Old Aug 05, 2012, 06:09 AM
ara25demayo is offline
Find More Posts by ara25demayo
México, MOR, Jiutepec
Joined Oct 2011
i gived up with the pusher so i did a 3mm porter ill put photos later
ara25demayo is offline Find More Posts by ara25demayo
Old Aug 05, 2012, 08:12 AM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Originally Posted by boredom.is.me View Post
Nice.
Get the nose to taper down a bit.
Make narrower ailerons.
Get rid of the couter balance tabs too. They add extra leading edges which creates more drag.
Thank you!
I will take in to consideration what you have suggested!
Free
P.S. Working on a new wing, will post pics soon!
Free is offline Find More Posts by Free
Old Aug 10, 2012, 12:39 AM
Groovechampion is offline
Find More Posts by Groovechampion
Micro enthusiast
Groovechampion's Avatar
Australia, SA, Adelaide
Joined Aug 2011
Gulliows Micro Stuka JU-87
Here's my addition to this thread.
A Gulliows Micro free flight conversion using a AR6400.
Plane is covered in doped tissue, awaiting a maiden.
She weighs in at 52 grams, so a little heavy.
Has R/E/T/A - 4 channel control. Power from a PZ UM Sukoi motor, the ailerons are done with two separate UM servos from the Corsair.
If she flys well, Ill commission her with some decals as per my first post in the build log: http://www.rcgroups.com/forums/showthread.php?t=1680022
Nath.
Groovechampion is offline Find More Posts by Groovechampion
Old Aug 12, 2012, 04:16 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
well?! how does she fly? converting a 905 mustang right now.
nemoskull is offline Find More Posts by nemoskull
Old Aug 20, 2012, 02:42 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
I gotta make something with my AR6400.. sick of my UM Corsair crash machine. Maybe a micro foamy to start.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Aug 20, 2012, 02:53 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Good call.
BryanEW710 is offline Find More Posts by BryanEW710
Old Aug 20, 2012, 02:57 PM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
I made a 14" snowball with similar parts. I put a bowed carbon fibre rod in front to protect the prop, and it is invinceable!
You can see it at: http://www.rcgroups.com/forums/showt...930241&page=89 post 1332.
dbacon is offline Find More Posts by dbacon
Old Aug 25, 2012, 01:54 PM
arauser is offline
Find More Posts by arauser
Ozark,AR
Joined Nov 2005
I've been messing around with micros for a while using the guts from 4 sites, mustangs and an old su-26. I recently bought an airbrush and came up with a couple I thought worth posting. The edge is one I designed myself, it has an 18" span and weighs 1.17 oz without the battery. It does about anything you want other than hover. The other is a rubber powered $5 plane from Estes I converted to electric. It flys great, 15 minute flights on a 150 mah battery. I know mine doesn't compare to most I've seen on this thread but you have to start somewhere.
Jeff
arauser is offline Find More Posts by arauser
Old Aug 25, 2012, 05:25 PM
nemoskull's Avatar
Joined Sep 2009
the estes convversion is on the left, yes? thats pretty cool. and 15 minutes on a 150mah lipo rocks!
Old Aug 25, 2012, 05:56 PM
arauser is offline
Ozark,AR
Joined Nov 2005
Yes thats correct, I made bigger wings and tail section for it out of 2mm depron, the ones in the kit are fairly small. I was going to use a 250mah but the 150 squeezes into the fuse. nicely and flys well at just a 1/3 throttle.
Jeff
Old Aug 25, 2012, 06:07 PM
Free is offline
Free's Avatar
Joined Jan 2012
Nice edge!
Free
P.S. Will post pics of my Yak-55 V3 soon!
Old Aug 25, 2012, 07:48 PM
arauser is offline
Ozark,AR
Joined Nov 2005
Originally Posted by Free View Post
Nice edge!
Free
Thanks Free, looking forward seeing your Yak.
Jeff
Old Aug 25, 2012, 07:55 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Nice paintwork, arauser.
How do you mask it, especially where you're painting two colours side by side like on the Edge? Whenever I've tried to do things like that, the masking tape pulls bits of the paint off. I've never tried an airbrush though, only rattle cans.
Andy2No is offline Find More Posts by Andy2No
Old Aug 25, 2012, 08:54 PM
arauser is offline
Ozark,AR
Joined Nov 2005
Thanks Andy,
I work for a printing company and I use water based inks which is what I use in my air brush. It has a pretty good adhesion to the foam but I still have spots that sometime pick off. I have to dab alittle back on with a Q- tip. I use a low tack mylar for most of stenciling. A friend told me he has good luck sticking the masking tape to his jeans a couple of times before applying it so it will lose some of its tack.
Jeff
Old Aug 26, 2012, 10:18 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
Teaser pics of current project!
Ss
starscream4002 is offline Find More Posts by starscream4002
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
