Old Mar 24, 2011, 03:03 PM
bigtruck169 is offline
Find More Posts by bigtruck169
United States, NY, New York
Joined Dec 2009
amazing
bigtruck169 is offline Find More Posts by bigtruck169
Old Mar 24, 2011, 03:49 PM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Originally Posted by chiloschista View Post
Hi,
I just got my new PV500 ECO. Thanks boopidoo and Ian for finally stimulating me to buy this device.
I'm very satisfied with the great quality of all the components.
The remote is IR and not wired like boopidoo one.
Just to clarify, I have an IR-remote as well. The wired remote does only have one function which is to turns power on & start recording / stop recording & turns off power.
So, how much did you pay for it in the end?
boopidoo is offline Find More Posts by boopidoo
Old Mar 24, 2011, 03:57 PM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
oops, I exchanged it for a microphone
I still have to study it.
$335.-
Ric
chiloschista is offline Find More Posts by chiloschista
Old Mar 24, 2011, 06:29 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
So a final test of the £9.99 Emprex.
I couldn't find a DVD to use as a good source so I downloaded Ian's gopro fpv video and recorded that onto the Emprex. The bitrate was very low, perhaps the white of the video comresses very well. But it looks good to me.
Emprex test HQ source (1 min 0 sec)
NDw is offline Find More Posts by NDw
Old Mar 24, 2011, 11:07 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Using an HD source or recording off TV will always result in a much higher
quality at a lower bitrate because there's no wireless transmission noise. Noise
is incompressible, so the real challenge for any ground based recorder is to capture
the noise (which just eats up bitrate) while retaining real image detail
in the remaining bitrate. Some recorders will just increase the bitrate as
far as needed to capture everything. Others have an effective cap, so
the ground details just start to blur together and such.
As for your transcoding above. Something's wrong there. It's stuttering pretty
badly. Dunno if it's the recorder (doubt it, since we've seen better), or whatever you
used to play my original (which is smooth), but it looks like it's playing at
about 20fps, with regular long pauses.
The only reliable way to test any ground recorder is to actually record flights
transmitted over the air. Those that picked up that batch of Lawmate PV500CK's
(old generation recorders) learned that the hard way.
ian
Daemon is offline Find More Posts by Daemon
Old Mar 25, 2011, 05:51 AM
NDw is offline
NDw
NDw
Joined Aug 2010
Alright I might try your SD recording, recorded onto the emprex to eliminate my camera as yours seems to give very crisp images close to the ground.
With regard to the transcoding stuttering, yes I was using an old DVD player as it had rca outputs. I think the heads need to be cleaned.
Old Mar 25, 2011, 06:31 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I have my emprex all wired up now and ready to record an actual FPV flight, but as usual, the weather isn't playing ball, with strong winds and rain forecast for the weekend. If the wind calms down a bit later, I will try to get out and do some flying, even if it's just a non-FPV flight but with FPV recording.
lovegroove is offline Find More Posts by lovegroove
Old Mar 25, 2011, 10:48 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
well, doesn't look like it's going to happen today. Had 5 mins of no wind and I started to get my stuff ready to go flying, but it started raining before I got out the front door.
Old Mar 25, 2011, 10:55 AM
Firefox675 is offline
Find More Posts by Firefox675
Firefox
Firefox675's Avatar
USA, KS
Joined Oct 2005
Originally Posted by NDw View Post
The 9.99 Emprex is a solid reliable recorder. Nvr cuts out on static. One touch(well you have to turn it on first) record. But only average record quality.
If you want singificantly better record quality then I think the lawmates are prob the best option, as I imagine if you damage it accidently they'll have warrantly cover ect.
Anyone sell these in the US for a reasonable price.
Firefox675 is offline Find More Posts by Firefox675
Old Mar 27, 2011, 04:02 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
So today was my first test flight with the VuPoint recorder. I thought I had everything set up right, but when I got home I only had audio...no video recorded. Bummer. I grounded tested the setup with feed through and it recorded okay. I don't know what I did wrong at the field, but I didn't have it setup in feed through so had no idea what it was/wasn't doing. I guess I'll hook it up to my backup 7" LCD so I can verify it's recording. I'm not to worried about lower quality video on the pass through as it'll be on the backup display anyway.
Vantasstic is offline Find More Posts by Vantasstic
Old Mar 27, 2011, 04:13 PM
Crist Rigotti is online now
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
I had to go through several ground sessions before I got it to record reliably. Now, all I do is hit the record button. BTW, I reformated my card and that seemed to help a lot. Also be sure the AV in connector in pushed all the way in. Are you using the cables that came with the VuPont? I am because they are different than some of the others. Could explain the audio only recording.
Crist Rigotti is online now Find More Posts by Crist Rigotti
Old Mar 27, 2011, 04:44 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Yes, I'm using the VuPoint cables. I have no idea why it didn't record video...I'm pretty sure everything was plugged in okay. Who knows...a real mystery. Nothing lost as it was just a 'show and tell' flight. It could have turned out bad though. You see, I forgot to turn on and start the VuPoint until after I was already flying. No sweat, I'm on a 'close in' waypoint mission so the AP has things handled. I move to turn on the recorder...LEDs to dim to tell if it's on when outside (I'll fix that Crist), then start the REC and try to see if the REC LED is flashing. Once sorted out I looked back in my display and my plane was on a slow altitude decline and was just above 100 feet at ~1/2 mile out...and of course I didn't know where it was by LOS. No panic though...simple fix with a little up elevator for a safer altitude. I could have missed recording a nice crash though had things gone worse. A later review of my OSD settings showed I, somehow, managed to turn off my Rate Of Climb Gain, thus, essentially, turning off the APs elevator control authority. Dumb mistake...don't know how I managed to do that. Anyway. I had the recorder working fine with the FPV Rx and video splitter in pass-through mode at home. I'll keep it in pass-through on my backup display just to verify everything's working.
Old Mar 27, 2011, 04:45 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Just another input on the VuPoint recorder. When powering it up it seems I have to hold the power button a few seconds and listen for a little 'electronic click', then wait a little longer before the power light comes on. Same thing with shutting down. It certainly isn't an instant on/off device. Once more familiar with it and turning it on BEFORE I launch I don't think it'll be any issue.
Old Mar 27, 2011, 05:26 PM
Joined Mar 2008
Same thing here. Do the LED mod. So much easier.
Old Mar 27, 2011, 06:41 PM
anestetico is offline
Find More Posts by anestetico
Brazil
Joined May 2009
My JXD 990 stopped recording, it records to an inexistent file, I have 2 old broken movies on it, tried to reset, format and use esternal memory card but it won't record nothing
does the emprex exist only for uk customers?
anestetico is offline Find More Posts by anestetico
Discussion Which portable video recording device? al_b FPV Talk 6 Feb 28, 2007 11:03 PM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 03:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 10:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 07:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 03:29 AM
