Old Mar 13, 2010, 07:56 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Is it just the display? If you turn it on, let it go to solid green, and then
hit the REC button will it start recording normally (rec light green, drive light flashing)?
I don't know why all you guys are having so much trouble. My two units work fine.
I do wonder if you're perhaps using big drives with a power demand that's higher
than it can handle. It's only rated to 160GB, and I believe that to be a limit of
the power handling, not the actual capacity.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 13, 2010, 07:59 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Yeah, checked that - thanks.
I notice that when I power, the red light goes on. I press Power, and the green light flashes for around 5 seconds, then goes solid. But I see no picture, and the HDD light doesn't flash. I can hear the HDD spin up, but - nothing.
It's back in the box, and I'll rap to their support tomorrow. Damn - gonna cost an arm and a leg to send to them. Quite depressed.
Cralis is offline Find More Posts by Cralis
Old Mar 13, 2010, 08:00 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
ian
Thanks Ian - will try that. But I'm sure the red light flashed a few times when you power on, while the thing boots up. Nothing is happening at the moment.
My HDD is pretty small...
Originally Posted by Cralis View Post
I got a new 250gb Seagare for my BR...
Mmm... OK, not small enough, it seems. Surely that's not the problem? Does a 250Gb use more juice than a 160?
Old Mar 13, 2010, 08:03 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
I have two BR3002 now... bought a second one from OnVon....before they sold out...
Both with 100G drives, both work just fine....
galaxiex is offline Find More Posts by galaxiex
Old Mar 14, 2010, 02:19 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Oh no...
I plugged my new BR3002 into my GS, and it's been 100% fine, up until now.
Put power, red light flashes, then goes red. As expected. I then press Power, and the disk spins up, green light flashes for a while, then goes solid. No picture... Just blank..
Plugged into the PC via USB, and all is good. USB detected, and I can see files. But on my GS< I get no piture on the video Out.
Anyone have a clue?
I had the same problem and it was the av out plug not pushed fully home. Its gotta be all the way in. Mine was out by only about 2mm. Give it a good shove and try again
What happens when you use the 240V adaptor?
ommadawn is offline Find More Posts by ommadawn
Old Mar 14, 2010, 06:32 PM
snoopy is offline
Find More Posts by snoopy
Microbursts hurt.
snoopy's Avatar
United States, MD, Mt Airy
Joined Jun 2005
Hi Ian,
Do you know if you could power the MPVR+CB/DV5800 off USB instead from using my GS power and record? It looks like from specs it may be possible, it says: "Power Source, 8210 850 mAh Li-Ion Rechargeable Battery, USB Port when Plugged into PC."
I'll hop over to Target, see if any are on sale.
I'm assuming that USB is just 5VDC, and I could use a spare UBEC I have?
Thanks.
The MPVR+CB (aka DV5800) is still pretty solid bang for the buck although you
should factor in the cost of a spare larger battery or two.
ian
snoopy is offline Find More Posts by snoopy
Old Mar 14, 2010, 06:53 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
I was hoping it was the AV cables, but no luck. Same issue. They are flush in. Also, with the power supply plugged in - same issue. If I recall correctly, when you power on, the HDD light flashes a bit right? Mine doesn't flash at all...
Old Mar 15, 2010, 02:37 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by jknust View Post
Hi Ian,
Thanks.
Yes I'm sure you can power it via USB port at 5V.
Target doesn't stock them in-store any more, so the online price is what it is.
ian
Old Mar 15, 2010, 02:39 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Normally when it's powered, but off, the power light is solid red.
When you press the power button, the green light normally flashes
green for several seconds, simultaneous to the HDD light flashing red a few
seconds, and then the HDD light goes out, and the power light goes solid green.
From there, if you hit REC (and it has a valid AV input) the REC light goes green
and the HDD light flickers red.
ian
Old Mar 15, 2010, 02:57 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks Ian.
In standby, I have solid red, as you say. I press the Power button, and the green light flashes, but no red light activity... Then the green light goes solid.
On the screen, nothing happens. Just black.
When I connect it to my laptop (USB only), it spins up, and I get the device, and can copy files. It's just when I power it normally and have the AV cables connected.
Old Mar 15, 2010, 03:35 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
And as I asked earlier. If you plug in a valid A/V input and then hit
REC button, what happens? Not hearing any of the weird drive chirping sounds?
ian
Old Mar 15, 2010, 04:32 AM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
Why are you looking for the "old" BR3002, when there is since 1 year a better one on the market:
http://cgi.ebay.at/ws/eBayISAPI.dll?...m=220566328098
http://www.okbuynow.com/25-inch-sata...qpi0jj1bi299i3
has more recording resolution: 720x576
and has a better video codec implementation
so smaller files than the older one, at better quality.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old Mar 15, 2010, 04:42 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
ian
Hi Ian.
No sounds... I can hear the disk spin up if I put my ear to the device, but no lights indicating it's doing anything.
I quickly made a video:
BR3002 not working well (1 min 32 sec)
It's not easy plugging things in with one hand!
Any clues there?
Old Mar 15, 2010, 09:25 AM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Is it guaranteed to record through static and video dropouts?
That is the biggest must have factor for choosing the BR 3002
Old Mar 15, 2010, 09:29 AM
Austria
Joined Sep 2007
Yes, it does.
I had the BR 3002 and now the newer one i linked above.
I would not recommend the BR3002 anymore. Buy the newer one if you want to buy such a recorder.
Discussion Which portable video recording device? al_b FPV Talk 6 Mar 01, 2007 12:03 AM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 04:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 11:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 08:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 04:29 AM
