pair.
Old Oct 06, 2012, 03:56 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
I've completed yet another conversion using one of the AR6400 family. This one uses an AR6400LBL, 2500kv park 180, and 180mAh 2 cell. AUW is 104g or 124g with the floats, wingspan 30" and the plans say 127 sq. in. wing area.
http://youtu.be/TN9bgVTzJsM
That thing looks flawless, Im almost too embarrassed to show off my recently completed Carbon Cub Panorama now
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Oct 06, 2012, 06:42 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Does any on know how to make a GWS direct drive 3 blade prop fit a 1.5mm shaft, or what hardware is necessary to do this???
I made a noob mistake and thought direct drive meant it simply fits directly on the shaft.
I bought 2 sets and took one set to a lock smith this morning with some prop adapters. The lock smith drilled out the blades so that the prop adapters were a nice snug fit, however when I attached them to my plane they were horribly off center and nearly vibrated my plane into pieces
Maybe I will take the other set somewhere else with a drill press and try to get the holes dead on the money, unless there is a better way?
Old Oct 06, 2012, 08:41 AM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I've used a GWS 3 bladed 7x3.5 prop with a Plantraco prop adaptor. That fits the shaft, or one of the three sizes in the set does (you get two of each). I can't remember if the outside diameter fitted one of the black plastic rings that came with the prop, or if i had to ream one to fit.
Maybe reaming the plastic is better than drilling? I guess a powered drill has enough force behind it to drift off and make its own hole, plus there are only two cutting surfaces on a normal drill bit, whereas a reamer normally has at least four, so it keeps the shape of the hole better...
Actually, I've just checked my reamers and the "JP" (model shop one) only has two cutting surfaces, but does have a shape that follows the hole well. My cheap hardware shop one has six cutting surfaces.
Andy2No is offline Find More Posts by Andy2No
Old Oct 06, 2012, 09:38 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
My props are 5030's and I have the plantranco adapters, but they are slightly too large for the holes in the props I guess I will have to take my remaining blades to a machining place with a good drill press to get an accurate hole, as I dont really want to fork out for a set of reamers that I will only use once
Old Oct 06, 2012, 09:46 AM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I was thinking of two blade 5030 props when I said the Plantraco adaptors fit them. I have fitted different sizes of the 3 blade props to them, but I must have used a reamer.
I just own cheap tapered reamers. They weren't expensive, and I've had plenty of use out of them. You'll soon find a reason to own one once you do. "To a man with a new hammer, everything looks like a nail"
A tapered reamer might not seem ideal, but it works well enough The chances of having the exact size of straight reamer are fairly small, I guess.
Old Oct 06, 2012, 12:32 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
If you just spin the adpter on some sandpaper, you an evenly take off enough material so that it pits in the prop hole.
UNGN is offline Find More Posts by UNGN
Old Oct 06, 2012, 02:29 PM
Richard Cox is offline
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
Andy is right. Tapered reamers are a very useful tool, and inexpensive. I have one that goes from about 1/8" to 1/2", and another that goes up to over an inch.
GWS also makes those rubber adapters similar to Plantraco. Problem is that there
are about 6 on the sprue, and they have different size holes. You will end up with a
collection that fit nothing. But then, they are cheap.
Richard Cox is offline Find More Posts by Richard Cox
Old Oct 07, 2012, 02:43 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Thanks, thats actually a very good idea
Old Oct 07, 2012, 08:51 AM
mtflyr is online now
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Just another adapter idea for the GWS props.
Get some cheap plastic tapered hobby paint brushes. Then just press fit( can add CA too) one into the GWS prop cut off the excess and drill in a small shaft starter hole and thread in with the prop shaft works great.
Pete
mtflyr is online now Find More Posts by mtflyr
Old Oct 07, 2012, 11:46 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I would have had to sand too much off the prop adapters to fit it in the blades, so I simply used progressively larger hex drill bits with a screwdriver handle to ream the holes in the blades. This worked out perfectly, however when I was CA'ing them together one of the prop adapters set a little bit wonky and I ended up destroying the prop trying to get it out
...but I just ordered 2 more sets of blades, now I know what to expect I should be able to get the prop adapters to fit like a pro.
Thanks for all the help guys
Old Oct 08, 2012, 06:10 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I just discovered the free flight models on hobbyking and I reckon they would be the perfect candidates for AR6400 conversions
http://www.hobbyking.com/hobbyking/s...ht_Models.html
Weight: check
Wingspan: check
Cheap: check
Cool: check
Here are my favourites.
Wright Brothers
Highwing + floats
The Fokker tri-plane
I know where my money is going in the coming months
Old Oct 08, 2012, 10:37 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
So here is my 98% completed Carbon Cub Panorama, I just need to attach some magnets to the canopy and replace one of the props.
Carbon Cub Panorama (1 min 43 sec)
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
