Old Jul 03, 2012, 11:52 AM
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
If you do enough looking, they can be found for a reasonable price: http://www.hippocketaeronautics.com/...c,12109.0.html
A quick search for "blade breaker" on Ebay turned up a lot of good results: http://www.ebay.com/sch/i.html?_saca...breaker&_sop=1
I've made my own holders that work exceptionally well for me. I must admit that I "borrowed" the idea from an article I found on Small Flying Arts. Pictures and the link to that article are in this post. http://www.rcgroups.com/forums/showp...&postcount=173
PiperCub49 is offline Find More Posts by PiperCub49
Old Jul 03, 2012, 12:07 PM
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by dbacon View Post
Yes and if you could get holders for these blades, they would be great, as they are very sharp. The availability can't be beat!
Using flat pliers, you can snap the double/single edge razor blades into any shape you want, including to fit into an Xacto handle. I snap the blades while holding them inside a transparent plastic baggie.
Gene K
speedy01 is offline Find More Posts by speedy01
Old Jul 03, 2012, 12:26 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Gene K
I've tried both of these techniques, and with my luck, neither one worked for me. My blades don't have a high enough carbon content for a nice snap, so I use tin snips. I also tried to fit one in my Xacto handle, but there wasn't nearly enough support for regular cutting. Again, this was my personal experience. It seems like I'm sort of the odd man out though. To each his own...
Kody
Old Jul 03, 2012, 12:56 PM
Gulf Breeze, FL
Joined Jul 2006
I align the flat of the pliers where I want the snap, then press at a shallow angle on my workbench until the blade snaps. I use bulk blades from Excel, as shown here http://www.widgetsupply.com/page/WS/...ty-razor/BEO65.
Gene K
Old Jul 03, 2012, 01:16 PM
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
I go to the local dollar store - buy disposable razors, 10 or 20 for a buck, and break them open. Great blades very sharp, easy to use. One feature I like is the flexibility. You can lay one end flat on a t-28 micro wing for example and still have the blade curved up to hold. Easy to separate the wing from the fuselage with no damage. I use them all the time.
gklein is offline Find More Posts by gklein
Old Jul 03, 2012, 01:17 PM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Lots of good ideas, there's got to be a method here to suit everybody's needs. Since it is hard to have less than a year's supply with 10 in a package, I just keep ordering them from HK whenever I think of it.
Thanks for the research everybody!
dbacon is offline Find More Posts by dbacon
Old Jul 03, 2012, 01:41 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
I second that, dbacon. Thanks for all the help everyone!
Old Jul 13, 2012, 02:38 AM
México, MOR, Jiutepec
Joined Oct 2011
Hay Im having trouble with my ar6400 the unit cam with a UM P-51 but I'm gonna useit in a miniature model to test a twin boom with V tail dessign but I've foud out that when I enable the v tail mix in my dx6i the controls are reversed like this in the v tail configuration the elevator goes up and down both servos together and in rudder they run opposed well in my board in elevator they go opposed and in rudder they go together why this happens?
ara25demayo is offline Find More Posts by ara25demayo
Old Jul 13, 2012, 07:34 AM
Chrizz
Chrizz's Avatar
Belgique, Bruxelles, Woluwe-St.-Lambert
Joined Nov 2009
Hi!
The easy answer is that one of your servos needs to be reversed, which can be done by programming the AR6400 itself (instead of tweeking your Tx).
Depending on, if either you rudder or elevator might allready move in the wanted direction, try reversing the other channel. It might be as simple as that, but you might also have to reverse i.e. the rudder channel on your Tx to obtain the right direction of movement (not in between the servos, but compared to the airframe itself). Here's a link to the AR6400 manual with the programming (a nice trick is to use elastics to hold the Tx's sticks in place for the programming).
Good luck :-)
Chrizz is offline Find More Posts by Chrizz
Old Jul 13, 2012, 10:55 AM
Joined Oct 2011
Thanks I need something to fly in the Sumer as I trashed the mustang and the pieces aren't in stock
Old Jul 27, 2012, 12:23 AM
Am I a Registered user?
Eratix 3D's Avatar
United States, CO, Grand Junction
Joined Feb 2012
Mine is a stock P-51.
Eratix 3D is offline Find More Posts by Eratix 3D
Old Jul 28, 2012, 10:41 PM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Hi Guys! Here is my new favorites. I built 2 Goldguy nutballs at 18". One with AET and one with elevon rudder. The elevon one was my favorite until I found Aeronots piYak in 14" is my favorite now.
All use HK 415 receivers Turnigy 6g ESC 5320 servos and 180 nanotech 2 cell batts.
If you want a flying experiance build one of these.
I have a 11" piYak on the bench now for one cell so I can meet the 2oz max for our indoor flying this coming season. will use same equip except for the motor which will be the forsite motor and gb with brushed ESC.
JCS
Sorry Guys, I was in the 5 and 10 g motor thread. These could use 6400 receivers. How do I get this post to the 5 and 10 g thread?
miatamama is offline Find More Posts by miatamama
Old Jul 28, 2012, 11:01 PM
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, FL, Daytona Beach
Joined Nov 2007
Your first picture reminded me of this.
http://www.rcgroups.com/forums/showt...fer+foam+plate
boredom.is.me is offline Find More Posts by boredom.is.me
Old Aug 04, 2012, 07:33 PM
"Free" in Christ!
Free's Avatar
United States, CA, SF
Joined Jan 2012
Here is my new plane called the "Firebolt"! (Designed with "Not Free")
It is a pylon racer, V2 will be faster!
V2 will have less wing area/bigger tail surfaces!
AUW=34 grams
Free
Free is offline Find More Posts by Free
Old Aug 04, 2012, 10:41 PM
Joined Nov 2007
Nice.
Get the nose to taper down a bit.
Make narrower ailerons.
Get rid of the couter balance tabs too. They add extra leading edges which creates more drag.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 126 Mar 26, 2013 06:30 AM
Cool Show off your Parkzone Micro P-51!!! P-51C Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
Gallery Show off your planes texan Wimberley Valley Flyers 4 Apr 13, 2006 02:10 AM
