Old Sep 30, 2012, 07:42 PM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
Originally Posted by boredom.is.me View Post
Oh nothing really. I'ld say that the AR6400 and L aren't as popular anymore. I for one got annoyed with it.
i for one have found the liner servos to be VERY weak and bind up very easily.
cale10 is offline Find More Posts by cale10
Old Sep 30, 2012, 07:45 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I for one got annoyed with it. It is convenient that everything you need is there, but that what makes it inconvenient at the same.
Add that to the fact that separate individual components soon followed such as The DT receivers, HK (and other identical brand) servos, and the ability to have brushless with a loss effort.
I edited my post right after you posted.
That too. I wouldn't say they are weak, but I would say that they are annoying to work with. You can't take the horns off. You can't choose horns. They must be aligned with relation to the surface in order to get proper functionality. You have to constantly clean them if you fly outdoors. They randomly decide that they want to go full travel, stay that way, then burn. They are annoying to mount.
The list has the potential to go on, but I think I hit the biggest points.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Sep 30, 2012, 07:53 PM
Mendo is offline
Find More Posts by Mendo
Mendo's Avatar
United States, CA, Ukiah
Joined Dec 2011
+1 to that!
Mendo is offline Find More Posts by Mendo
Old Oct 02, 2012, 05:04 PM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by UNGN View Post
Received my Target Hobby "AR6400"s today.
I got two today and just did a quick bind - both worked flawlessly.
Have you flown yours yet?
Gene K
speedy01 is online now Find More Posts by speedy01
Old Oct 02, 2012, 06:01 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Gene K
Yes, they fly fine. They seem to be less chattery than many of my other AR6400's.
I just wish they were L bricks. you get spoiled by that little bit of extra throw.
UNGN is offline Find More Posts by UNGN
Old Oct 02, 2012, 06:07 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Well here's my micro 3D plane built from 6mm foam and using 2S BL setup. Its a bit chunky at 65g, 18in. Going to sand down the foam to save a few grams later.
Scratch Built micro 3D backyard flight (2 min 35 sec)
Cheese5 is offline Find More Posts by Cheese5
Old Oct 02, 2012, 06:11 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Looks like quite the handful!
BryanEW710 is offline Find More Posts by BryanEW710
Old Oct 02, 2012, 09:12 PM
Gulf Breeze, FL
Joined Jul 2006
Yes, they (Target AR6400s) fly fine. They seem to be less chattery than many of my other AR6400's.
Mine don't chatter at all! Money well spent.
Would be nice to have the longer throws, but right now I'm mired in WWI models and don't really need the extra control.
Talk about WWI models, have anything on your building board... as something based on Rise of Flight skins?
Gene K
Old Oct 02, 2012, 10:28 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Gene K
Not yet. I have a bunch of AS3X builds right now, but when I get them done or give up, I'll bust out my large format printer and start printing tissue. It's still in the box, but I don't have a clear surface in my workshop to set it on.
Old Oct 03, 2012, 05:40 PM
Not Free is offline
Find More Posts by Not Free
Foamies for life! #f3p
Not Free's Avatar
United States, CA, SF
Joined Sep 2011
That flys nicely for a micro 3D
Not Free is offline Find More Posts by Not Free
Old Oct 04, 2012, 01:47 AM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
I've completed yet another conversion using one of the AR6400 family. This one uses an AR6400LBL, 2500kv park 180, and 180mAh 2 cell. AUW is 104g or 124g with the floats, wingspan 30" and the plans say 127 sq. in. wing area.
Dumas Champ AC7 30" RC Conversion. (1 min 11 sec)
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Oct 04, 2012, 08:59 AM
Gulf Breeze, FL
Joined Jul 2006
Beautiful!
Are the floats for display, or have you flown them?
Gene K
Old Oct 04, 2012, 09:49 AM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
GREAT JOB! Eclipse_7
I have a 30" Dumas Mr Mulligan that is in the queue. That may end up taking my old Beast guts after seeing how well yours flew. How much speed in reserve did you feel you had?
Thanks for posting.
ducatirdr is offline Find More Posts by ducatirdr
Old Oct 04, 2012, 12:41 PM
Eclipse_7's Avatar
Joined Nov 2003
The floats should hopefully be functional, I'm not worried about flying with the extra weight, but take offs may be tricky.
The video is of the maiden, its a bit breezy and it has the worst adverse yaw I have ever seen, so most of the flight was done under 3/4 throttle. Once I got her dialed in, she cruises well at 1/3 to 1/2 throttle. The 2500kv motor with the beast prop is not really a speed set up. If you were looking for speed you may want to look into the 3000kv stryker motor.
At around 85 watts/lbs it defiantly flies on the wing, so if you are looking for blistering performance with some vertical then this is not the power system you are looking for.
Old Oct 04, 2012, 12:43 PM
Gulf Breeze, FL
Joined Jul 2006
What did you do to waterproof the airplane?
Gene K
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
