Old Feb 08, 2012, 10:44 AM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
Originally Posted by dbacon View Post
Yes, Baconflyer (Really Neat Name...) you can get a small board from HobbyKing that takes two inputs (Aileron + Elevator) and puts out two (Rt and Lt Elevon servos). I will go check the weight. 4 grams
http://www.hobbyking.com/hobbyking/s...idProduct=6321
thanks dbacon
baconflyer is offline Find More Posts by baconflyer
Old Feb 08, 2012, 10:59 AM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by Vyceroy View Post
... any ideas for the Cessna T-50??
Most of us older folks immediately think of Sky King!!!
http://www.youtube.com/watch?feature...v=j5-18MR8aZs#!
Nice pics here:
http://www.rcgroups.com/forums/showthread.php?t=831644
Gene K
speedy01 is offline Find More Posts by speedy01
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
I dont remember what it runs here as the stores dont carry the classic double sided bluecor....
What do you mean by "double sided"?
Gene K
Old Feb 08, 2012, 11:06 AM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
The bluecor at lowes now only has the plastic film on one side as the older bluecor has the plastic film on both sides .. what this does to the foam is make it a bit stiffer as it runs through the machine for the second film application .. they use heat to bond it to the foam ..
I am Partial to the Skyking scheme.. I have a Photo of my grandmother and him taken somewhere ..
Vyceroy is offline Find More Posts by Vyceroy
Old Feb 08, 2012, 11:11 AM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
The bluecor at lowes now only has the plastic film on one side ....
When I used to play with those panels, I spent too much time REMOVING the plastic....
Gene K
Old Feb 08, 2012, 11:22 AM
seitz2c is offline
Find More Posts by seitz2c
P. Seitz
United States, IA, Mechanicsville
Joined Jan 2006
If your putting it to a vote ! I vote Sky King . another Old fart heard from
Paul
seitz2c is offline Find More Posts by seitz2c
Old Feb 08, 2012, 11:24 AM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
I have fond memories of watching it in Reruns .. had the best of everything .. Planes and cowboys lol
Old Feb 08, 2012, 11:35 AM
chadman is offline
Find More Posts by chadman
United States, OR, Portland
Joined Feb 2011
AS3X for 3 channel?
Thought I'd throw it out there ... could you put the AS3X system in a rudder/elevator only airplane? Would you realize the benefits? I'm building a StevensAero Air Camper and it is going to be really nice - would that new system top it all off?
chadman is offline Find More Posts by chadman
Old Feb 08, 2012, 11:42 AM
BlazingStar is offline
Find More Posts by BlazingStar
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
Gene K
So what do you use now?
BlazingStar is offline Find More Posts by BlazingStar
Old Feb 08, 2012, 12:00 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
i only remove the film after i have the model built and need to sand the foam .. it really helps to leave it on for the tape to have something to grab on to when you glue fuselage pieces together.. tape doesnt like bare foam..
Old Feb 08, 2012, 12:46 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Because I'm building smaller now, I use mainly Depron (regular, Aero), and am trying Pro-formance. The FFF when sliced is too flimsy.
Gene K
Old Feb 08, 2012, 01:00 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Here is my latest laser cut sheet Depron UMX. Intended as a pusher jet using Stryker guts. Unfortunately my Stryker rx has developed a glitch that will cause one servo to go full travel and lock there about once a flight. This has destroyed or damaged three aircraft before I determined the cause. I am waiting on a used Stryker that I bought from another RCG member to arrive before I try to fly this one.
Wingspan is 12"
Airframe only tips the scales at 30 grams
The basic airframe will take very little modification to set up as an EDF once the UMX Mig15 fan is available
John
pmpjohn is offline Find More Posts by pmpjohn
Old Feb 08, 2012, 01:10 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Beautiful bird John .. wouldnt mind having one of those..
Old Feb 08, 2012, 01:15 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
That could be arranged
John
Old Feb 08, 2012, 01:20 PM
kelloggair is offline
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
John
could you make a f4d skyray by chance?
kelloggair is offline Find More Posts by kelloggair
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
