Old Feb 20, 2012, 07:56 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Great looking Goose Vyceroy !
pmpjohn is offline Find More Posts by pmpjohn
Old Feb 21, 2012, 03:09 AM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Originally Posted by pmpjohn View Post
Thanks dbacon. Not sure yet. The F15 will slow down reasonably well but hang on when you open her up Neither bird was built to be a floater or I wouldn't be using Stryker power
John
Doesn't this present a problem? An indoor plane built for speed? Or do you have the area and low wind to fly it outdoors?
dbacon is offline Find More Posts by dbacon
Old Feb 21, 2012, 07:06 AM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
I don't have anyplace to fly indoors. Dead calm to 3mph would be ideal but I have flown her in 5-8 and she will punch through it. I do 99% of my flying at a club field. AS3X would be nice but I don't have one yet. I love to fly my um's when the glow guys are sitting around complaining it is to windy to fly
John
Old Feb 21, 2012, 09:18 AM
JohnC is offline
Find More Posts by JohnC
Senior Moments...I forgot
JohnC's Avatar
New Hyde Park, NY
Joined Mar 2001
My non scale Jenny
This is my first attempt to build a balsa ultra micro plane. The plane is made with very light contest 1/32 balsa and some 1/16 balsa. It has plug in wings, removeable cabane section of the fuselage for receiver access,full house RETA controls (AR6400). The wing span is 22 inches on the top wing and all up weight with a 160 MAH battery 37 grams. The covering is ultra thin mylar red and yellow. I have flown the plane in a small gym. It has been a long hard road but with two builds to get it right. It is not to exact scale and mods were made for ease of flying and to get a correct CG.
John F. Clarke
JohnC is offline Find More Posts by JohnC
Old Feb 21, 2012, 10:57 AM
taildragger1589 is offline
Find More Posts by taildragger1589
Lookin' up at the centerline
taildragger1589's Avatar
United States, GA, Lawrenceville
Joined Feb 2005
Nice first try!
Does she fly as pretty as she looks?
Nick
taildragger1589 is offline Find More Posts by taildragger1589
Old Feb 21, 2012, 12:16 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
John
My club field is usually windy as it is right off Anchor Bay in Lake St. Clair. N. of Detroit. Your flyers would not like that, we rarely see 5 MPH, usually 10, but because we are surrounded by 8-15 foot high brush, the air on top of the runway is absolutely dead, so landings are tricky. Maybe I could fly UM's in that dead air, that is worth a try.
I did fly my Capricorn there this last Fall, and it worked real well when it hit the dead air, since it flies at just a few MPH. So I decided to quit worrying about the UMs and start building, and put in an order for Depron Aero at RC Foam. They claim "Aero" is like Depron but 20% lighter. I am thinking I may get the 2mm Depron to work. I gave up searching for Durobatics, as it looks like that dried up when the sole producer passed away a year ago or so.
RC Foam says the Depron Aero is a new name for Gediplac, but I don't think I can run it through the printer like I understand they did with Durobatics.
Does anybody know a replacement for Durobatics? Hopefully at a better price than it was, $7-$10 a sheet, a little larger than a notebook sheet of paper.
Old Feb 21, 2012, 12:53 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
I just got back from the field and did the maiden and one more flight on the Mig29 in 5-10 mph winds. If she flies any different than the F15 it would have to be even better
Can't help with durobatics. All my builds use regular 2,3 and 6mm Depron.
John
Old Feb 21, 2012, 01:08 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
pmpjohn,
Finding out you do this beautiful work in Depron is very encouraging!
So you must paint the Depron, right? How do you keep it light? And what about all those panel lines, do you draw them in with a pen? Looks like a lot of detail work, but worth it!
Old Feb 21, 2012, 01:19 PM
JohnC is offline
JohnC's Avatar
New Hyde Park, NY
Joined Mar 2001
My non scale Jenny
It lifts off with out any help in about 1o-15 feet and flies very well. Just power up and do the turn after it is in the air. Easy to do the pattern in the gym.
I could send a earlier vido when I used a P-51 motor.With that motor it struggled to get into the air. I changed to 4 site Motor and now it almost leaps into the air.
I may delete the ailerons to save save weight as the ailerons are barely effective. Rudder is very effective. I do have some dihederal in the lower wing. I have a carbon fiber rod for a spar and I bent in the dihederal. Works well for small diameter carbon fiber rods. All you need is 15 watt soldering iron and a Jig to hold the carbon fiber rod.
John F. Clarke
AMA 9473
Old Feb 21, 2012, 02:20 PM
Joined Feb 2005
Somehow I figured it would be that way, seems like it's almost impossible to build Jenny where she'd not float around like she does.
John F. Clarke
AMA 9473
Love that AMA #!
Mine was 31006 till I a few years back when things got a little tight and I had to let it go.
I also got into depron for the scratch builts due to the fact that you can knock out one for about $2.
Seems like you have to make the ailerons about 33% chord to make'em work good though...
But I'm starting to get the yen again for *real* modeling...
Nick
Old Feb 21, 2012, 03:14 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
pmpjohn,
Once the parts are glued together and sanded to shape I fill the open pores in the foam with lightweight spackle from the hardware store. There are several brands but you will know you have the right stuff when you pick up the container and think it is empty. Spread this on with a finger and then go back over it with a wet finger to work it into the foam and smooth it out. When dry sand and repeat as many times as required to get the surface you want. there is no substitute for elbow grease. I use the cheap water based acrilic paint from the craft store that comes in small plastic squeeze bottles and costs $1.00-$1.50 each depending on the store.
The panel lines, rivets and ect. are drawn in the computer with a cad or graphics program and printed on full sheets of clear Avery label. These are sprayed with clear Krylon to waterproof the ink and cut out. Peel and stick on like any other sticker. The painted areas that are not covered with a sticker get a coat of WPU, water based polyurethane, to protect the paint and put on a shine.
John
Old Feb 21, 2012, 05:13 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Originally Posted by taildragger1589 View Post
Love that AMA #!
Nick
I had to do the same, but when you "Re-Up" you can put your old number down and you will get it. Mine isn't near as great, but still, I got it: 342006
Old Feb 21, 2012, 05:14 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
pmpjohn,
And all that graphic application doesn't turn it into a "lead sled"?.
Old Feb 21, 2012, 06:19 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
pmpjohn,
78.2 grams w/ 240mah hyperion 2s pack. These were not built to be floaters. A few extra grams helps penetrate the wind better.
John
Old Feb 21, 2012, 07:15 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Yes I guess I was thinking in the 25-40 gram weight like the pure indoor flyers are, but for outdoor, shouldn't be anything wrong with 80 grams, that less than 3 ounces!
My present outdoor foamies are 28 oz or so.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
