Old Mar 16, 2010, 06:01 AM
seaQ is offline
Find More Posts by seaQ
Sweden
Joined Oct 2009
BlueAngel, do you need an HDD or can you record on to an SD card without hdd plugged in?
seaQ is offline Find More Posts by seaQ
Old Mar 16, 2010, 06:29 AM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
I thought that i read somewhere here in the forum, that it works.
But can't confirm it, because i never tested it.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old Mar 16, 2010, 07:39 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
It llooks very similar internally to my k2 digistor I bought last year. Quite like it, but doesn't compare to the minidv.
Can confirm that one records through static, can use SD card instead of HDD. +5v supply, Two buttons to record - one to power up, second to record (from remote if its a problem...!!)
BlueAngel - what bitrate do you get on the highest quality recording?? I wonder if that is the same
Shikra is offline Find More Posts by Shikra
Old Mar 16, 2010, 07:46 AM
Austria
Joined Sep 2007
BR3002: ~6800-7600kbps
new one: ~4500-4700kbps
Old Mar 16, 2010, 09:10 AM
Shikra is offline
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Thans BlueAngel - I think it's the same unit as mine, but with a different case. We are talking about the white one (http://www.okbuynow.com/25-inch-sata...qpi0jj1bi299i3)
I posted a review of it some time back. If anyone is interested, here is the detail...
I'd give it 7/10 compared to 10/10 for a minidv for quality
For use on plane (board removed)....
The board can be easily removed from the case.
Can be used on plane with just SD card - yes !!
Weight - 40g for board with SD card. !!
Board Dimensions - 131*75* (5 mm typical, 12mm max)
Power supply - 5v supply required
Could be used with SD card on plane or solid state device with SATA interface
If weight is less of an issue, could be used cased (135*80*20mm).
For use on the ground....
Takes standard 2.5" SATA or SD card
Metal case - able to withstand reasonable punishment
Supplied with neoprene edge protector providing further protection
Recording....
Continues recording with static - yes. Tested 10 secs
Continues recording with no input - yes. Tested 10 secs (Requires input signal to start)
Can record without screen attached - yes. Using IR remote. Requires valid signal to start.
Can record without need for PC - yes.
Can record and output at same time - yes.
No options to save in different formats or change recording detail.
Led to show when recording.
Recorded test file data from PAL capture...
Data Rate: 4.5-5Mbps
XVID codec in AVI container.
2GB = 1 hour recorded video
Misc...
Can plug straight into TV/panel with RCA to playback recorded flights
2 sets audio cables provided. 3.5mm 4 pin stereo round to 3*RCA
Comes with mains 5v adapter. Common 5 pin round center positive
Can also be used as USB storage/media player/photo viewer etc.
Recording steps without a connected monitor...
Power up the unit by pressing main button
Wait 5 secs to complete startup process
Press the record button on the remote
Verify recording led is on
Press Exit on the remote to stop or Rec to start again
Issues found:
1 It will not record from my mono 600tvl cam. Suspect the cam is out of tolerances though. All my other cams 420-550TVL work)
2 I couldn't directly read file from Adobe CS4. Sony Vegas is fine as is avidemux and virtualdub. Potentially just a codec issue.
Old Mar 16, 2010, 09:17 AM
Thumb_number is offline
Find More Posts by Thumb_number
I think my wheels fell off.
Thumb_number's Avatar
Perth
Joined Oct 2009
Originally Posted by Thumb_number View Post
Hope so! I jumped.
Fingers crossed x
Fingers still crossed! Hope it's => than my Apitek DV-M2.
Sigh
Thumb_number is offline Find More Posts by Thumb_number
Old Mar 18, 2010, 12:09 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Originally Posted by galaxiex View Post
I have two BR3002 now... bought a second one from OnVon....before they sold out...
Both with 100G drives, both work just fine....
I am worried that maybe the 250Gb drive I have IS the issue. Could you maybe tell me what make of HDDs you guys are using successfully, and their size? Maybe a model number?
Cralis is offline Find More Posts by Cralis
Old Mar 18, 2010, 12:35 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That's easy to test. Simply remove the drive, plug in the A/V out and boot it up.
It will boot normally without a drive. If you still see nothing, then it's broken.
ian
Daemon is offline Find More Posts by Daemon
Old Mar 18, 2010, 01:44 AM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Mine's a new Seagate.
etman is offline Find More Posts by etman
Old Mar 18, 2010, 02:37 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
ian
Tried, and failed.. Busy with the seller trying to resolve.
Old Mar 18, 2010, 06:57 AM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Feb 2007
Does anyone with the e-Bay recorder know if having this inline with a monitor will help prevent blue screens? I would think that since the signal from the receiver is being recorded and is then being output to whatever you connect to it, it would have a constant signal to keep it from going blue. That is assuming the recorder can output in real-time. If that's the case, then I would definitely like to pick one up as I could just use any sort of DVD player or small LCD screen. Can anyone confirm this?
healthyfatboy is offline Find More Posts by healthyfatboy
Old Mar 18, 2010, 07:06 AM
Austria
Joined Sep 2007
Yes, it prevents the LCD for going blue screen.
i am using the ebay recorder (new one) and a LCD from ebay in my groundstation:
http://www.rcgroups.com/forums/showp...1&postcount=41
Old Mar 18, 2010, 08:16 AM
Joined Feb 2007
Excellent. I'll probably pick one up soon then as I was worried about the blue screen. I would like goggles at some point but that will be after a while so now that the blue screen issue can be rectified with this recorder, a portable DVD player will be in my near future as well. Thanks!
Old Mar 27, 2010, 02:32 PM
MDreamer is offline
Find More Posts by MDreamer
"Here birdy birdy birdy..."
MDreamer's Avatar
Israel
Joined Sep 2006
Originally Posted by SoMoney View Post
KS638
-No verification if these can Record and view at the same time through goggles yet.
Hard to find but can be had off eBay between $99-130US. It uses the same video encoder chip (Zoran) as Nikon L18 camera. Examples show good quality 640x480 even at low bitrate.
-the built-in 2.4GHz receiver/antenna useless past 300m
-beware of similar looking KS639 which is worthless.
Can record and view at the same time but only on the LCD OR on the video out.. only you can see or the person next to you at the same time.
MDreamer is offline Find More Posts by MDreamer
Old Apr 12, 2010, 07:38 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
An update from me and my faulty BR3002... Recorder posted back, took two weeks for them to say they have it... Been 8 days since then, and they are 'still testing'.
Discussion Which portable video recording device? al_b FPV Talk 6 Mar 01, 2007 12:03 AM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 04:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 11:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 08:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 04:29 AM
