Old Nov 21, 2009, 07:05 AM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
How to make a DC Clamp amp meter ?
How to make a DC Clamp meter ?
Guys, do you have any idea how to make a DC Clamp meter ? most Clamp meter is can only measure AC.
or do you have any suggestion to convert an Ordinary AC Clamp Amp meter to allow measurement of DC current.
I need to measure a DC Current up to 500 Amps for my electric Forklift project.
lazy-b is offline Find More Posts by lazy-b
Old Nov 21, 2009, 07:45 AM
43851E is offline
Find More Posts by 43851E
43851E's Avatar
College Station, TX
Joined Jul 2009
Fluke Instruments of Fremont Ca. did it first. They inject a DC pulse into one side of the clamp & then detect it on the other side. There is a polairty (direction) the clamp has to be oriented with respect to the current flow. How to make one? Very hard without a scope and allot of circutry. I would wire in a full time shunt (.01 ohm) 200 Amp and leave it there. It would act like an extra 20 feet or so of wire that you could measure the voltage drop across, and thus current flowing. Or from what I've seen recently....pawn shops have been carrying a cheaper Fluke model that will measure DC Current. Look for the clamp on meters (Fluke) that have the words "in & out" molded on each side of the clamp. You could always test it on your car battery when you're there.
Sorry, in my mind, it would be kinda hard to DIY, but have faith. Lets see what the others think. Good catch on the "in line DC Current" sensing topic!
Best, Doug
43851E is offline Find More Posts by 43851E
Old Nov 21, 2009, 07:53 AM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Would be extremely difficult to build one and get it calibrated. Best to just buy one. http://ph.farnell.com/jsp/search/bro...26catalogId%3D
jeffs555 is offline Find More Posts by jeffs555
Old Nov 21, 2009, 09:58 AM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Ellion
Why not parallell 3 ACS 758/200 Amps sensors ( see Allegro Application notes, they show How ...)
http://www.allegromicro.com/en/Produ...0758/index.asp
Friendly Thoughts
Alain
Acetronics is offline Find More Posts by Acetronics
Old Nov 21, 2009, 10:20 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
You might be able to DIY one.
Go to http://www.major-tech.com/products/m...=Clamp+Meters# and click on "Measurement Principle of AC/DC Clamp Meter"
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 21, 2009, 12:14 PM
Hell-e-Guy is offline
Find More Posts by Hell-e-Guy
Joined Jan 2006
You can try using a low permeability material core such as a ferrite core to catch the magnetic field lines produced by the DC current and pass them through a hall sensor.
This will require a slit in the ring that is difficult to make, so 2 half circular cores may be the answer.
Hell-e-Guy
Hell-e-Guy is offline Find More Posts by Hell-e-Guy
Old Nov 21, 2009, 03:19 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The LEM serie of current transducers does just that(Hall effect sensor) for DC or AC. Very easy to use but requires +/- 15V supply:
http://www.datasheetcatalog.com/data...HAL100-S.shtml
Available from 50<600 amps. Just download the pdf for application
coriolan is online now Find More Posts by coriolan
Old Nov 21, 2009, 03:55 PM
pmackenzie's Avatar
Joined Dec 2002
Neat part. Less than $20 at Mouser for similar ones that only need +5 volts to operate:
http://www.mouser.com/Sensors/Curren...rd=hal&FS=True
- But no stock
A bit more than $20 at Digikey , and in stock
http://search.digikey.com/scripts/Dk...name=MT7180-ND
Pat MacKenzie
Old Nov 23, 2009, 04:46 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Silicon Chip Sept 2003: Current Clamp Meter Adaptor for DMMs
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Nov 23, 2009, 07:43 AM
lazy-b is offline
Manila, Philippines
Joined Jul 2004
Guys, thanks to all your suggestion......look like Bruce Abotts's cirucits is simple to make..........look like if we can find a smaller Core, I guess it can be use for our Electric Plane/Helicopter.
Alain, Thats a very nice current sensor perfect for my next project........Data Logger for electric Helicopter.
Ellion
Old Nov 23, 2009, 10:55 AM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
That article Bruce linked is probably the same design as this kit. http://www.altronics.com.au/index.as...=item&id=K2582
Kit is cheap enough, but I imagine shipping would be high.
How do I use my Craftsman clamp meter #82014? papasmurf Power Systems 9 Feb 15, 2010 01:13 AM
Alert Sears/Craftsman #82062 AC/DC Clamp Meter PGR Electric Plane Talk 0 Jul 30, 2006 06:05 PM
Sears AC/DC Clamp Meter DKB Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2004 10:46 PM
how to make a amp meter to tell how much my motor is drawing? jeff262 Power Systems 7 Nov 07, 2003 10:28 AM
DC amp clamp with 10 milliamp resolution Dannyabc Power Systems 0 Aug 24, 2002 03:22 AM
