Old Apr 02, 2012, 01:19 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by wannabe View Post
Do these Aiptek camcorders have video input? I only see output...
Many of them do. Varies by model.
ian
Daemon is online now Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Apr 02, 2012, 01:49 PM
Wrestling a pregnant albatross
wannabe's Avatar
Joined Oct 2003
Ian, what is your favorite way to record on the ground? What type of hardware are you using?
wannabe is offline Find More Posts by wannabe
Old Apr 02, 2012, 02:27 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Lawmate PV-1000
Old Apr 03, 2012, 05:49 AM
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Hi,
How do these two compare:
http://www.ebay.com.au/itm/MINI-High...#ht_5444wt_905
and
foxtech mini D1 recorder http://www.foxtechfpv.com/mini-d1-qu...der-p-451.html
The foxtech recorder is listed to record 704x576 video, so if I input PAL from rx (720x576), will it cut off edges of video? And lose some osd info?
Do they both record full static?
Considering prices are very similar, what is my best option?
Oh, and what class SD card is required for best quality?
Thanks in advance,
Sam
sammyc is offline Find More Posts by sammyc
Old Apr 03, 2012, 05:38 PM
That's falling with style!
RowdyRod's Avatar
Joined Apr 2008
Originally Posted by Adekamer View Post
Not sure if anyone else has posted a review on this one, but I just received one this week from an eBay purchase. It’s the Angel Eye Mini DVR KS-660M. I can report that….
Pros:
  • It records through static
  • It can do real time output to monitor or goggles and eliminates the blue or black screen of death (for my test devices anyway)
  • Time & Date stamp can be removed from the recording.
Cons:
  • Onscreen display such as battery condition icon, recording icon and date & time cannot be removed from the display, these things take up valuable space on the screen that I would like to use for my aircraft telemetry.
  • Cannot display on the built in LCD screen and output video at the same time.
I’ve only done some basic tests and have not tested recording quality or frame rates yet.
If anyone knows how to update the firmware on these things please let me know, If I can remove the on-screen display it will be perfect for my needs.
Test videos will be uploaded after Easter.
RowdyRod is offline Find More Posts by RowdyRod
Old Apr 04, 2012, 02:26 AM
Joined Dec 2010
RowdyRod, can you check if yours has a 30min record limit?
Also very interested in seeing recorded footage. Fwiw I think Alex (IBCrazy) uses these or a similar version...
mich75 is offline Find More Posts by mich75
Old Apr 04, 2012, 02:55 AM
merlin64's Avatar
The Netherlands, NB
Joined Dec 2007
+1 for me
merlin64 is offline Find More Posts by merlin64
Old Apr 04, 2012, 04:16 AM
ffranck's Avatar
Oslo, Norway
Joined Jan 2011
Hello!
Thanks for this thread, here is a small comparison I made of my two recorders (The Foxtech SD V1.3 and the DVR-DV01 "5.8GHz pocket ground station").
FPV Ground Station Recorders Testing with a RC Car (1 min 2 sec)
I posted more details about the test here: http://www.rcgroups.com/forums/showp...5&postcount=57
BTW, I did not found the any thread about the "5.8GHz pocket ground station", is there one?
Cheers!
Franck
ffranck is offline Find More Posts by ffranck
Old Apr 04, 2012, 04:33 AM
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
as for onboard recording car dvr has too many advantages compared to composite DVR:
Cost 3 times less + you get wide angle camera
small cameras easy to pan tilt
way more detailed video
tiny TF card never jumps out if plane bad landed - no corrupted recordings
there is always option to set motion detect -very useful !
no worries about card full - old files get overwritten
cam/dvr easily powered via servo pins, no step-up needed for camera
automatic start recording
weight with camera 30-40g.
http://www.youtube.com/watch?v=rchk8JjusGg
fmkit is offline Find More Posts by fmkit
Old Apr 04, 2012, 04:50 PM
United States, NJ, Millburn
Joined Sep 2011
Originally Posted by paulinfrance View Post
well my mouse got the best of me last night, it ran to 'Buy now' so i ended up buying this;
http://www.newmp3technology.com/av25.htm
I'm curious how this purchase turned out. Any feedback? 39 buck dvr with lcd is kinda amazing.
ov3rmind is online now Find More Posts by ov3rmind
Old Apr 04, 2012, 04:57 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Not much specs on that....recording quality, records through static, etc. Let us know how it works out when you get it.
Vantasstic is offline Find More Posts by Vantasstic
Old Apr 04, 2012, 05:31 PM
sammyc's Avatar
Joined Nov 2011
Wow, great price, have you received it yet? Could you give us a run down on how good it is please?
Old Apr 04, 2012, 05:47 PM
sammyc's Avatar
Joined Nov 2011
Found a review and some more info:
http://www.fpvuk.org/forum/index.php?topic=2138.0
Records 320x240 at 25FPS, would be ok as a basic recorder to see where plane went down, but I wouldn't like to use it as a proper flight recorder with intents on using and uploading the video. Don't think they mentioned anything about static.
Old Apr 04, 2012, 07:49 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Wow, that is pretty low resolution. As you mentioned...good for helping to find a downed plane, but not much good for actual video/posting. Of course, so many are using on-board HD cameras for video anyway.
Old Apr 04, 2012, 08:12 PM
Joined Sep 2011
Correct. On board hero2 takes care of the quality thing pretty well. Useless if you can't find it though in a pinch.
Just saw this too: http://www.newmp3technology.com/av28g.htm lol. same functions and price as first one, but includes NES games in case you destroy your copter and have time to kill.
Discussion Which portable video recording device? al_b Video Piloting (FPV/RPV) 6 Feb 28, 2007 11:03 PM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 03:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 10:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 07:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 03:29 AM
