Old May 22, 2012, 06:00 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Im also looking at the foxtech D1 DVR http://www.foxtechfpv.com/mini-d1-qu...der-p-451.html
Only possible problem I can see, is PAL video is 720x576 res, whereas the D1 records 705x576. Anyone run into problems with this? Does it crop PAL video?
Cheers, Sam
sammyc is offline Find More Posts by sammyc
Old May 23, 2012, 01:00 AM
paulinfrance is offline
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
Hi, sammyc,
if you look up 2 posts you will see that your first DVR is the same as mine but at
sunsky it's only $54, i still haven't had any answers, maybe they are all asleep,,,,,,,,,,,,,,
Your last post with the foxtec i have seen good reports on it but with it installed in the plane.
paulinfrance is offline Find More Posts by paulinfrance
Old May 23, 2012, 01:15 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Originally Posted by paulinfrance View Post
Hi, sammyc,
I don't see why you would install on plane, if I wanted to record on board, a $40 HD keychain is the go to.
I have read some pretty good reports on the foxtech D1 recorder, but no one can really answer me about PAL video being shrunken or cropped?
Old May 23, 2012, 05:52 AM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Hi
I have JAPAN DVR. I want to use it with external power at field. Does anyone use it as I want?
Firatp is offline Find More Posts by Firatp
Old May 23, 2012, 06:39 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Im still finding more DVR possibilities
How about this jetview one?
Seems to get a pretty good wrap:
http://www.jetviewcctv.com/product_i...roducts_id=415
Old May 23, 2012, 06:41 AM
igorek82 is offline
Find More Posts by igorek82
United States, NY, New York
Joined Apr 2011
Sammyc, all(most) of these dvrs were mentioned and reviewed earlier in the thread...
igorek82 is offline Find More Posts by igorek82
Old May 23, 2012, 06:49 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Yea, but im after current opinions, now there are (or at least could be) new products and new pricing, so this changes the opinions and value. Im after the current opinions
Old May 23, 2012, 09:48 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Firatp View Post
Hi
That's easy...just connect it to any 5v input. I used an old brushless motor ESC (just using the BEC part) to step down the 12v ground station battery to 5v for the SD-4 recorder...works fine. Actually I mostly use the internal battery, but have the plug available for external power should I start running the battery down.
Vantasstic is offline Find More Posts by Vantasstic
Old May 24, 2012, 03:34 AM
Firatp is offline
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Thanks Van,
Is the current important? My BEC gives 5V 5amp. I hesitate that over amper will damage can batteries or dvr itself.
Cheers
Old May 24, 2012, 12:55 PM
Martin7182 is online now
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
I'm not Van but the current is a max. value. A stronger BEC will not damage a device that needs less. A weaker BEC than needed could cause a voltage drop or worse, a damaged BEC. But I think the recorder doesn't need more than a few hundreds mA, so any 5V BEC should be ok.
Martin
Martin7182 is online now Find More Posts by Martin7182
Old May 24, 2012, 03:34 PM
Firatp is offline
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Martin
Thanks Martin
Then I can use my DVR without batteries.
Cheers
Old May 24, 2012, 04:59 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thanks Martin
Cheers
No, your good. Like Martin said...the BEC amp value is what it can support UP TO. Kinda like the speed rating of your car. It can do 'up to' 150mph on the speedometer, but you only need it to drive at 50mph...no issues...
Old May 27, 2012, 02:06 PM
brodjack is offline
Find More Posts by brodjack
usual old know-it-all
Blackpool,U.K.
Joined May 2005
The Foxtech DVR is really good.
heres a sample of my video,recorded groundstaiton DVR using 200mw 5.8 gear, just hovering and testing Naza FC settings on my homemade frame quad.
it was very windy..
watch in 720p
http://youtu.be/jskyLrLOFts
brodjack is offline Find More Posts by brodjack
Old May 28, 2012, 08:12 AM
Joined Aug 2011
A helpful reply, igorek only another 146 pages to read,,,,
as said, maybe since the reply on this thread, there are other products that are as good or better as at more competitive prices, a simple reply would have done,,,,,,,,,,,
Old May 28, 2012, 08:19 AM
igorek82 is offline
Joined Apr 2011
All I meant to say was that a search button would have answered a particular question in 30 seconds or less... Also, searching YouTube with the name of the DVR usually produces a lot of videos recorded with that particular device...
Discussion Which portable video recording device? al_b FPV Talk 6 Feb 28, 2007 11:03 PM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 03:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 10:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 07:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 03:29 AM
