Old Jun 06, 2012, 03:20 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
It seems a bit bulky any heavy, can it stripped down? I wonder if the screen and internal camera can be easily detachable.
iskess is offline Find More Posts by iskess
Old Jun 06, 2012, 04:00 PM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
I've converted tens of brand name still cameras and no name car dvrs for onboard recording, it always comes to 30-40gram once powered by ubec and case/LCD removed. When I shop for dvr I look for one that doesn't use touchscreen and no buttons on LCD panel so it can be removed completely..
I'm sure this DVR can be reduced down to 30g and av-in Y-cable connected to normal CCD cam ,TX and the DVR. would be awesome to record rear view in case some birds decide to attack and of course front view gets recorded simultaneously while HD DVR has no effect no video link in case the DVR decide to die or change screen because of bad card or voltage
fmkit is online now Find More Posts by fmkit
Old Jun 07, 2012, 02:13 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Originally Posted by fmkit View Post
this car dvr looks even better than Horyzon HD
it can record digital CMOS and AV-in simultaneously thus can be used onboard and as ground recorder.
I just lost auction, will bid another one - don't outbid me!
Are you sure that external lens connector is AV-in?
hefest is offline Find More Posts by hefest
Old Jun 07, 2012, 02:37 AM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Item description say so also pictured 3 pin coax connector (3.5mm? power, ground composite video), no way 3wire thin cable 5-10ft long can carry 720p digital video
Old Jun 07, 2012, 02:41 AM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
I sure would love a how-to tutorial on this conversion. Next time you do it, shoot a YouTube video. That would be great!
Old Jun 07, 2012, 02:42 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Maybe this one too
http://www.ebay.com/itm/5-Car-GPS-Na...17dc0d&vxp=mtr
Old Jun 07, 2012, 02:47 AM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
the navigator you linked doesn't record AV-in, only to view rear camera
I own similar device - useless
Old Jun 10, 2012, 09:41 AM
tete is offline
Find More Posts by tete
Joined Sep 2008
This unit has 2 cams and AVout
http://www.ebay.com/itm/2-8-Separate...item256fcd60cf
tete is offline Find More Posts by tete
Old Jun 10, 2012, 10:03 AM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Originally Posted by tete View Post
$96.69 for 720p way overpriced
yesterday I won similar dual cam DVR $23 free shipping
Old Jun 10, 2012, 10:34 AM
tete is offline
Joined Sep 2008
yeah good deal but cannot see AVout in picture or specs
Old Jun 10, 2012, 11:16 AM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
just split av_in, better than av-out with its added latency and OSD garbage
CCD output split into av_in and other wire to vid.TX, if you can remove 42-75Ohm resistor inside transmitter'sav_in then you don't need video buffer, video TX will transmit your OSD, not DVR's.
Old Jun 10, 2012, 11:31 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Can you report back with the info about that DVR?
Old Jun 10, 2012, 11:48 AM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
sure
Old Jun 10, 2012, 02:35 PM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
That's an interesting price, $23 with free shipping!
First picture below specs clearly shows "AV IN" port. Too bad it hasn't av out.
It says "Microphone Support" and "Build-in stereo Support". Could it be that the AV connector uses one pin for common power and audio?
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Jun 10, 2012, 02:53 PM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
I'd love to see some photos of the split and resistor. I video tutorial would be fantastic.
I know it's time consuming and a lot to ask, but it would be great.
Discussion Which portable video recording device? al_b FPV Talk 6 Feb 28, 2007 11:03 PM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 03:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 10:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 07:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 03:29 AM
