Old May 28, 2010, 11:36 AM
Bandarra is offline
Find More Posts by Bandarra
Bandarra's Avatar
UK, South Yorkshire, Sheffield
Joined May 2009
Don't know if it is in the "list" yet or not but I recently got a Vivitar dmd-p20 and have only good things to say about it.
Bandarra is offline Find More Posts by Bandarra
Old May 29, 2010, 12:00 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Received my Vosonic VP6060 flash recorder today
http://www.vosonic.com/product.php?P...&kind=1&id_1=8
It's not too shabby (especially as it cost me less than 30GBP).
Applied the latest firmware and tested it with a Sony 540TVL camera
Single button press to start or stop recording.
Output is viewable whilst recording input.
768 x 576
25 FPS
4.3 mbits/sec
640 x 480
25 FPS
3.6 mbits/sec
Results are the same on either a high speed SD or CF card.
Looks quite good in the goggles and on screen after recording.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old May 29, 2010, 09:34 PM
garris2 is offline
Find More Posts by garris2
Melbourne, Australia
Hi Daemon, I'd like to get your opionion of these 2 recorders for suitability as a ground based recorder for FPV.
I think the 2210 is for ATSC TV and the 2230 is DVT-B. The 2210 has Analogue recording in HQ mode of 69.2MB/min 720*480, 9364Kbps.
http://www.tvix.co.kr/ENG/products/PVRR2210.aspx
http://www.tvix.co.kr/ENG/products/PVRR2230.aspx
cheers Geoff
garris2 is offline Find More Posts by garris2
Old May 30, 2010, 01:40 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Sounds like nice specs, particularly the bitrate, but to be suitable for ground
based recording it needs to be able to record through static, and there's
no way to know that until someone has one in hand.
ian
Daemon is online now Find More Posts by Daemon
Old May 30, 2010, 09:41 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Recorded a flight with the PV-1000 today. Using its 1280x960 setting, it appears
to range between 9-14Mbit/s. Averages out to about 13 minutes per Gigabyte.
It offers the sharpest image I've ever seen from a digital recorder and I'm quite
impressed. I can't wait to try it with a higher resolution camera than the 420tvl
RCV922. I can't compare it to MiniDV quality, as I stopped using that years
ago (just too inconvenient).
I'll try to post up some raw sample clips, but because it uses ASF file format, slicing up
the raw files is a little tricky.
I had a couple different passengers on my second set of goggles plugged into the AV
output of the PV-1000 and they were super impressed with the quality of the pass
through signal. It was also cool after the flight to just replay segments of the flight
back to someone else, also using the passenger goggles, while I could look at the big
bright high res LCD screen, and explain to them what they were seeing ("and we got
really close that hangglider in about 1 minute... "). That said, there seemed
to be an subtle banding effect on the replayed signal, which I suspect has something
to do with it having to downsample back from 1280x960 oversampled recording
back to an analog NTSC signal for the goggles to understand. I was worried that
it might be in the recording, but it's totally clean on my computer.
ian
Old May 30, 2010, 10:04 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Ian, that sounds real good.
Does it pass your set requirements?
* One touch record
* Record through static
$599 is a bit steep though?
Cralis is offline Find More Posts by Cralis
Old May 30, 2010, 10:14 PM
ColorSky is offline
Find More Posts by ColorSky
Joined Aug 2009
I have ordered a piano HDD-DVR from BEVRC, the same with nghobbies sells.
I checked the video on vimeo, looks good.
ColorSky is offline Find More Posts by ColorSky
Old May 30, 2010, 10:19 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
* One touch record
As I described in my earlier review, yes and yes.
I picked it up for $500, although I believe the place I ordered it from has
since raised the price.
ian
Old May 30, 2010, 10:20 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I think it has been confirmed that the Piano DVR does not record reliably through static.
ian
Old May 30, 2010, 11:35 PM
AgentCow007 is offline
Find More Posts by AgentCow007
USA, CA, Los Angeles
Joined Sep 2004
I just tried recording a test video with my V-Mate/ground station, but the video flickers up and down... it's just the recording though, because it's fine in my goggles. I tried using deshaker 5 times with different settings but it just makes it worse. Any suggestions?
AgentCow007 is offline Find More Posts by AgentCow007
Old May 31, 2010, 12:49 AM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Just bought this unit.
I know well enough not expect HD quality.
Seller dispatched within 2 days.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=120513671085
borneobear is offline Find More Posts by borneobear
Old May 31, 2010, 04:14 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Here's a raw 1 minute clip from the Lawmate PV-1000
http://thud.us/videos/rc/lawmate-pv1...e-1280x960.asf (right click - save as)
Play it in VLC.
In the process of cutting it out of the original clip without re-encoding it seems to
have lost the ability to seek properly, but the original files are fine.
BTW, the constant hiss, is because I put the microphone in too much airflow.
And here's a longer edited vid I posted on Vimeo, downsampled to 640x480 and only 4Mbit/s
before uploading.
FPV Soaring at Zion - new Lawmate PV-1000 recorder (8 min 30 sec)
It's a little hard to judge quality based on Vimeo vids, but generally the motion is smoother
and the fine details (which my mountain has a lot of) are more crisp, particularly
through high motion scenes (which I also have a lot of, due to rapid camera
movements and turbulence).
I think the real limit of detail here is actually the camera, which is only 420TVL.
I'm looking forward to trying it with my VSN505 (or VSN500) with its 550 TVL and better colors.
Old Jun 07, 2010, 02:26 PM
Moosthegoose is offline
Find More Posts by Moosthegoose
Joined Aug 2009
Hi
I have bought the same DVR, for my laptop is taking up to much space and is a hassel carrying around..... well i tried it out, but i was dissapointed by the low video quality it gave me. and when i start recording, the piqture will turn blur after a few seconds ......I dont have any picturequality problems on my laptop, so back to the lap top again
Do you have the same quality problem?
Moosthegoose is offline Find More Posts by Moosthegoose
Old Jun 07, 2010, 10:06 PM
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Originally Posted by Moosthegoose View Post
Hi
Damn it... looks like we bought crap.
Mine hasn't arrived yet, but based on your input I've toned down my expectations to rock bottom.
Buy cheap, buy twice?
BB
Old Jun 08, 2010, 01:00 AM
garris2 is offline
Mini mobile DVR
This item looks interesting...
NEW !! MINI Mobile SD DVR Module MP-VRM100
from http://www.misumi.com.tw/
under the DVR category.
Might be the onboard recorder SD card recorder we are looking for.
Geoff
Discussion Which portable video recording device? al_b FPV Talk 6 Feb 28, 2007 11:03 PM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 03:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 10:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 07:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 03:29 AM
