Old Dec 09, 2011, 09:58 PM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Hi all. I'm on my third micro but first homebuilt. I have a Vapor and a Trojan but am using the Trojan guts for this: http://www.rcgroups.com/forums/showthread.php?t=1551932
I haven't even maidened it yet but maybe tomorrow. Yesterday I realized rcfoam is only an hour from me so I went down and bought a few 3mm and one 2mm sheet of Depron. Also, a 2000kv/10g/2s BL and a Plush 6A ESC since I was there, haha.
So, with that said, I'll fly my balsa "Extra" until it crashes, then make another out of 2mm Depron.
My next question. Will the AR6400 work for an airplane with the 10g/2000kv BL? I'm not asking if/how to wire it. I'm asking if the plane (control surfaces) will be too large for the servos. I'm running the brick for elevator/rudder and twin 1.9g for the ailerons. If not, ill ask elsewhere so as not to hijack
Sixinarow is offline Find More Posts by Sixinarow
Old Dec 09, 2011, 10:18 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The AR6400 will be fine in a plane up to about 5 Oz. The new bricks/servos might be good up to a 10 Oz plane.
UNGN is offline Find More Posts by UNGN
Old Dec 10, 2011, 10:44 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
If you are after 3D flying ,you will run into some real performance issues as the thrust on the little linear servos is not very high
use long servos (L) and make spades on control surfaces to aid the throw - also- hinging must be "floppy"
Our 22" Extra using beast stuff is a terrific peformer at 60 grams
go much above that sizewise , you will need to fly slower , have bigger surfaces because - -you have only so much thrust available from the servos.
Our 160 sqinch TIPO weighs 55 grams and has L servos and th e small geared motor as used in the UMX Extra - it is underpowered except for mild flying and the control power is minimal as there are no spades or aerodynamically balanced control sections.
I really don't se how a 10 oz plane will work with the 6400 series rx/servos
richard hanson is offline Find More Posts by richard hanson
Old Dec 10, 2011, 11:08 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The NEW servos have 2X the power of the old ones.
SPMSA2030L.
The new AS3X bricks have these servos on the boards. They should have enough power for a 10 Oz plane (maybe a 5 Oz 3D plane).
New Servo
Old Servo:
Check out how much larger the motor is on the new servo.
Old Dec 10, 2011, 11:47 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Why are they making bigger linears? They are annoying. They are good for weight, but not if they keep getting bigger and bigger.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Dec 10, 2011, 11:48 AM
Addicted
Joined Dec 2011
Thanks guys. I have the newer single servos and the standard AR6400 (UM Trojan).
Richard, my BL is about the same specs as the Park 180 you're using in your 140% 300.
Old Dec 10, 2011, 12:03 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
+1
Get rid of linear servos altogether and use micro rotary.
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Dec 10, 2011, 12:33 PM
Joined Oct 2007
The linears are good and simple to boot - They are even accurate enough for the tiny helis
I would use rotary if they fit my 6400 type rx and were easy to come by. I will have th e new stabilized rx and linears when they are made avilable.
Old Dec 10, 2011, 12:49 PM
Joined Nov 2007
I'ld rather get another BNF than buy an AS3X brick. I bet they cost around $80 or more. Compare that to "easy to come by" servos. I'll gladly wait 3 weeks.
But then again, my opinion is highly biased due to the fact that I do not like combination electronics anymore. I like individual components.
Old Dec 10, 2011, 01:20 PM
UltraMicro is offline
Find More Posts by UltraMicro
UltraMicro's Avatar
United States, CA
Joined Jul 2011
Originally Posted by Cheesehead View Post
How does it fly?
Flies great: you can go to my blog to get full review.
UltraMicro is offline Find More Posts by UltraMicro
Old Dec 10, 2011, 01:37 PM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Originally Posted by Razors edge 29 View Post
+1
Has anyone compared the torque of the small (HKS-282) rotarys from Hobbyking? Factory specs aren't worth much these days.
Cheesehead is offline Find More Posts by Cheesehead
Old Dec 10, 2011, 02:38 PM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
I remember flying my Ikarus foamies with GWS Pico and HS 55 servos. They generally came in at less than 7oz.
From my experiences with the linear servos, I would rather use a HS 50 than a larger linear servo. I've not seen any of the 2030L but it would have to be a huge improvement over the 2000L for me to consider using them in planes > 4oz.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Dec 10, 2011, 02:45 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
For the same weight as an HS50, you could have three 2.3g servos. Two of the 2.3g servos would have more power than 1 HS50.
It also depends on what surface is being controlled. For Rudder on a 7Oz plane, I'd rather use a 2.3g servo that a 7g servo.
Old Dec 10, 2011, 03:17 PM
Eclipse_7's Avatar
Joined Nov 2003
I'd rather use the 5.8g, 8.4oz/in HS 50 for a pull-pull rudder, or the 4.5g, 11oz/in torque HS 35.
But only on higher performance planes > 4oz.
Old Dec 10, 2011, 04:37 PM
Joined Oct 2007
Our 7 ounce 3d models (indoor/outdoor types ) use servo which are in th "20" in ounce range
Some of these are 5 gram digitals
The 60 gram 3dtypes work great running the 6400L stuff
on large models - 10 ounce- 16 ounce etc., we run to the 30 in ounce types Models like the Zoom/ Super Zoom are very responsive on this type
The new Venus is unreal in response using 30 in ounce
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
