Old May 28, 2012, 11:02 AM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
Anybody up for summarising this device list in a new thread. I am in the market to buy a dvr now. So search function is not going to help. And way too many pages now to read through
GTiDonavan is offline Find More Posts by GTiDonavan
Old May 28, 2012, 12:14 PM
Joined Jan 2012
Originally Posted by ov3rmind View Post
I ended up ordering an even cheaper one for 19 buck shipped (with prime) from amazon.
http://www.amazon.com/gp/aw/d/B0024U...=5336653529-20
Good resolution, simple operation, no LCD though, but if doing FPV, use goggles or display to review
Hi what is the resolution for this device
Old May 28, 2012, 08:34 PM
igorek82 is offline
Find More Posts by igorek82
United States, NY, New York
Joined Apr 2011
Summarize ? Buy cheap = buy twice FPV-Japan DVR looks good...
igorek82 is offline Find More Posts by igorek82
Old May 28, 2012, 10:51 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yep, that's about it.
One thing I'll add. There's generally a noticeable difference between really cheap DVRs which people
use just to record OSD text and last position, and more expensive DVRs which are suitable for recording
videos that you might post on YouTube/Vimeo. When someone says "This really cheap DVR works
fine for me." it helps to pay attention to which category of usage they fall in.
There really haven't been more than a couple good DVRs added since the first post in this thread
stopped being updated.
ian
Daemon is online now Find More Posts by Daemon
Old May 29, 2012, 01:04 AM
paulinfrance is online now
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
640
http://vhsvideotodvd.blogspot.fr/201...tal-video.html
paulinfrance is online now Find More Posts by paulinfrance
Old May 30, 2012, 05:30 PM
TheSelf is offline
Find More Posts by TheSelf
Los Angeles, CA
Joined Jan 2011
Originally Posted by ommadawn View Post
I gave up using HDD after I discovered the quality of DVD. I now use a Sony portable DVD burner, and am hoping to convert the rest of the tribe to this format.
http://www.geeks.com/details.asp?inv...6-FB-R&cpc=SCH
Also my Baru (Br3002, or 3003, not sure..) had an annoying habit of slipping slightly out of synch occasionally, and putting the bottom 10mm of screen at the top. Never found a cause for it. Its now collecting dust with all my other recorders that didnt make the grade.
Let me know if formatting works for you,'
Cheers
Frank
Hi Ommadawn - or anyone who has the Sony Portable DVD Recorder VRD-MC6- I don't suppose anyone can tell me what the dimensions of the barrel connector to power the device is please?- I got one of these models used on ebay which didn't come with a power cord at all- and the barrel connector socket isn't a standard 2.5mm jack- picture attached- if anyone has the ability to measure the barrel connector outside and inside diameters and the pin diameter I would greatly appreciate it so I can find a correct sized barrel connector/cable to power this off of a 3S lipo- until I do that I cannot power the device up at all to test it..thanks in advance for any feedback
TheSelf is offline Find More Posts by TheSelf
Old May 30, 2012, 06:03 PM
sverlander is offline
Find More Posts by sverlander
Sam in Virginia
sverlander's Avatar
Hampton Virginia
Joined Jul 2005
Here is all the info on what I used.
http://www.rcgroups.com/forums/showp...&postcount=140
Coax power plug with 1mm diameter center pin. Common replacements for laptop computer power supplies. 5mm o.d. x 3.4mm i.d.
Here's the link to the one I used
AllElectronics.com
http://www.allelectronics.com/make-a...3.4-X-1/1.html
CO-AX POWER PLUG W/ CENTER PIN 5 X 3.4 X 1
sverlander is offline Find More Posts by sverlander
Old May 30, 2012, 06:23 PM
TheSelf is offline
Los Angeles, CA
Joined Jan 2011
AllElectronics.com
Thanks so much Sverlander! So just to confirm- you used that specific connector and it fitted Ok and powered your VRD-MC6 OK with a 3S lipo? (I ask as since posting with a little research I believe the dimensions of the original power connector might be 5.5mm outside diamter, 3.3mm inside diameter and 0.9mm pin- the dimensions of the one you mentioned seem pretty close- so long as it fits, all is good I guess..how do you add black and red cable to a bare barrel connector like that? thanks again!
Old May 30, 2012, 06:38 PM
Sam in Virginia
sverlander's Avatar
Hampton Virginia
Joined Jul 2005
Yes that's the one I use and I have had no problems with it. The outer housing screws on the plug so unscrew it, solder some wire on the lugs and screw the outer housing back on. Back when I found this plug it was all I could find but you might be able to find one factory made with the wires. If you have the AC power adaptor you could cut the wire and add a dean connector and use the same plug for battery or AC operation.
Old May 30, 2012, 07:02 PM
TheSelf is offline
Los Angeles, CA
Joined Jan 2011
thanks Sverlander- I'm in Los Angeles- so that store is local to me- think I'll go down and save on shipping- thanks again buddy!
Old May 31, 2012, 01:22 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
I also use this recorder, and really like it.
- Kim -
SpookiePower is offline Find More Posts by SpookiePower
Old Jun 03, 2012, 08:57 PM
7AC is offline
7AC
Find More Posts by 7AC
7AC
7AC's Avatar
Central Indiana
Joined Oct 2006
AmCap
Anyone using "AmCap" have a problem with a black screen when "Start Capture" is selected. I have a great picture with it until I hit "Start Capture" then the screen goes black. I do get a recorded file, I just can't see the video while the file is being recorded
7AC is offline Find More Posts by 7AC
Old Jun 03, 2012, 09:32 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Radio Shack or The Source also have it.
Martin Y is offline Find More Posts by Martin Y
Old Jun 06, 2012, 07:39 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
I'm in a hunt for recorder, again, since my Aiptek MPVR croaked.
Since I also need a backup screen 2-in-1 like jdx 990 would be nice, but at least it should support around and over 3000 kb/s bit rate.
This foxtech mini d1 looks like it could do the job if I go for separate dvr and TV/Monitor solution. Raw sample video shows over 3500 kb/s and 30fps.
Is it any good? Any detailed reviews so far?
hefest is offline Find More Posts by hefest
Old Jun 06, 2012, 02:18 PM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
this car dvr looks even better than Horyzon HD
it can record digital CMOS and AV-in simultaneously thus can be used onboard and as ground recorder.
I just lost auction, will bid another one - don't outbid me!
fmkit is online now Find More Posts by fmkit
Discussion Which portable video recording device? al_b FPV Talk 6 Feb 28, 2007 11:03 PM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 03:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 10:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 07:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 03:29 AM
