Old Jun 24, 2012, 07:20 AM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
Your prop is WAY too big. I just built a 23" flying wing with similar electronics, and the 5043/5030 prop was way too much torque.
dylantorquerol is offline Find More Posts by dylantorquerol
Old Jun 24, 2012, 07:54 AM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
Originally Posted by UNGN View Post
The 2030's.
The Motor is 2X larger and the rack has ball bearings.
They are cheaper than the 2000's, too.
If using a single servo, a conventional 2.5 - 4g servo might work better, but I haven't tried one.
Hi!
The elder servos AS2000/AS2000L are not suited for use with the new AS3X-bricks.
But does the new 2030's work with other non-AS3X AR6400's? Could one use the new, apparantly also cheaper, servos with and old brick?
Would there be any advantages?
@Free: Beautifully build (even though I must admit the bracings might be a bit of an overkill...? It's still nicely done!).
Sorry to read that it doesn't fly well ;-(
Chrizz ;-)
Chrizz is offline Find More Posts by Chrizz
Old Jun 24, 2012, 08:38 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by Chrizz View Post
Hi!
The new servos are stronger and will last a lot longer (as long as they aren't bad). The only disadvantage is they weigh 2.3g instead of 1.7g for the Long throw versions.
UNGN is offline Find More Posts by UNGN
Old Jun 24, 2012, 08:56 AM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Originally Posted by BryanEW710 View Post
Looks like a lot of unnecessary bracing
In my opinion the bracing was completely necessary, because, first, I sanded the 1mm Depron on both sides to remove weight, (and A LOT of strength)(now ~.7mm), and second I milled A LOT of the foam for the same reasons I sanded it, so the foam is REALLY weak.
These are my reasons.
Free
P.S. Third reason, it is fun!(and good pracitce)
Free is offline Find More Posts by Free
Old Jun 24, 2012, 09:06 AM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Wouldn't you get more strength out of the same amount of foam for the fuse, if it were a box cross section, rather than a "+" cross section?
dbacon is offline Find More Posts by dbacon
Old Jun 24, 2012, 09:07 AM
Free is offline
Free's Avatar
Joined Jan 2012
Originally Posted by iamsuperbleeder View Post
well the rudder servo in my su-26 went on the fritz today... locked up at full right and spun the plane into the ground, demolishing the nose of the plane...
so I copied an idea right from this thread and used the left over parts to make a flying wing after a little mixing everything moves the way it should, but who knows if it'll actually fly, LOL! I'll find out tomorrow!
Looks nice! What's the AUW?
I agree, your plane might have to much torque, a 2x2DD or a 3x2DD might work better (these are guesses on the prop sizes). Might want to look here: http://www.rcgroups.com/forums/showthread.php?t=1616928
Free
Old Jun 24, 2012, 10:07 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
A Box has more Strength, but a + shape 3D's better than a Box with the same weight.
Old Jun 24, 2012, 10:31 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Free
P.P.S. Fourth reason, I makes me look like I know what I am doing, LOL.
With all due respect, I think you'd have been better off to not tinker with sanding and milling and let the foam do the (structural) work. I just look at that big spider brace on each wing and think that a lot of your flying character went out the window when those were glued on.
Take the criticism, of course, for what it cost you to receive it, lol.
BryanEW710 is offline Find More Posts by BryanEW710
Old Jun 24, 2012, 10:40 AM
iamsuperbleeder is offline
Find More Posts by iamsuperbleeder
Licensed Lunatic
iamsuperbleeder's Avatar
United States, FL, Lake City
Joined Mar 2012
yeah the prop is a little large, lol, but it's the only size I have from the su-26. I may try just cutting it down and rebalancing it. I'm not sure of the weight, I don't have a scale...
iamsuperbleeder is offline Find More Posts by iamsuperbleeder
Old Jun 24, 2012, 12:50 PM
Free is offline
Free's Avatar
Joined Jan 2012
I took the criticism, (and it hurt, LOL).
I do not think that the bracing or milling or sanding hinders flight performance, but improves it due to the light AUW. (29 grams)
The milling/sanding lightened the airframe by ~4 grams!
I would appreciate your opinion on why it would hinder performance.
Free
Old Jun 25, 2012, 10:01 AM
BryanEW710's Avatar
Joined Sep 2010
Free
My guess would be either CG changes or aero issues due to the bracing.
Old Jun 25, 2012, 10:36 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Seems to me that to select prop size you should proceed in steps:
1. Start with the rpm the motor will be used at,
2. and the amps it can handle.
3. Then you consider the speed you want, select the right pitch for that,
4. Now you can determine the thrust it has.
Only at this point do you know if it will work for your plane weight and desired performance.
There are lots of charts that help with this. Such as:
http://members.jcom.home.ne.jp/42232...aticthrust.htm
Use 95% in efficiency and RPM goes where it says "U".
Old Jul 02, 2012, 11:42 AM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Has anyone here used an UMX Beast/Sbach motor on a CF tube? The tube I ordered is a little bit too small to fit snugly, and I'm having a devil of a time attaching the two.
Cheesehead is offline Find More Posts by Cheesehead
Old Jul 02, 2012, 11:57 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Drill a small hole about 20mm from the edge of the tube. Make the hole between 3-5mm. Carefully make a cut down the length of the tube till you get to the hole. You should be able to get the motor in it now. If it is too loose use a ziptie to tighten it.
No sense in throwing away perfectly good material.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 02, 2012, 12:21 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I drilled a hole through the CF tube so the mounting screw from the factory mount would go thru and put heat shrink on to make it a little more snug...then epoxied the back side. The motor tube gets sandwiched with the CF tube inside and the Plastic mount on the outside.
You can then cut away the extra plastic from the mount, but I used rthe mount ears to help epoxy it to the foam.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
