Old Apr 27, 2012, 08:19 AM
BladeScraper is offline
Find More Posts by BladeScraper
Custom User Title
Joined Jun 2011
Originally Posted by baconflyer View Post
aaaaaaaaggggghhhhhh!!!!!! i went on the horizon hobby website, and all ar6400 bricks (other than the lbl, nbl, and ar6400t) are DISCONTINUED!!!! WHY NOTCH WHY?!?!? i mean... wait... did i say notch? hmm, maybe my minecrafting has gone a little too far.... but really, WHY?!?!?!?!?
No they aren't they are out of stock.. I looked.
BladeScraper is offline Find More Posts by BladeScraper
Old Apr 27, 2012, 08:28 AM
Custom User Title
Joined Jun 2011
Here is the AR6410L (DSMX version of AR6400L)
I guess the AR6400L is discontinued.
But only because they replaced it with a DSMX version, which does the EXACT same thing, but DSMX compatible! But either one, they do the exact same thing!
So, yeah, I guess they did, but other places still sell the old version as well!
Old Apr 27, 2012, 08:32 AM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
If that is really the case ( have not checked myself):
I was talking with a flyer that appeared to be a Horizon "insider" at the Holiday Electric Fly last December, among other things, he told me that Horizon was moving away from the "bricks" and toward separate components to save on warranty claims. Example: having to replace an entire brick when a single servo went south.
EDIT: DSMX versions are good news. But the raft of AR6400L bricks I have were made of gold for a minute or two there
Tim Wolff is online now Find More Posts by Tim Wolff
Old Apr 27, 2012, 11:34 AM
2.4g shaun is offline
Find More Posts by 2.4g shaun
2.4g shaun's Avatar
United Kingdom, England, West York
Joined Aug 2008
Hi Richard,
Glad they are of use to you.. The model is a bit over designed..
I used 1/32" balsa for the rear top and bottom sheeting, 1/8" light ply for F1. Forget about F1a and F2a. F5 can just be the lower half for the bottom sheeting support.
I also just used med 1/16" balsa for the bottom sheeting instead of ply and no u/c..
I glued the top wing in position as this stiffens up the whole structure.
With your motor, I would suggest putting the esc in the nose, the servo behind F3. Also my AR6300 RX sits there and the LiPo sits between F2 and F3.. It balances fine with the gear distributed like that.
I tissued and doped mine... 2 spray coats of sanding sealer and then stuck the tissue down with spray dope followed by a second coat.
One more in the swarm I'm looking forward to the pics
Cheers,
Shaun
Originally Posted by Richard Cox View Post
Shaun,
Thanks so much for the Gnat plans. I already have it framed up. All Balsa
except 1/16" Ply for the firewall. 5 gram BL motor, AR6300 with single
rotary servo that will turn a torque rod to the rudder, just like we used to do it.
Hard to believe they flew that at 4 oz., but with at TD .010 it probably really
zipped.
I have a Jr. Falcon that I did the same thing, even painted it just like the pic
on the box.
Will post pix when it is done.
2.4g shaun is offline Find More Posts by 2.4g shaun
Old Apr 27, 2012, 02:55 PM
Richard Cox is offline
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
I agree. Minimum formers. I also will glue on the top wing and use rubber bands on the bottom to allow access. Battery will probably go behind the motor, depending on CG,
although I lengthened the nose slightly. Will use CF rod for the torque rod, with the servo mounted sideways to provide the twist.
I will just use couple of coats of clear dope and some tape for decoration, and print out
a decal for the "GNAT".
Do you have the original construction article? Even after almost 50 years, I remember a quote when the pilot told his launcher to just "Chuck it like a dart".
Richard Cox is offline Find More Posts by Richard Cox
Old Apr 27, 2012, 04:40 PM
Custom User Title
Joined Jun 2011
you do know you can replace the servos with out
buying a new brick, right? You just need a REALLY tiny screwdriver and to be REALLY good at soldering.
I mean, why would they sell this:? http://www.horizonhobby.com/products...-throw-SPM6832
Old Apr 27, 2012, 04:42 PM
Not Free is offline
Find More Posts by Not Free
Foamies for life! #f3p
Not Free's Avatar
United States, CA, SF
Joined Sep 2011
REALLY is a really great word
Not Free is offline Find More Posts by Not Free
Old Apr 27, 2012, 07:23 PM
Custom User Title
Joined Jun 2011
Lol
Old Apr 27, 2012, 07:34 PM
2.4g shaun's Avatar
Joined Aug 2008
Sorry, I only have the plan. I would like to see the article if anybody could scan it .
2mm carbon tube works really well for torque rods,with the advantage that you can cyno music wire in the end for the crank.
If you look on our site www.singlechannel.co.uk you can see a number of s/c models converted using a servo like you mentioned...
There are also a number of s/c tx's converted to 2.4g for the real s/c experience.
Shaun
Old Apr 27, 2012, 08:27 PM
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
Well, here it is. 1.70 oz less battery.
Maiden tomorrow.
Old Apr 27, 2012, 08:55 PM
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
Shaun,
Have you flown yours yet?
Old Apr 28, 2012, 05:12 AM
2.4g shaun's Avatar
Joined Aug 2008
Hi Richard,
No test flight yet... the weather has been vile in the UK...
wind & rain.
Good luck with yours.. looks good...
I would set low rates on the rudder.... These tiddlers tend to be very sensitive.
I may make the Ken Willard Pageboy next . It's a bit big at 15" span though
Cheers,
Shaun
Old Apr 28, 2012, 01:32 PM
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
I taped a penny to the rear to get the CG per the plans. On the first launch, it pitched up
badly, so I removed the penny. It flew nose up, but reducing the throttle helped.
It apparently needs more down thrust. I had considerably less than that shown on the
plans. No damage. The 10 gram motor has lots of power. May reduce the prop
size, currently 5 x 4.3.
Thanks again for the plans.
Do you have the pageboy plans?
Old Apr 28, 2012, 05:10 PM
Rod Nyssen is offline
Find More Posts by Rod Nyssen
Joined Apr 2010
Nice little plane, Richard.
I hope it doesn't bite.. ;-)
Pageboy:
http://www.rcgroups.com/forums/showthread.php?t=1546069
http://www.rcgroups.com/forums/showthread.php?t=160288
http://www.outerzone.co.uk/plan_details.asp?ID=358
Rod Nyssen is offline Find More Posts by Rod Nyssen
Old Apr 28, 2012, 06:15 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
If the servo motor is still fuctioning, you can press the motor out of the old rack and press it into the new rack and no solder is required.
To replace the racks, you need a #000 Phillips screw driver.
UNGN is offline Find More Posts by UNGN
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 05:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 07:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 12:05 PM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 08:11 PM
