Old Mar 31, 2011, 11:37 AM
Carlos230023 is online now
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
You can go all the way up to a class 10 card (10Mb/sec). That's what I'm putting in my Go Pro.
CJ
Carlos230023 is online now Find More Posts by Carlos230023
Old Apr 01, 2011, 02:07 AM
Pisces is offline
Find More Posts by Pisces
The Dreamer
Pisces's Avatar
Sydney, Australia
Joined Dec 2010
Hi Group,
I have received my EMPREX BPR101. Installed a temporary 2.5" 80GB IDE HD. Had to re-format the HD from NTFS to FAT32. The emprex will only record to a HD with FAT32 file system.
I am using a Cyclops CEOSD. The OSD text fits on the display and is recorded all ok. That is the OSD is not clipped. Video quality in loop AV-IN to AV-OUT and also the recorded video is about the same quality. Quality is acceptable but not perfect. There is some streaking and loss of fine detail on the VDU screen. Large contrast transitions eg video black level to white level in the picture leave a faint streak on the display. PAL colours are good in both the recorded and feed thru mode.
I am planning to changeout the 80GB HD and use a IDE/CF adapter and 8GB CF card. These CF cards I understand are already compatible with IDE drive architecture and can be formatted to FAT32. The CF card have much lower power requirements from DC 5V compared to a conventional magnetic spinning HD. Also CF card is a lot more resistant to rough handling.
Any reports of successful recording when using a CF card would be appreciated.
Pisces is offline Find More Posts by Pisces
Old Apr 01, 2011, 04:17 AM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
That would be a cool solution.
IDE hard disks are expensive compared to their memory size.
Maybe i will use such a adapter:
http://cgi.ebay.at/Secure-Digital-44...item20b2df68db
or from DX:
http://www.dealextreme.com/p/sdhc-sd...-8gb-max-19737
I have more SD cards than CF cards.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old Apr 01, 2011, 05:06 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
I got one of these hds.
http://cgi.ebay.ie/ws/eBayISAPI.dll?...=STRK:MEWNX:IT
Good price and plenty big.
NDw is offline Find More Posts by NDw
Old Apr 01, 2011, 05:30 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
6.5GB? That'll store about 90 minutes of video.
Dunno what's with the obsession with trying to use SD cards and such.
Yes PATA is more expensive than SATA but that's just supply and demand.
A 2.5" PATA/IDE 160GB drive is a bit more than 50 bucks.
http://www.google.com/products/catal...d=0CFQQ8wIwAg#
And yes, all DVRs I know of, use FAT32.
ian
Daemon is online now Find More Posts by Daemon
Old Apr 01, 2011, 11:35 AM
Firefox675 is online now
Find More Posts by Firefox675
Firefox
Firefox675's Avatar
USA, KS
Joined Oct 2005
My interest in the SDHC card route is that the assembly should be much lighter to handle and should require less amps to operate.. Other than that a HD would be good.
Firefox675 is online now Find More Posts by Firefox675
Old Apr 01, 2011, 11:51 AM
Austria
Joined Sep 2007
I second that.
+i don't need 160GB
Old Apr 01, 2011, 01:57 PM
fransbr is offline
Find More Posts by fransbr
fransbr's Avatar
Netherland, Watergang
Joined May 2007
Emprex otg ide hdd
Originally Posted by lovegroove View Post
If enough people outside the UK wanted one, I could probably try to arrange a group buy of the Emprex units .
Hi Lovegrove,
I would be interested in one. (EMPREX OTG IDE HDD)
I live in the Netherlands, tell me what to do.
FransBr
fransbr is offline Find More Posts by fransbr
Old Apr 02, 2011, 11:38 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I have been doing a static test with my Emprex. It works OK and recording looks good, but I powered it with a 12 volt gelcell and used a spare ESC and the bec to get the 5 volt. The ESC got very hot in fact I could not hold it for too long.
What other simple way is there to reduce the 12 volt to 5 volt?
Flypoppa is offline Find More Posts by Flypoppa
Old Apr 02, 2011, 11:48 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Was that a switching BEC? I figure not right? If so, get a switching BEC. Hobbyking sells one pretty cheap, but any switching BEC should do.
Markus
markus123456 is offline Find More Posts by markus123456
Old Apr 02, 2011, 01:49 PM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Markus
No it was not. It was just a 20amp ESC and I used the Servo lead.
I did not know if a plain UBEC (Switching BEC?) would be the same.
I will try one Thanks.
Old Apr 02, 2011, 02:03 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I'm powering my VuPoint with an old brushed ESCs BEC. It runs on little power though and the BEC gets just a little warm. I'm sure that running a HDD on the Emprex certainly draws more current.
Vantasstic is online now Find More Posts by Vantasstic
Old Apr 02, 2011, 02:47 PM
Joined Jun 2007
most standalone UBEC's have an amp rating. and I think the emprex draws 2 amps. dont quote me on that and remember it depends on the HDD you put in there.
CJ
Old Apr 02, 2011, 03:05 PM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
CJ
So if you add about 0.5A (USB max) - 1A you are at the limits of an usual BEC, which probably is rated at 3A.
If you use a high number cells battery (3s or more) the BEC works even more. In this case try a 2s pack.
Be careful, because if the BEC is well done it could happen that it shut off for ovecharge (no more video ). If it is a bad one it will simply fry (no more BEC ).
Ric
chiloschista is offline Find More Posts by chiloschista
Old Apr 02, 2011, 04:25 PM
Joined Jun 2007
why are you adding amps? 2 amps full draw dude. A 3A Ubec will be plenty. 5A's are also readily available.
CJ
Discussion Which portable video recording device? al_b FPV Talk 6 Mar 01, 2007 12:03 AM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 04:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 11:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 08:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 04:29 AM
