Old Oct 11, 2012, 09:59 AM
trexpilot is offline
Find More Posts by trexpilot
trexpilot's Avatar
Australia, WA, Perth
Joined Feb 2006
I have Pv700 from bevrc and happy with it
Much simpler to Rec my fpv flights, its light enough to fit in my top pocket with only one cable connected to my predator
So when I fly my quad fpv all I need for ground station is only goggle and pocket dvr
trexpilot is offline Find More Posts by trexpilot
Old Oct 12, 2012, 02:35 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Here is videolink recorded with F20 CAR DVR (720p CMOS +video-in)
flew really small wing with two cameras
F20 videolink record (1 min 53 sec)
fmkit is offline Find More Posts by fmkit
Old Oct 15, 2012, 09:08 AM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
http://www.youtube.com/watch?v=aX2WhlmlHU0
Is this onboard recording?
GTiDonavan is offline Find More Posts by GTiDonavan
Old Oct 15, 2012, 09:18 AM
BriGuy82 is offline
Find More Posts by BriGuy82
SemperFi!
BriGuy82's Avatar
United States, TX, Texarkana
Joined May 2012
The DV02 from FoxtechFPV is back in stock! Going fast to! Started with 36 units on Saturday..
FOXTechFPV
BriGuy82 is offline Find More Posts by BriGuy82
Old Oct 15, 2012, 12:17 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
the little plane can't take anymore weyght, the video was recorded on ground while connected to 2.4ghz video reseiver, I edited the video so one can see lots of static and dynamic scenes - the recorder doesn't skip frames and can record static forever if set to recycle old files.
Old Oct 15, 2012, 06:33 PM
soulreaper is offline
Find More Posts by soulreaper
Joined Nov 2005
how did you get the dvr to record from the ccd camera. How did you hook the ccd camera into the dvr?
soulreaper is offline Find More Posts by soulreaper
Old Oct 16, 2012, 07:37 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
The DVR has AV-in 3.5mm plug, mid-ring is video and tip is +5v that I don't use cause my camera powered by 12v
till today I was using F20 as GS (videolink)recorder
couple hours ago flew the DVR and it appear to have color-hunting problem, sometimes too much green:
sf f20 (0 min 47 sec)
Old Oct 16, 2012, 10:34 PM
Pattaya01 is offline
Find More Posts by Pattaya01
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
Fantastic discovery
I have been trying many different recording devices, none was really satisfactory.
I found this device: Gadmei USB TV Box, UTV332E
Link: http://www.gadmei.com/en/product.aspx?bigclassid=2
I found it in Pattaya Thailand, Tuckom for around 1000 Baht (30 USD)
Absolutely perfect !!!!
1) Installation of the software one click
2) Records in plain MPEG format
3) Records through noise, even if you switch off your receiver, keeps on recording
4) Bundled software extremely easy to use, no bugs or hick-ups (just need to set to PAL)
I made a recording with the on-board recording as overlay.
16_Oct_2012_NaJomtien (8 min 0 sec)
My setup: FPV Raptor 2m, video TX 400mW, Video RX diversity receiver from HK, PC Samsung notebook N120.
Pattaya01 is offline Find More Posts by Pattaya01
Old Oct 17, 2012, 03:10 AM
Martin7182 is online now
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
I'm sorry Pattaya01, but this is not a recording device but a tuning device.
If you need to lug along your laptop then it's not that attractive anymore.
But if you're happy with it then that's nice.
Martin
Martin7182 is online now Find More Posts by Martin7182
Old Oct 19, 2012, 09:33 AM
Joined Sep 2012
Martin
What's your point????
I think this threat is to share information about FPV recording, right? This device records, it has a video in, USB out, and yes, it also has TV tuning, so what???
It works like a charm, so I wanted to share this information. Are you the moderator?
Old Oct 19, 2012, 01:11 PM
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Pattaya01, didn't want to upset you, my apologies.
As far as I can see this device doesn't record anything but converts a composite signal into a video stream for your laptop. It cannot be used without a laptop so therefore it's not very attractive for a lot of people. I think most people want something simple, reliable and preferably cheap, all of which a laptop (with Windows?) is not.
But like I said, if you're happy with it then there's nothing wrong. If you have a laptop already and the combo proves to be very reliable then that's perfectly fine. But if you don't own a laptop, I certainly wouldn't purchase one, but would go for an autonomous $100 - $200 recorder. Without doubt your video quality is very good. I guess only the more expensive recorders do reach that quality.
Concerning the live viewing, I wouldn't put any electronics between the vrx and the lcd-screen or goggles. For safety and also to prevent possible lag.
Martin
Old Oct 20, 2012, 12:58 PM
Greg Covey is online now
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
BriGuy82,
Thanks for the post on the DV02 from FoxtechFPV! It appears to be the same device as the BEVRC PV700 high quality digital video recorder.
They were down to 17 units so I ordered one. What cable are people using to plug between the DV02 and the Predator V2 goggles?
Greg Covey is online now Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Oct 20, 2012, 04:55 PM
BriGuy82 is offline
SemperFi!
BriGuy82's Avatar
Joined May 2012
No problemo! I actually ordered one of these to go with it. I sent Foxtech an email asking about internals on that cable in case the 3.5mm jack was not compatible with my FatSharks, so it looks like he added a wiring diagram to the jack end in the picture, Also got a couple Female to Female adapters for my A/V cables in case the cables weren't compatible with my Dominators.
Originally Posted by Greg Covey View Post
BriGuy82,
Old Oct 20, 2012, 05:14 PM
Rochester, NY, USA
Joined Aug 2000
Sweet, thanks!
The two cables look like they will mate nicely.
The AV IN for DV02 is a 2.5mm 4-pin jack (left image)
The AV IN/OUT on the FatShark is a 3.5mm 4-pin jack (right image)
Old Oct 20, 2012, 07:16 PM
BriGuy82 is offline
SemperFi!
BriGuy82's Avatar
Joined May 2012
Sweet, thanks!
Ok so I know yellow is video, left and right must be audio then?
Discussion Which portable video recording device? al_b FPV Talk 6 Feb 28, 2007 11:03 PM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 03:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 10:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 07:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 03:29 AM
