Old Dec 21, 2009, 12:53 AM
bungholio is offline
Find More Posts by bungholio
duct tape and hot glue
bungholio's Avatar
Olympia,WA
Joined Dec 2009
Thanks a million bijillion quintupillion kaboomillion!!!
I'll hope to post pics as soon as I get parts
also I decided that I would buy a parkzone UM mustang motor and try that first, then if that doesn't work I'll put it in another plane and put in all the electronic we talked about.
bungholio is offline Find More Posts by bungholio
Old Dec 21, 2009, 03:47 AM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
Why is everyone talking about putting a diode in, mine works just fine without?
Bowerz is offline Find More Posts by Bowerz
Old Dec 21, 2009, 05:49 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Because Horizon Hobby said the bricks and servos should be run on 1s.
I tell people Power Wheels run great on 18 volts, but if they burn them up, I'm not going to warranty it for them.
UNGN is offline Find More Posts by UNGN
Old Dec 21, 2009, 06:12 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
If you're using a BESC (which most ESC's are now), there's no need to do it, it puts out the correct voltage anyway.
Old Dec 21, 2009, 06:45 AM
Veteran is offline
Find More Posts by Veteran
Mc-Fly
Veteran's Avatar
Melbourne-Australia
Joined Mar 2008
Bowerz for the sakes of a diode your running it at 5v, which is cheaper a 50c diode or a 50$ brick? Literally a brick
Veteran is offline Find More Posts by Veteran
Old Dec 21, 2009, 06:57 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
So you have to add a diode for the AR6400 even with a BESC? Seems kind of silly to me, what the point of them adding BL capability?
Old Dec 21, 2009, 07:28 AM
ghost2212 is online now
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Because the primary use is on one cell brushless setups where the voltage is not a problem.
ghost2212 is online now Find More Posts by ghost2212
Old Dec 21, 2009, 07:37 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The limits on the rcvr are 3.2 to 4.2 volts. To get more poop out of the motor, you need the 2 cell system where the BEC puts out 5.2 volts. Mine runs on the 2 cells. A buddy has the brushless motor and ESC coming from HK that runs on the single cell for a weeny Bug, and of course, needs no diode. So the choice is whether you want to run 1 or 2 cell system.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 21, 2009, 10:03 AM
jantel is offline
Find More Posts by jantel
Jantel
Surrey UK
Joined Dec 2003
Here are some pictures of my 1/72 scale Bristol Superfreighter, power is 2 X 6mm pager motors using a single 150Ma cell from a Blade MCX, construction is 0.050" Durobatics, flies really well after a long scale like take off run , more details at http://www.rcgroups.com/forums/showthread.php?t=1161392
jantel is offline Find More Posts by jantel
Old Dec 21, 2009, 10:12 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
:O Wow! I would love the building skills of some of you guys!
Old Dec 21, 2009, 12:49 PM
EdLokken is online now
Find More Posts by EdLokken
The Villages, Fl.
Joined Oct 2002
Just completed Miss America. I scaled it down to about 26” wing span. The radio is an AR6400, motor is a 5 gram outruner, a 4540 prop, and a DP 3A 1S 1 gram brushless speed controller. I flew it this morning with a 400ma lipo because I thought it would be tail heavy. Well it was nose heavy and was able to trim in enough up trim for a very pleasant flight. It weights with the 400ma battery 53.5 grams, or 1.9 oz, with a 240ma battery 48.5 grams, or 1.7 oz. The 240ma battery will be just right for balance.
It has lots of power, after getting some altitude it just floats around at less than throttle. I have to get a black Sharpie to change the color of the prop. It is covered with Japanese tissue, and one coat of thinned dope.
EdLokken is online now Find More Posts by EdLokken
Old Dec 21, 2009, 03:49 PM
GIFLYRC is offline
Find More Posts by GIFLYRC
GIFLYRC's Avatar
INDEPENDENTLY POOR in OHIO
Joined Dec 2001
VERY VERY NICE! Miss America----and a real show of craftsmanship, perfect application for the AR 6400
Wish it was mine!----Roger aka GIFLYRC
GIFLYRC is offline Find More Posts by GIFLYRC
Old Dec 21, 2009, 07:43 PM
mtflyr is online now
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Jantel cool bird
Pete
mtflyr is online now Find More Posts by mtflyr
Old Dec 22, 2009, 12:01 AM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
Very cool. I am wondering the AUW of these planes...
dylantorquerol is offline Find More Posts by dylantorquerol
Old Dec 22, 2009, 12:35 AM
bungholio's Avatar
Olympia,WA
Joined Dec 2009
P-47 Build Log
I now have a build log formy p-47 here:
http://www.rcgroups.com/forums/showthread.php?t=1162526
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
