Old Nov 19, 2011, 05:45 PM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Originally Posted by ara25demayo View Post
YEAHH MAYBE BUT IS LIKE is better the ar6300 for external esc because it wheit 2gr and ar6400 with servos and esc 5 gr and with 6400 i cant use 2s lipos
It's easy to run a 6400 on 2s lipo. You just need a diode in the BEC power connection to the reciever.
Petefoss is online now Find More Posts by Petefoss
Old Nov 19, 2011, 09:44 PM
buratino is offline
Find More Posts by buratino
Singapore
Joined Nov 2007
Pilatus Porter
Hi, here is my latest build, 21" wing span Pilatus Porter. AUW 41g with Turnigy 160mAh. I am using AR6400L and AR2000L for aileron.
buratino is offline Find More Posts by buratino
Old Nov 19, 2011, 11:26 PM
ara25demayo is offline
Find More Posts by ara25demayo
México, MOR, Jiutepec
Joined Oct 2011
Cool can you giveme plans or wich kit do you do i want a porter or a cessna caravan
ara25demayo is offline Find More Posts by ara25demayo
Old Nov 20, 2011, 03:10 AM
buratino is offline
Singapore
Joined Nov 2007
Hi, I don't have exact plan for this, the frame and wing based on the P. Tritle plan on this page: http://www.rcgroups.com/forums/showt...pilatus+porter
Old Nov 20, 2011, 09:47 AM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
Lovely!
I love that plane and your interpretation of it is just sweet! Do you have dual ailron servos (progammable flaps in option!)?
Chrizz is offline Find More Posts by Chrizz
Old Nov 20, 2011, 10:17 AM
Joined Oct 2011
with what did you cover it?
Old Nov 20, 2011, 10:29 AM
Joined Oct 2011
my other buildin that im going to start today because here in mexico we have a holiday ia an arado ar 234 in 20" i dont know itf twin 27-30mm or twin pusher or twin tracker
Old Nov 20, 2011, 08:14 PM
buratino is offline
Singapore
Joined Nov 2007
@Chrizz: I am using single aileron servo AR2000L as I have only 1 left. Been thinking about flap for this plane but later I decided not to go with it as I think the effect will not be significant for this size and at my place I can only do hand launch and grass landing.
@ara25demayo: I am using microlite from homefly.com, very light and worked great.
Old Nov 22, 2011, 02:14 AM
kdwzagi is offline
Find More Posts by kdwzagi
(madkev :) )
kdwzagi's Avatar
United Kingdom, England, Stafford
Joined Dec 2002
indoor aerobat
Hi
after my P51 bit the dust I decided to build an aerobat for indoor flying. I've used every last bit off the mustang including the torque rod setup and pushrods
construction is mainly from 2mm depron but I've added two 6mm pieces on the nose to act as a motor support and also to absorb some impact ;-)
the wing has a double thickness to 45% of the chord to act as a Kf aerofoil
it loops and turns on rudder very well but it could do with a better roll rate so I may fit another linear servo at some point and do away with the torque rod setup
it's very stable in flight. probably because of the large chord
wingspan 19"
weight 35g
kdwzagi is offline Find More Posts by kdwzagi
Old Nov 22, 2011, 09:18 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
One of these days, I need to take my hand at scratch-building!
Do you have any carbon on this plane? Can I see the underside?
BryanEW710 is offline Find More Posts by BryanEW710
Old Nov 22, 2011, 10:11 AM
kdwzagi is offline
(madkev :) )
kdwzagi's Avatar
Joined Dec 2002
Aerobat
I have a 2mm carbon rod let into the wing. Not sure if it's needed but better to be safe than sorry
Old Nov 22, 2011, 06:11 PM
taildragger1589 is offline
Find More Posts by taildragger1589
Lookin' up at the centerline
taildragger1589's Avatar
United States, GA, Lawrenceville
Joined Feb 2005
For those of you which liked the 20" model of the 56" Champion Stampe kit.
Here is the video.
Nick
Lil stampe (2 min 49 sec)
taildragger1589 is offline Find More Posts by taildragger1589
Old Nov 22, 2011, 11:42 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Nice Stampe, taildragger1589.
I built the 20.5" 3 channel Falcon Models 2mm depron Easy Scale Stampe a while ago, and have been taking it to indoor fly-ins. It's around 42g AUW, with a 240mAh Hyperion G3 cell.
I used a Vapor brick with a small 5 or 6g 4600Kv brushless motor using a 1s ESC on the rudder channel (spare pads) and a mix on my DX6i to put it on the throttle stick - the onboard servos are on the elevator and aileron channels on the Vapor brick.
I haven't posted any pictures because it's not made with an AR6400, though the Vapor brick has a lot in common. It was attacked by a Parkzone UM Corsair at the last fly-in, and had its motor mount sheared in two, but it's feeling better now. Maybe I should take some pictures before something worse happens to it.
Andy2No is offline Find More Posts by Andy2No
Old Nov 23, 2011, 12:55 PM
Joined Feb 2005
sounds like a plan. I'd like to see it. after all, it is an ar6400 sized plane
Old Nov 23, 2011, 05:18 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Falcon Models Easy Scale Stampe (brushless, single cell, with a Vapor brick)
Okay. Here it is.
Most or possibly all of the Falcon biplanes seem like a good choice for an AR6400. The original Falcon gear made them a bit heavier. My Stampe is nice and slow, much more indoorsy than my 4-Site.
Thrust from the 4600Kv 5g or so motor on a single cell and a 4025 prop isn't that great - a lot less than 1:1, but there's enough power to make it fly nicely. I could probably have got similar performance with an SU-26 motor and geabox, and about the same duration, I'm not sure. It's a bit heavier than my SU-26 biplane conversion, but feels a bit more powerful and stable and it seems to fly slower.
I bought the Vapor brick from www.MicronRadioControl.co.uk and asked them to supply it with the trailing servo socket on channel 4, to connect the ESC, because my soldering skills aren't that good and my hands aren't steady enough to do anything that small.
I've fitted the 240mAh single cell Hyperion lipo in these pictures - hiding behind the motor mount, on Parkzone UM style velcro.
I seem to have disguised most of the scars and prop cuts in these photos, without trying to. It's collected quite a few already. In the Stampe vs Corsair incident, the square part of the motor mount separated between the layers of plywood, and the top wing broke away from the fuselage. I fixed both with some UHU POR. There doesn't seem to have been any other damage though, apart from a bit of a crease in the depron near the nose.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
