Old Mar 07, 2012, 08:26 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Originally Posted by 1stplane View Post
seems big bird, what is the weight with all electronics and batt.?
Here is a link to the plane at hobbyking http://www.hobbyking.com/hobbyking/s...idProduct=9468
3d astronaut is offline Find More Posts by 3d astronaut
Old Mar 07, 2012, 10:35 AM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Originally Posted by Vince Herman View Post
I purchased 100 of the nanotech 160's last summer in preparation for this indoor season. I sold about half of them to others, and use the rest for the 5 family members who fly together. This means that we never had to worry about running out. $1.47 each came to $2 each after shipping.
We do a lot of higher current draw flying, hovering and such. I would say that on average, each of the cells we have have about 10 cycles on them. If there is any drop in capacity, I can't notice it (especially when there is always another charged battery to use)
I got 100 of these for $200.00. How many TP does that get you?
You can get about 22.
Free is offline Find More Posts by Free
Old Mar 07, 2012, 10:59 AM
flashkick is offline
Find More Posts by flashkick
Flash, AAAAAAAAAAAHhhhhhhhhh
flashkick's Avatar
United States, UT, West Jordan
Joined Dec 2008
actually that's not the same one as ungn's. he has the kyosho one that is an epp kit.
flashkick is offline Find More Posts by flashkick
Old Mar 07, 2012, 12:46 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Yes. Mine is a Kyosho Christen Eagle II with Pkz Mustang electronics. AUW with a 160 battery is about 35g.
Here is a picture:
I was in Tokyo last week and they still had 3 channel planesets for about $100 USD.
I still have a the un modded one I bought for $65 USD, so I didn't buy another. Its in the build queue, but doesn't have a date.
They also had the minium AD Zero plane set for about $110. I was very temped to purchase one of those and If I wasn't meeting coworkers in Central Tokyo an hour later I may have picked one up (I didn't want to walk around Tokyo all day carrying a big box).
Going back to Tokyo at the end of March. I may pick up another AR6400 conversion plane (looking for a Minium Alpha Beaver)
UNGN is offline Find More Posts by UNGN
Old Mar 07, 2012, 01:52 PM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
@UNGN
Hi!
Do you know if spare parts are actually available in Tokyo? Here in Europe it's fairly easy to get hold of any Kyosho Minium/Minium Ad plane-kit, but impossible to get most spare parts.
I was just wondering... ?
Chrizz is offline Find More Posts by Chrizz
Old Mar 07, 2012, 03:44 PM
poulsbobill is offline
Find More Posts by poulsbobill
a little kid at heart
poulsbobill's Avatar
Poulsbo, Wa
Joined Sep 2004
Originally Posted by Tim Wolff View Post
What kind of flight times were you getting? What brand 160 cell?
I did a bit of poking around and found a Tiger branded T1302 and a clone at Hobby King. Even the branded one is reasonably priced, but I already have a small collection of reasonably priced single cell brushless motors that won't top the stock Parkzone setup.
It was the thunder power 160mah 25c. I checked my timer and i have it set at 3:00 minutes. I usually have some reserve battery left.
Did you see the thrust i got from the test on that thing? Is amazing. I dont think the umx motor/gear box gets that.
Bill
poulsbobill is offline Find More Posts by poulsbobill
Old Mar 07, 2012, 03:50 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Sounds like a big trade-off. With the same lipo , I can get twice as much flight time (again with reserve) from the stock brushed equipment.
BryanEW710 is offline Find More Posts by BryanEW710
Old Mar 07, 2012, 03:59 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by Chrizz View Post
@UNGN
Hi!
It's similar in Japan. They have 3 blade props, prop shafts, motors, decals, things like that, but I haven't found wings/tails and when I have, they are very expensive vs. what we paid for Parkzone minium spare parts.
I am going to pick up some 3 blade props next trip, however, as they were just a couple USD's for the Beaver props and about $3.50 USD each for Zero props with nose cone.
Old Mar 07, 2012, 04:09 PM
Richard Cox is online now
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
Originally Posted by CorvetteC5 View Post
Not true! One must supply higher then the rated 3v to the LEDs or no current will flow and they will not light up. V=IR.
The resisters provided with the LEDs will limit the current but only at the specified voltage (or less voltage as long as still above the turn-on voltage of the LEDs). What voltage is the kit intended to illuminate at?
They are almost certainly designed to operate on the 5 volt output from
the receiver. At lower voltage, like 1 cell, they will be considerably dimmer,
and at higher voltage, in danger of damaging the LEDs.
Richard Cox is online now Find More Posts by Richard Cox
Old Mar 07, 2012, 05:04 PM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Originally Posted by UNGN View Post
Its at 5A. Don't plan on using any batteries smaller than 500mAh.
It will make ZERO thrust using a 160 mAh battery.
The current is around 3.6A, not 5A!!!
The thrust data are here:
http://www.gasparin.cz/?show=frames&...hatsnew&lng=en
Click on PRODUCTS
Click on BL MOTORS G15
CLICK on G15 12W 3.6V Bronco
A 240 mA.h 25C or 300 mA.h battery should be ok.
The thrust is not theorical. Gasparin makes motors which are more expensive but have good efficiency.
Of course, you have to use a good ESC...
indoor_fr is offline Find More Posts by indoor_fr
Old Mar 07, 2012, 06:30 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Click on PRODUCTS
3.6A @ only 3.6V. I'll bet you a dollar its around 4.5A @ 4.2 volts.
Even at 3.6A it won't run for more than 20 seconds on a Nanotech 160 @ WOT before the Battery LVC's.
2S or a geared 1S outrunner makes way more sense.
At $83 USD, that motor makes Zero sense in 2012.
Old Mar 08, 2012, 03:20 PM
Poulsbo, Wa
Joined Sep 2004
Could be the way i fly or try to take care of the battery. I have my timer set at 4:00 for the extra 300.
Bill
Last edited by poulsbobill; Mar 08, 2012 at 03:22 PM. Reason: I also changed the prop on the tiger motor to the beast prop. 5 x 2.75 and got 3 grams more thrust
Old Mar 08, 2012, 03:24 PM
BryanEW710's Avatar
Joined Sep 2010
Admittedly, I NEVER fly WOT unless I absolutely have to, even for aerobatics.
Old Mar 08, 2012, 06:33 PM
Joined Sep 2011
I found a company that will import the Kyosho brand if anyone is interested. Not sure what the shipping costs will be but it shouldnt be THAT much.
Old Mar 09, 2012, 08:52 AM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Here are some in flight pictures of my vintage foam (out of production for about 30 years) free flight MRC Ryan ST-A conversion that I posted about earlier. Action is from the great TINY 2012 indoor event last weekend in San Angelo, TX.
Still need to weigh it, but I am guessing around 65 grams.
Orange prop is now black and a spinner and pilot figure is not far behind...
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
