Old Nov 06, 2011, 03:45 PM
Pouncer is offline
Find More Posts by Pouncer
Wanton construction
Pouncer's Avatar
Stockholm Sweden
Joined Sep 2006
Originally Posted by Nooflyer View Post
BryanEW710,
I'll probably put an AP03 with the 3.5a .3g esc in it. Not sure what prop i should use. But i know i'll stay with single cells.
I'd be interested in knowing more about this single cell ESC, I've recently completed a 30 cm stryker using a HK 2 gram outrunner and a HK 3A ESC but experienced some difficulties as the ESC would shut down after a few seconds at full throttle?
http://www.rcgroups.com/forums/showthread.php?t=1534571
Pouncer is offline Find More Posts by Pouncer
Old Nov 06, 2011, 04:05 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
BryanEW710,
Throw a 4025 on it.
http://www.hobbyking.com/hobbyking/s..._ESC_3_5A.html
boredom.is.me is offline Find More Posts by boredom.is.me
Old Nov 06, 2011, 05:40 PM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Originally Posted by seitz2c View Post
The maiden went well just slightly nose heavy. so i'm calling it done! I ended up at 38 grams
Paul
Awsome, could you tell me a bit more about the materials being used?
/Ryde
Meshuggah is offline Find More Posts by Meshuggah
Old Nov 06, 2011, 07:34 PM
Nooflyer is offline
Find More Posts by Nooflyer
Nooflyer's Avatar
United States, MO, KCMO
Joined Aug 2005
boredom.is.me,
thanks i'll try that as i feel the 3020 prop would be speedy!
Nooflyer is offline Find More Posts by Nooflyer
Old Nov 08, 2011, 02:53 PM
Nooflyer is offline
Nooflyer's Avatar
Joined Aug 2005
Recieved my 3.5a esc but i'm still having issues. Are these esc programmable, if so is there a manual somewhere? thanks
Old Nov 08, 2011, 03:01 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Her is the manual for that esc:
http://www.hobbyking.com/hobbyking/s...X246741X34.pdf
For many HK products the manual can be found when you click on "Files"
coriolan is offline Find More Posts by coriolan
Old Nov 08, 2011, 03:09 PM
Nooflyer is offline
Nooflyer's Avatar
Joined Aug 2005
thank you, coriolan
Old Nov 08, 2011, 03:10 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Nooflyer,
What issues are you having? Not everything can be solved by programming the ESC.
What motor (and Kv version, if appropriate) and what prop are you using? Are you able to measure the current (and ideally, the battery voltage at the same time)? Maybe you've over propped it.
Andy2No is offline Find More Posts by Andy2No
Old Nov 08, 2011, 03:37 PM
Nooflyer is offline
Nooflyer's Avatar
Joined Aug 2005
I'm using an Ap03 7000kv with the new .3g 3.5a esc and a 4025 prop.
The issue i'm having is not enough with a brand new 150mah 25c single cell batt., with the brushed motor in my yak 55m i'm getting 1.5 to 1 aspect ratio. But with the brushless i'm getting maybe 1:1 thrust.
Basically i have to be full throttle to hover. I was told to put an 4025 prop on for 3d and that hasnt worked out. I know 3020 prop is recommended but i'm not after speed.
Old Nov 08, 2011, 04:05 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I see, Nooflyer. I think that's really the wrong motor for the job, and it probably draws too much current with a 4025. The 4200Kv version would be more appropriate for that sort of plane, and allows a bigger prop:
http://www.hobbyking.com/hobbyking/s...idProduct=9664
- the recommendation there is for 2s (I've no idea if it's right). A 4025 would be fine with the 4200Kv one on 1s, and you might be able to go a bit bigger to get more thrust - maybe 5x3.
You don't get the same benefits from going from a 1s coreless brushed (geared) setup to a 1s brushless direct drive setup that you'd expect. It's not the same as upgrading a plane that has a geared brushed motor and runs on a 2s or 3s lipo, unfortunately. The efficiency of direct drive brushless motors at such low voltages isn't that great, and coreless motors seem pretty good - they just don't live as long. Modfly had some success with a small high Kv brushless motor and a gearbox.
Unfortunately, using a high Kv brushless direct drive isn't good for efficiency and thrust, only speed.
Old Nov 08, 2011, 04:14 PM
Nooflyer is offline
Nooflyer's Avatar
Joined Aug 2005
Bummer
But thanks Andy2No, I guess i'll just make another order to HK! Luckily they are in stock now
Old Nov 08, 2011, 04:19 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
You're welcome, Nooflyer. The Extra looks good. I hope you get it working the way you want it to.
Old Nov 08, 2011, 04:21 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Bummer
A friend is running one of these on a single cell with a GWS 5030 prop with good results.
http://www.hobbyking.com/hobbyking/s...idproduct=9662
I have one on the way myself.
Tim Wolff is online now Find More Posts by Tim Wolff
Old Nov 08, 2011, 04:28 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
way better on 2S
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 08, 2011, 04:37 PM
Nooflyer is offline
Nooflyer's Avatar
Joined Aug 2005
Will order one of these motors from Hk in the next day.
Until then I'm just going to put the brushed 4site motor in and see how she flies!
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 05:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 07:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 12:05 PM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 08:11 PM
