Old Feb 23, 2012, 04:05 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Okay so I have a really basic question. I have a PZ UM Corsair, that contains the AR6400 "brick", correct? Can it be attached a to a brushless ESC somehow or can I only use it with the brushed motor that came with the Corsair?
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 23, 2012, 04:09 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Yes. Check this thread for more info.
BryanEW710 is offline Find More Posts by BryanEW710
Old Feb 23, 2012, 04:41 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
You can even use the Brick with a 2S Brushless ESC, by powering the brick thru the BEC of the ESC and using a diode to drop the 5.0v's from the BEC down to about 4.2V.
A Brushless Corsair on 2S will have much better performance than one on 1S. Most 1S brushless motors will not perform as well as the original brushed motor.
UNGN is offline Find More Posts by UNGN
Old Feb 23, 2012, 08:33 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
That would take a decent amount of time, effort, and money right? But seems doable.
Free
Free is offline Find More Posts by Free
Old Feb 23, 2012, 08:38 PM
thanks
Old Feb 24, 2012, 07:31 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Free
What, a 2S Corsair?
It'll take a 1 dollar diode, a $14 ESC, a $7 motor, a $1 prop, $.05 of heat shrink, some battery extensions from HK, some scrap plastic for a firewall and some screws you have laying around.
For tools you'll need a soldering iron/solder and some epoxy to install the firewall in the plane.
Old Feb 24, 2012, 11:26 AM
Free is offline
Free's Avatar
Joined Jan 2012
You have a point, what motor/speed control would you use, would you have to swap wires like this?
Free
Old Feb 24, 2012, 12:02 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
The easy way but not the cheapest way is to swap out the Rx board and motor from a beast. I did this on a Polecat and now have a Polebeast.
John
pmpjohn is offline Find More Posts by pmpjohn
Old Feb 24, 2012, 12:07 PM
BryanEW710's Avatar
Joined Sep 2010
John
Good idea!
Old Feb 24, 2012, 08:31 PM
dbacon is online now
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
A 2 cell LiPo could go as high as 8.4 volts fully charged. A diode drops 0.7 volt, leaving 7.7 V to the Rx, isn't that too high?
dbacon is online now Find More Posts by dbacon
Old Feb 24, 2012, 08:41 PM
GIFLYRC is offline
Find More Posts by GIFLYRC
GIFLYRC's Avatar
INDEPENDENTLY POOR in OHIO
Joined Dec 2001
The power for the reciever is taken from the BEC output of the ESC and is typically 5vdc which is dropped to 4.3vdc by the diode---Just right to power the brick!
Roger aka GIFLYRC
GIFLYRC is offline Find More Posts by GIFLYRC
Old Feb 24, 2012, 08:59 PM
Richard Cox is offline
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
The AR6400LBL has a built-in brushless controller.
Also used in the Stryker 27Q.
Richard Cox is offline Find More Posts by Richard Cox
Old Feb 24, 2012, 10:07 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
But its limited to 3a output. Not usually an issue but can be limiting sometimes. The as3x brick is 5a, so better.
Adding a seperate ESC gives a bit more flexibility.
Endlesslag is offline Find More Posts by Endlesslag
Old Feb 24, 2012, 10:42 PM
The paper models are new to me. I just experimented with one of the three free downloads you get from fiddlers green and am badly putting together a cessna 172. Obviously this one is not ideal for putting a brick in, too weak made out of paper. What would be the best way to incorporate the graphics and design of a fiddlers green model into a structure/size that can support the ar6400? Would it be possible to just scale one up ever so slightly and make a rudimentary foam structure to support the paper exterior? Hmmm.
Old Feb 24, 2012, 11:39 PM
Free is offline
Free's Avatar
Joined Jan 2012
I would skip the paper and copy the design on to foam, you could make it profile. If I
am understanding you correctly that is what I would do.
Free
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 05:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 07:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 12:05 PM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 08:11 PM
