Old Feb 07, 2012, 06:27 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
not the same .. Bluecor/ fanfold comes in a folded pack, 5-6 mm thickness .. see photo
Vyceroy is offline Find More Posts by Vyceroy
Old Feb 07, 2012, 06:56 PM
seitz2c is offline
Find More Posts by seitz2c
P. Seitz
United States, IA, Mechanicsville
Joined Jan 2006
My newest build 16" PT-19 Fanfold blue foam 37grams ready to fly. receiver AR6400L brick , motor ,and gear box from a 4-site . Prop GWS 4x4
Paul
seitz2c is offline Find More Posts by seitz2c
Old Feb 07, 2012, 07:06 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
ah ok. I saw some of that too. I'll get a case of it next time I'm out.
Endlesslag is offline Find More Posts by Endlesslag
Old Feb 07, 2012, 07:22 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Paul
sweet plane .. love to see more bluecor planes..
Old Feb 07, 2012, 07:51 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
I am almost at the covering point of the build.. Nows the time for audience participation .. i need to choose a scheme... any ideas for the Cessna T-50??
Old Feb 07, 2012, 08:23 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Originally Posted by Bill Quantock View Post
Early to the gym to avoid air traffic, third on the floor, throttle up...tail up, up elevator...more throttle...more up elevator......tail goes down, plane does not lift!
Instead, it scurries around the gym floor like it's looking for wayward rodents that might inhabit the school gym. Seemed to be going as fast as my other indoor slow flyers, but refused to lift.Bill
Could it be nose heavy? Or too much down thrust, maybe, or possibly both.
I've had that experience with a 200g triplane I made (there's a video somehwere). I just had way too much down thrust due to a high motor position, though the CG was about right. It scooted around on the floor at high speeds without lifting off, so I decided to chuck it - bad idea. It nose diived into the floor a few feet away. So, I figured out it was the thrust angle and pointed the motor up quite a bit (actually above horizontal). It then flew beautifully - straight into a basket ball net that hadn't been retracted into the ceiling. I've been meaning to fix it for a couple of years now.
Andy2No is offline Find More Posts by Andy2No
Old Feb 07, 2012, 08:38 PM
BlazingStar is offline
Find More Posts by BlazingStar
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
Paul
very nicely done.
Post an in-flight video.
We would all like to see the pretty planes people show off here in their natural element!
BlazingStar is offline Find More Posts by BlazingStar
Old Feb 07, 2012, 08:44 PM
numanair is offline
Find More Posts by numanair
numanair's Avatar
United States, WA, Kirkland
Joined Sep 2010
How much do these sell for in stores near you? Last time I checked here I think it was $36, which seems rather steep.
Nice plane you have there Paul.
numanair is offline Find More Posts by numanair
Old Feb 07, 2012, 09:04 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
I dont remember what it runs here as the stores dont carry the classic double sided bluecor...
i have been getting mine from friends and people that sell left overs or excess they have..
Old Feb 07, 2012, 09:19 PM
seitz2c is offline
P. Seitz
Joined Jan 2006
Thanks guys !
$36 may sound expensive but it's enough foam to build 40 or 50 micros with a lot of foam left over I've got Less than $5.00 in the PT-19 and thats including $2.00 for pilots .
Paul
Old Feb 07, 2012, 09:23 PM
-=BS=-
Thousand Oaks, CA
Joined Jul 2009
$2 for the pilots? I'll take four!
Old Feb 07, 2012, 10:11 PM
seitz2c is offline
P. Seitz
Joined Jan 2006
The pilots can be purchased at parkflyerplastics.com these are the 1"size
Paul
Old Feb 07, 2012, 10:22 PM
-=BS=-
Thousand Oaks, CA
Joined Jul 2009
Oh I've never had good results with clam shell people.
Yours looked like carved foam
Old Feb 07, 2012, 10:24 PM
Bill Quantock is offline
Find More Posts by Bill Quantock
Wingnutz
Bill Quantock's Avatar
Canada, ON, Markham
Joined May 2009
Chasing invisible mice...
Originally Posted by dbacon View Post
A friend did extensive work with leading edge slats, I think that's close, but his were on a .45 size sport plane, high wing, and were fixed about 3/4 inch above and forward of the LE of the wing. They were also slightly curved. They seemed to give more lift, but it would have been nice to eliminate them for other modes of flight.
I think yours will flatten out when the flaps are retracted, right?
However if it is a power problem, I learned from one of these sites how to measure thrust by hanging the plane nose down on a digital fish scale. You read the weight, then zero it, then firewall the throttle, and read again.
Thanks for the suggestions to get my Storch chasing rainbows instead of invisible mice (off the ground). I am intrigued with the scale method of thrust measurement but I don't know how much thrust my model needs or how to calculate required thrust. I have spoilerons but no flaps on my Storch. Spoilerons were not deployed when I was tying to take off. hope to try again this Friday evening with a more aggressive wing incidence.
Keep em flying!
Bill
Bill Quantock is offline Find More Posts by Bill Quantock
Old Feb 07, 2012, 10:35 PM
Wingnutz
Canada, ON, Markham
Joined May 2009
Chasing rainbows...
Andy2no,
Thanks for your suggestions. CG seems close to where my plan puts it and eyeballing the thrust line puts it pretty close to the datum line or slightly downwards. However, both suggestions are now on my suspect list.
I'll post after my next try.
Bill
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
