Old Jan 31, 2012, 10:58 AM
pr0ject42 is offline
Find More Posts by pr0ject42
CEL abuser
USA, CO, Denver
Joined Dec 2010
Has anyone checked this one out? Looks like an Aiptek MPVR knockoff:
http://www.walmart.com/ip/Coby-CAM4002/15846627
pr0ject42 is offline Find More Posts by pr0ject42
Old Jan 31, 2012, 11:33 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
No evidence that it has an A/V input jack. In other words, it's not a PVR (like the MPVR series).
ian
Daemon is online now Find More Posts by Daemon
Old Jan 31, 2012, 11:42 AM
CEL abuser
USA, CO, Denver
Joined Dec 2010
ian
It does say
Additional Features:
Interfaces: USB 2.0, 3.5mm composite video
Of course that could mean output..
Old Jan 31, 2012, 01:04 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I'm about 99% sure that's output only.
One of the inevitable progressions of cheap consumer electronic products is that
they actually contain less and less "frills" as they mature. Features that people don't
use very often, get removed from future versions and imitations of the product.
ian
Old Jan 31, 2012, 05:43 PM
traderdmb is offline
Find More Posts by traderdmb
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
Originally Posted by Thint1 View Post
hi,
do you mean the codec of the FPV Japan recorder?
i use also this recorder, so i´m very interested about your issues and workaround.
cheers Thomas
I had to use Virtualdub to convert the audio to mp3 before I could load files into Sony Vegas HD Platinum. However, once I upgraded to Vegas 11 PRO those problems went away. Hope this helps.
traderdmb is offline Find More Posts by traderdmb
Old Feb 07, 2012, 05:19 PM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Fried my Piano Recorder today. i knew I should have bought 2. So what is the best quality recorder available now? I prefer a hard drive based recorder.
techspy is offline Find More Posts by techspy
Old Feb 08, 2012, 06:58 PM
isilive is offline
Find More Posts by isilive
Austria, Tir., Schwaz
Joined Feb 2012
I have bought a SanDisk V-Mate and tried for the first time today.
Cabling is easy. Configuration also. So i use the remote to start recording and it works instantly. Picture quality is ok. Not perfect, not bad, but good enough for my first recorder. And very good for the price.
I switched off the tx to test static. Picture goes black, but after 2 minutes of static it still records. I hope this is longer than the static i will ever get in air =P Switching on tx again and recording is fine.
+ price (i paid just about 35 euro)
+ case and design. lightweight and small.
+ it records to sd-card. format: mp4 video 640x480. you can choose pal or ntsc.
+ doesnt stop recording when picture is static
+ with the new firmware you get video-output now in highest resolution (640x480) also.
+ power supply and cinch (rca) cables included.
o picture quality is ok. it's good enough to start with.
o there came "one button recording" with the new firmware. but you need the remote control. i'd prefer if there was a button, so you would not have to worry about'cher'motecontrolbatterey.
o its 5v so u need a bec (you can build a simple bec for <5 euro).
o there is appr. 0,2 sec of lag on video output. for fast flights i would connect via video-splitter or directly.
after all: i like it
wishlist: 12v, one touch record button on the cabinet, better video quality (but again, its not bad)
isilive is offline Find More Posts by isilive
Old Feb 09, 2012, 02:12 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
When SanDisk V-Mate is recording you see the dates on the screen ? Is it possible to hide the dates during recording and also in viewing ?
IMEIV is offline Find More Posts by IMEIV
Old Feb 09, 2012, 09:00 AM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Anyone know the cheapest place to get a lawmate pv-1000?
Old Feb 09, 2012, 10:06 AM
jon davies is offline
Find More Posts by jon davies
S. Wales
Joined Jun 2008
I had a V-Mate but it's some time since I've used it. I found some old V-Mate recordings and there was no date stamp on my videos so it is possible to remove it.
Have a look at the manual
http://www.sandisk.com/Assets/File/p...0UG_Eng_T1.pdf
I do remember it was a bit clumsy to use and the version I had didn't out put video during recording but, it worked, no blue screening.
Good luck
jon davies is offline Find More Posts by jon davies
Old Feb 09, 2012, 10:23 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Good luck
Hi Jon. Your link does not allow to download instruction but I found them in SanDisk site and nothing is said about date stamp on the video. So if you tell that there isn't any date stamp on the video I'm very happy. Thanks..
Old Feb 09, 2012, 10:46 AM
S. Wales
Joined Jun 2008
Sorry Imeiv.
Can't get the link to work but if you've found the manual I won't investigate further.
Hope you're happy with the V-Mate.
Jon
Old Feb 10, 2012, 10:10 AM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
I can not believe the lack of suitable devices for this application. What really gets me is that there used to be several (like the Piano recorder I had) that are not made anymore! The Japan recorder seems nice but there is an issue with availability. I did find this one, http://www.supercircuits.com/Digital...el-DVRs/MDVR80 although expensive, seems to be very nice. This one is without an internal hard drive but you can add one (voids warranty however). or you can spend another $230 for them to install an "AV grade mobile 250 gig hard drive" (that costs $80 on the retail market). I do like the 1 button record and the fact that it can record 720 x 480 @30fps. The model number interestingly enough is the same as the now unavailable MDVR80 listed at the beginning of this thread.
I really can't believe that one of the companies making all these custom FPV products haven't come out with a specific recorder with the specs we want!
Anyway, I will probably get the lawmate pv-1000 unless the japan DVR gets back in stock this century.
Old Feb 10, 2012, 01:18 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
No telling if the MDVR80 can record through static. And once you add the harddrive (at
their price) you're at the price of the much more capable PV-1000 (there's a listing on
Google Shopping that claims $468, but have to call that vendor to verify price).
I don't recall that the Piano recorder was all that, either. Some people had problems with
it stopping recording randomly and not always recording through static.
There are other HDD based recorders out there but many of them crop the image quite a bit.
ian
Old Feb 10, 2012, 04:23 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
I loved my piano recorder. Never had an issue with it stopping recording and the quality was great. I don't ever remember it dropping out from static either.
Oh, and I went to the website that shows the PV-1000 for that price...
1. They don't list the price on the web page. You have to enter your email address for a "discount code that is good for only one day"
2. When you enter the "code" which is the same code no matter what email or day you request it, you get a price that is $20 more than the price listed on google that takes you to their site.
3. When I inquired about the fact they have no price listed, and that the price with the "discount code" more than the advertised price, he said "yeah, we had a price increase yesterday"
4. When I explained that all these circumstances sounded too shady and asked for an explanation, he resorted to ghetto talk " You are busting my chops over 20 bucks homie?".
So I figured I would spend the extra $100 and get it somewhere reputable.
Discussion Which portable video recording device? al_b FPV Talk 6 Feb 28, 2007 11:03 PM
Discussion Recycle any battery or portable electronic device. willhaney Batteries and Chargers 3 Dec 21, 2006 03:27 PM
Onboard Recording / Telemetry Device - Suggestions? LoopZilla Micro Helis 27 Jun 01, 2005 10:23 PM
Throttle usage recording device CloudyBright DIY Electronics 3 Dec 16, 2004 07:51 PM
Interesting Portable Photo Storage Device Randy Due Aerial Photography 12 Apr 11, 2004 03:29 AM
