Old Nov 03, 2011, 09:23 PM
Nooflyer is offline
Find More Posts by Nooflyer
Nooflyer's Avatar
United States, MO, KCMO
Joined Aug 2005
My Latest Build
Here's my scratchbuilt extra 300. Its a little bigger than E-flite's Extra because i wanted a slower UM planes while still using the 4-site equipment. Weight should come out 32g hopefully!
Nooflyer is offline Find More Posts by Nooflyer
Old Nov 04, 2011, 10:10 AM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
Video of my 3rd gen Micro Capricorn
Video of my Micro Capricorn. 1.1 oz with 9" wingspan. All electronics from Parkzone P-51.
Micro Capricorn, 1.1 oz and 84 sq inches, flown by Otto Dieffenbach (3 min 7 sec)
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Nov 04, 2011, 10:14 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
2mm depron?
SS
starscream4002 is offline Find More Posts by starscream4002
Old Nov 04, 2011, 10:53 AM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
But will it rise off water? I'm surprised how well it performs at various speeds, altitude, and attitude!
Jay
Faethor is offline Find More Posts by Faethor
Old Nov 04, 2011, 01:18 PM
Joined Aug 2011
Jay
Me too. It won't ROW, I tried in the pool. It needs more power to break the adhession of the water or I need to develop some skis like I did for my 7 oz mini to get the pontoons and rear wing surface out of the water. It will not pull through an inside loop but can handle outsides which I believe is thrust line related. Best.
Old Nov 04, 2011, 05:21 PM
DarrylB is offline
Find More Posts by DarrylB
ACT, Australia
Joined Jul 2008
Ryan NYP and Ford TriMotor (Dumas kits)
After a bit of a (forced) break from building I've finally gotten two new micros ready to test fly.
The RyanNYP comes in at 36g flying weight and the TriMotor at 46g. Both rudder/elevator only.
I chose not to make any specific efforts to save weight and added most of the detailing and trims as I was keen to get a more scale result than some of my other planes.
DarrylB is offline Find More Posts by DarrylB
Old Nov 05, 2011, 04:15 PM
seitz2c is offline
Find More Posts by seitz2c
P. Seitz
United States, IA, Mechanicsville
Joined Jan 2006
The maiden went well just slightly nose heavy. so i'm calling it done! I ended up at 38 grams
Paul
seitz2c is offline Find More Posts by seitz2c
Old Nov 05, 2011, 06:50 PM
Nooflyer is offline
Nooflyer's Avatar
Joined Aug 2005
starscream4002,
yes its all 2mm depron. I'm waiting for my brushless setup to arrive from HK or i might just trash my yak 55m to try it out.
Old Nov 05, 2011, 07:14 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by seitz2c View Post
The maiden went well ....
Paul,
Beautiful!
Gene K
speedy01 is offline Find More Posts by speedy01
Old Nov 05, 2011, 08:59 PM
Trackerman is offline
Find More Posts by Trackerman
Canberra Australia
Joined Jul 2007
Spirit of St Louis & Ford Trimotor
DarylB,
great fun last night, the Spirit was very realistic in flight flew beautiful. What can I say about the Trimotor, she looks terrific, but couldn't quite sustain flight. Keep at her she will be a real beaut to.
Cheers
Paul
Trackerman is offline Find More Posts by Trackerman
Old Nov 05, 2011, 10:56 PM
WonkoTehSane is offline
Find More Posts by WonkoTehSane
Joined Jun 2011
Beautiful Super Chipmunk.
Might encourage me to finish up my Super Chipmunk conversion from a set of Guillows plans.
WonkoTehSane is offline Find More Posts by WonkoTehSane
Old Nov 05, 2011, 11:24 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
starscream4002,
What's the powertrain going to be made of?
BryanEW710 is offline Find More Posts by BryanEW710
Old Nov 06, 2011, 08:06 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I built a few models around the 6400 setup- using the UMXExtra as the baseline for performance .
The most noticeable problem came when I tried comparisons of the VAPOR with the UMX
I wanted VAPOR speed with UMX performace
The rub was the weight issue
Using UMX rx and motor and mount - I added the VAPOR landing gear and a 160 ma battery
The airframe weight is the issue - You must stay under 34 grams all up inc battery to achieve same power loading
BUT you must drop down to low 20 gram area to get same wing loading!
This little flying disc weighs all up at 27 grams
The airframe is 7 grams- the next one will be larger - thei one is 12" dia (113 sq inches total) from 3mm Depron and has .027 dia cf around perimeter and a strip CF trailing edge . the elevons are bare foam
It is FAST! and accelerates vertically .
I think -I can go to 14" dia using 3 mm foam and narrower flat sections-and still stay below 32 grams all up with battery-this will give 153 sq inches
The airframes I have tried using milled 2mm foam are just too heavy- so for the next scale like aerobat -I am going to CF and covering.
I used Reynolds green film - attached with Elmer's spray adhesive - this works well and light heat shrinks the film easily
richard hanson is online now Find More Posts by richard hanson
Old Nov 06, 2011, 02:02 PM
Nooflyer is offline
Nooflyer's Avatar
Joined Aug 2005
BryanEW710,
I'll probably put an AP03 with the 3.5a .3g esc in it. Not sure what prop i should use. But i know i'll stay with single cells.
Old Nov 06, 2011, 02:44 PM
BryanEW710's Avatar
Joined Sep 2010
BryanEW710,
Do you use a lot of carbon reinforcement?
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
