I have put up with this long enough, so I started looking around and found out that we are not the only ones with this issue. There is supposed to be a firmware update, but I have not found any sign of someone having access to the update, and have not found any sign of anyone having this issue resolved. This thread covers the issue. Starting at page 82, Ren discusses a firmware update. http://fpvlab.com/forums/showthread....pan-DVR/page87 |
Hobbykings new:
SD DVR High Resolution Digital Video Recorder for FPV
Test recording off TV |
Recording off TV gives you really no idea at all how it'll perform in an FPV application.
A typical TV show or movie requires no more than 2-3Mbit/s even for action. This is because there's a lot of rules and conventions of filming that are friendly to digital video compression. Rarely does the camera pan and zoom, and roll all at the same time. Often only a portion of the frame has high detail, and the background is often out of focus. There's no static. Static is random and thus incompressible. A typical high motion FPV video breaks all of these rules. Every bit of the frame is in focus and may contain high detail and the whole view is panning, rolling, and zooming all at the same time, combined with static. Where a TV show may only need 2-3Mbit/s to be *perfect*, an FPV ground recording may require 7-15Mbit/s to really capture what you see in the goggles. Quality of the image is only one measure. The other big one we care about here is how well it records through high levels of static. Some recorders will go to blue/black screen on static. Some will pause the recording and resume when the image is good again. Some will just freeze up and lose the whole recording. The reason it's important is that if your plane goes down far away you will likely lose the video signal completely in the last few seconds, and it's important to be able to capture as many of the last moments as possible so you can see landmarks, and OSD data if available. If it stops recording, or freezes up and loses the recording as soon as there's any static, it's totally worthless. ian |
Latest blog entry: My 2012 FPV year in Review
Actually, can sometimes learn more from crackling and poppy signal. Every time
there's a burst of static, you'll see it hit the limits of compression, in the form of blurry areas, or boxy compression artifacts. Some recorders recover from that almost instantly, some take a second or two before the next key frame and the detail comes back. High motion, low flying, is the best way to test it. Watch the ground detail. If you can see it maintained well off into the distance, you're doing well. If ground detail all just blurs together, then inadequate bitrate. Here's some examples of high detail, high motion ground recordings. FPV Japan DVR
Lawmate PV-1000
Had to upsample both to HD resolutions just so YouTube would give em a higher max bitrate. ian |
OK Ian, I got busy for you
t Here you go And I think you'll find the test was 'intensive' with regards to low fast and crackly ![]() I can confirm though that it does record static, watched a minute of it just to make sure.. please don't ask me to watch anymore of it though, a bit to 'Gitmo' for my liking. WO |
What is your opinion of the DVR after seeing this video. how does it compare in the sub $150 price range? I value your opinion very highly. |
The video (downloaded from Vimeo) looks fine. I couldn't offer any more opinion than that, without having
one in hand. How reliable and easy it is to use in the field is a big part of the equation. For instance, my tricopter crashed the other day flying in the snow, and the only possible way I could find it was with the immediate use of my DVR to watch the last few seconds of the flight. Is why I won't use one without a screen and usually without all rec/play/menu/nav buttons on the device itself. ian |
I've been running the FPV1000 from ReadymadeRC for a bit now and I'm pretty happy with the quality of the video.
It has some firmware issues with issues like the order you power everything on, but if you do everything right - it just works. I have run into issues where if you leave it recording static for too long the file gets corrupted, so it's important to shut it down once you've completed your flight. All in all I'm happy with it especially at a $115 price point. I didn't have a chance to clear out my OSD before our blizzard meet - so every conceivable option is turned on. I've since gone in and cleared out 60% of the indicators.
| Thread Tools | |
| Discussion Which portable video recording device? | al_b | Video Piloting (FPV/RPV) | 6 | Feb 28, 2007 11:03 PM |
| Discussion Recycle any battery or portable electronic device. | willhaney | Batteries and Chargers | 3 | Dec 21, 2006 03:27 PM |
| Onboard Recording / Telemetry Device - Suggestions? | LoopZilla | Micro Helis | 27 | Jun 01, 2005 10:23 PM |
| Throttle usage recording device | CloudyBright | DIY Electronics | 3 | Dec 16, 2004 07:51 PM |
| Interesting Portable Photo Storage Device | Randy Due | Aerial Photography | 12 | Apr 11, 2004 03:29 AM |
