Latest blog entry: AR6400 guillows Space Shuttle
bungholio:
http://www.spektrumrc.com/ProdInfo/Files/SPMAR6400L.pdf Why is no one using strip carbon fiber on the wing? I notice everyone is using rod's supported from the fuselage, is the foam stiffer in such a small size? |
You might be best going with a 5g brushless. AUW with mount and prop are about 11g vs about 8g for the Mustang motor/prop and you'll have almost 2X the thrust (on 2s vs. 1s and the mustang motor). ESC weight would be another+ 7g and Extra 1S battery would weigh 10g more, so a cheap ($25 total) 2S brushless setup would weigh about 20g more and should fly a plane over 100g.
to switch the AR6400 to Brushless, bind it normally, then plug in the battery with the throttle stick on the TX up and to the left. Here's Modfly's tutorial |
2s is 2 cell Lipo (7.4v) An AR6400 can only work on 1S. You can simulate 1s operation, by running a Lipo compatible ESC on 2S and powering the AR6400 with the BEC (Battery Eliminator Circuit) output. Because the BEC of an ESC is normally 5 volts, a Diode can be soldered into the AR6400 Positive battery wire that will drop the input voltage from 5v to 4v, which is just about perfect. A good 2S battery pack for this would be Zippy 2S 180mAh 5g Brushless motor or this one, which is lighter (though the specs make it seem heavier) 5.4g motor Both motors should work fine with the 5043 or 5030 GWS props that are very popular with the SU-26 people. I don't know if the 5g motors come with a prop adapter. Mine did when I ordered them last month, the picture doesn't show it, but you'll need one with these props. Cheap ESC Slightly better Cheap ESC that is always out of stock. |
For reference, the empty, hinged Mustang airframe weighs only 18g. The rest is radio, motor/gearbox, bellcrank/pushrods and batteries. |
does this sound right, i just found it:
http://www.rcgroups.com/forums/showthread.php?t=1103757 |
My other model planes
Here are my other model planes that if the p-47 works, i would like to convert some more to rc. but i dont know which ones?
See that this is what I did on my Cox Zero in post #109 in this thread |
| Thread Tools | |
| Pictures: When planes were able to show off, at air shows | Patrick Plawner | Life, The Universe, and Politics | 126 | Mar 26, 2013 06:30 AM |
| Cool Show off your Parkzone Micro P-51!!! | P-51C | Indoor and Micro Models | 938 | Nov 20, 2012 06:49 PM |
| Discussion Show us those planes you really need to replace! | JimTMich | Parkflyers | 8 | Apr 26, 2012 11:05 AM |
| Discussion Show off those home made camera gimbals! | ben1101 | Aerial Photography | 2 | Jul 22, 2009 07:11 PM |
| Gallery Show off your planes | texan | Wimberley Valley Flyers | 4 | Apr 13, 2006 02:10 AM |
