Old Nov 22, 2009, 08:37 AM
the riot is offline
Find More Posts by the riot
stop me i'll hurt myself
lancaster county pa
Joined Dec 2008
Gallery
show off those ar6400 planes!
show them off ladies and gentlmen
heres mine
mustang motor
23g
2mm depron
the riot is offline Find More Posts by the riot
Old Nov 22, 2009, 04:53 PM
Dennis A is offline
Find More Posts by Dennis A
Wyomissing PA
Joined Aug 2003
Mig 3
...here's one. The MIG has flown, the Bearcat, not yet.
Dennis A is offline Find More Posts by Dennis A
Old Nov 22, 2009, 10:06 PM
seitz2c is offline
Find More Posts by seitz2c
P. Seitz
United States, IA, Mechanicsville
Joined Jan 2006
15 " C-47 Rud., Ail, Ele ,2 ss blue 7mm motors Gws 2" props ,33 grams fan fold blue foam.
Paul
seitz2c is offline Find More Posts by seitz2c
Old Nov 23, 2009, 08:16 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
heres mine
mustang motor
23g
2mm depron
Any chance you weighed the components before assembly?
I'm trying to estimate how heavy my current project will come out, but can't find weights for a few pieces. Specifically the motor/gearbox/prop, and the linkages. I think I'll be using the aileron bellcrank instead of two servos, but haven't fully decided yet. It all depends on what gear I can find good deals on.
The airframe(2mm depron, carbon bracing similar to yours) is at 11g fully assembled and hinged.
I wanted it to be under 30g, but if yours is 23g then maybe I can hope for 25g!
Here's a picture of it beside my mustang:
wparsons is offline Find More Posts by wparsons
Old Nov 23, 2009, 09:13 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
23g is probably without a battery, right?
UNGN is offline Find More Posts by UNGN
Old Nov 23, 2009, 09:22 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Plan on 7g min for the Motor/Gearbox/Prop (the motor itself is 5g)
4g for the brick
3g for the Aileron servo/bellcrank, linkage
4g (if you use 2 servos)
5g for the battery (the lighter batteries have a tough time with the 8mm motor)
1g for the linkages
or 20g with 1 Aileron Servo
21g with 2 Aileron Servos
Old Nov 23, 2009, 09:27 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
http://www.rcgroups.com/forums/showthread.php?t=1095931
boredom.is.me is offline Find More Posts by boredom.is.me
Old Nov 23, 2009, 10:45 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Based on those weights, I'll be coming in around 30g still.
23g without battery right? That's still a light airframe, Mine is a bit of a pig I think. I bet I could get away with 1mm foam for most of it.
We'll see how this one comes out first though.
Has anyone tried the biowire servos?
http://www.hobbyking.com/hobbycity/s...idProduct=6405
Looks like a really light alternative to a linear servo + bellcrank! Not sure it has the oomph though, or enough travel?
Old Nov 23, 2009, 03:22 PM
the riot is offline
lancaster county pa
Joined Dec 2008
nope with a battery
(secret, thin foam safe ca)
Old Nov 23, 2009, 03:27 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ How the hell did you get your airframe that light??
2g for the airframe, with wheels? That, or the weights above for components are way off, but they seem accurate to me?
Mine was 9g unassembled, 11g with carbon, glue and hinges(scotch tape).
Old Nov 23, 2009, 05:14 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
nope with a battery
The absolute lightest the parts shown in the picture are
3.4g for ailerons
3.8g For AR6400
1.6g for SU26 prop
1.3g for gearbox
4.9g for motor
3.6g for a 110 battery
0.4g for landing gear
= 19.0g with no airframe in that number. You are saying your hinged airframe with all of that visible CF weighs 4.0g.
Foam safe CA or not, I'd say your scale is tad off.
Old Nov 23, 2009, 11:24 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
here's mine i just finished..
30g finished weight with 130mah common sense lipo:
invertmast is offline Find More Posts by invertmast
Old Nov 24, 2009, 11:31 AM
wim5150 is offline
Find More Posts by wim5150
illinois
Joined Jun 2001
Boredom, what plans did you use for your F15 in the Post your 4 (or more) channel micros here thread ? Very nice model.
wim5150 is offline Find More Posts by wim5150
Old Nov 24, 2009, 12:12 PM
skootertrash74 is offline
Find More Posts by skootertrash74
United States, IN, Indianapolis
Joined Nov 2008
here is my design. yak sp55m. 17"ws, 3mm depron, p51 guts, 31gr weight minus battery. flies awesome, hovers but no punch out. more designs to come. i have some 1 and 2mm depron and some 3mm epp coming tommorow. i also have a hobby city micro yak54 with sukhoi guts in it. it flies well also.
skootertrash74 is offline Find More Posts by skootertrash74
Old Nov 25, 2009, 11:14 AM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
How did you print these plans to get it this size? I have an ar6400 and wing servo from the UMSu-26 that I have lying around.
cactus is offline Find More Posts by cactus
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
