Old Dec 23, 2009, 03:19 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by dylantorquerol View Post
BTW, how do you program the AR6400 for brushless?
Bind brick. Power up Brick with TX throttle up and to left.
The brick will acknowledge the the change and its ready for an ESC signal wire to be plugged in.
UNGN is offline Find More Posts by UNGN
Old Dec 23, 2009, 04:22 PM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
Bowerz, on your Micro-Avion build log, you said you used a 2s 800mah lipo, and didn't mention the use of a diode. Did it still work? BTW, how do you program the AR6400 for brushless?
Yeh, it did work fine, but i'm wondering if i was just lucky. As i said, i didn't think you needed it as it was working with mine OK.
Bowerz is offline Find More Posts by Bowerz
Old Dec 23, 2009, 08:54 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
my 20" bipe is working of 5v bec from the BL esc.... personally i dont think the extra .8v is going to destroy the thing.. if it does, its cheap enough to replace (and gives me a reason to upgrade to the 6400L)
invertmast is offline Find More Posts by invertmast
Old Dec 24, 2009, 12:33 AM
bungholio is offline
Find More Posts by bungholio
duct tape and hot glue
bungholio's Avatar
Olympia,WA
Joined Dec 2009
Post some pics of bipe
after all the thread is SHOW OFF YOUR AR6400 PLANES not talk about if our brick blew up
bungholio is offline Find More Posts by bungholio
Old Dec 24, 2009, 06:12 AM
GIFLYRC is offline
Find More Posts by GIFLYRC
GIFLYRC's Avatar
INDEPENDENTLY POOR in OHIO
Joined Dec 2001
Yes, perhaps a lot of discussion and not enough pic's but what better place to talk about applications and possible problems and mods than the thread directly related to the primary subject?
Should we have seperate threads on every subject relative to the ar6400??
I think not!
My $00.02-------Roger aka GIFLYRC
GIFLYRC is offline Find More Posts by GIFLYRC
Old Dec 24, 2009, 07:37 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Originally Posted by giflyrc View Post
yes, perhaps a lot of discussion and not enough pic's but what better place to talk about applications and possible problems and mods than the thread directly related to the primary subject?
I think not!
My $00.02-------roger aka giflyrc
+1
Old Dec 24, 2009, 08:57 AM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
How about the original AR6400 thread
http://www.rcgroups.com/forums/showt...ghlight=ar6400
answer to the 5v question
http://www.rcgroups.com/forums/showp...&postcount=201
but even going back to the vapor brick there are reports that it works
http://www.rcgroups.com/forums/showt...r+brick&page=6
mcross is offline Find More Posts by mcross
Old Dec 24, 2009, 10:05 AM
Joined Mar 2004
already did:
http://www.rcgroups.com/forums/showp...1&postcount=87
Old Dec 24, 2009, 11:37 AM
GIFLYRC is offline
GIFLYRC's Avatar
Joined Dec 2001
me too!
Old Dec 24, 2009, 05:27 PM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
Fine, enough talk, need more pics! BTW, invertmast, how does you bipe fly?
dylantorquerol is offline Find More Posts by dylantorquerol
Old Dec 29, 2009, 03:10 AM
turbinator is offline
Find More Posts by turbinator
France
Joined Nov 2003
A380 canadair Dash 8 AR6400 models
Hi
Here my models for AR6400. An A380 a canadair and a Dash 8 for indoor flight.
They are all built with foam using a CNC foam cutter.
Wing span 48cm for the 3 models.
Weight 35g for the 380; 30 g for the canadair; 28 for the dash.
More details on :
http://projetcnc.blogspot.com
turbinator is offline Find More Posts by turbinator
Old Dec 29, 2009, 07:36 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Originally Posted by boredom.is.me View Post
I just sent in a request to find out about the actual voltage range. We'll find out soon enough. Here is what I sent. It does cover everything right?
The AR6400, when used regularly, is subjected to 4.2v to 3.2v from a single cell lipo battery. Is this the actual, as in don't go any higher, voltage range or can this support 5v safely from an external ESC, wether two cell or three (four would be pushing the physical limits of the servos)?
Bottom Line: Is it safe to run the AR6400 on 5v from the BEC of an external ESC?
It is actually a somewhat of a large discussion, due to the fact that everyone is putting diodes on their positive wires to the receiver.
This is the responce:
Kevon
Thank you for contacting Horizon Hobby Product Support.
If the ESC has a BEC then you can use up to a 4 cell lipo or whatever
the ESC can handle. The receiver can take up to 9.6volts but the servos
are only rated up to 6volts.
If you should need further assistance regarding this issue please reply
to this e-mail for additional support.
If you need assistance in the future, please feel free to e-mail us at
productsupport@horizonhobby.com or you may also contact us toll-free at
1-877-504-0233.
Make sure to visit our web site at http://www.horizonhobby.com to see
all of our newest products!
Thank You,
I am so confused right now.
boredom.is.me is offline Find More Posts by boredom.is.me
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
I love the two air liners! How do they fly?
Old Dec 29, 2009, 07:38 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Kevon
1-877-504-0233.
Thank You,
Basically, no need for a diode if using a BEC, which is exactly what i thought all along!
Old Dec 29, 2009, 08:05 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Kevon
1-877-504-0233.
Thank You,
That sounds like a generic response and is not what individuals from HH have told us on this board. It's a good thing to have in your pocket when an AS2000 burns up on 5V, though if you don't have the skills and $3.00 to fix it.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
