Feb 03, 2012, 07:02 AM
Southlake, TX
Originally Posted by Bill Quantock
Here's the model that's been giving me the wiring grief. Waited to post until I'd gotten the wiring sorted and taxi tests completed in the basement. Got the tail up on one run before sanity took over!
It's a 'fairly' scale model of a WWII German Fieseler Storch. Chose it because it's so good looking (not)...actually it's another attempt to see how slow a scale micro can go indoors...so I started with an airplane that was designed to go slowly in the first place
So far, it's all 4-Site organs but with the size and weight of the model, I may be pushing the little 8.4mm brushed...
WS=33", weight so far 71g, calculated wing area approx 1 sq ft, so even if it puts on a few grams before I'm done, wing loading should still allow it to fly pretty slowly.
Interesting features include working landing gear(works the way the Storch's did I think, and sort of scale looking) using two ballpoint pen springs...I'm way oversprung. It takes a full pound to compress each spring completely...the model weighs less than 3oz! Only reason I didn't re-do the springs is I started with the landing gear and I'd have to dismantle the plane to change the springs!
Full length fixed wing slots (the Storch had these) It'll be interesting to see what these do (if anything).
Wikepedia shows a colour picture of Rommel's personal Storch while he was commanding German forces in N. Africa...it's white! so I'll probably just do all the brown camo squigglies with a brown sharpie.
I read a lot about Storches and if you're still reading all this babble of mine, I ran across a good true story involving a Storch. Apparently a Storch was the last aircraft "shot" down in a dogfight in Europe in WWII...by a Piper Cub! The American crew spotted the Storch below them and dived to attack, 45 service pistols blazing away out the window! In an attempt to evade the attack, the low flying Storch caught a wingtip and crashed injuring the crew. The Cub crew landed nearby and administered first aid!
It's been fun building this thing...now if I can get UNGN to tell me how to use the Xport to run the flaps while still using spoilerons, my Storch will only need a slight headwind to be able to "land backwards on an outhouse roof" (scale outhouse)
Maiden this weekend I hope.
Bill
I have always wanted to build a Stoch.
To get Flaps from the Xport, Mix Flaps>Gear 100%
