Old Nov 19, 2009, 08:14 PM
aeo-tiffany is offline
Find More Posts by aeo-tiffany
Hubei Province
Joined Sep 2009
Cool
Dr.Servo---Servo Speed Expert
As the first multi-functional servo speed tester,S1 not only accurately tests the speed,but also tests the consistency of the servo,which are really widely espected by model lovers.
Specifications:
Operating temperature: -10 ℃ to 50 ℃
Weight: 21grams
Size 33x 69x 11mm
Input voltage: 8V-12V (2S lipo battery or 9V 2A DC power supply)
Output voltage: 5V
Output current: 1A
Features:
◎ The first multifunctional accurate tester to measure servo speed.
◎ Integrated with high performance gyro sensor and processor, gives a overall measuring for servo synthesis performance.
◎ Transducer Isolation design, works perfect with any kinds servos.
◎ Ultra small and portable.
◎ With BEC built in, it can work with lipo battery, you don’t need to connect it with extra receiver battery.
Especially for helicopter model players,S1 is a must choice,because it can make you really choose slope servo with same speed.
aeo-tiffany is offline Find More Posts by aeo-tiffany
Old Nov 19, 2009, 08:46 PM
tukkus is offline
Find More Posts by tukkus
massachusetts
Joined Mar 2005
What good are the results if the servos aren't tested under a load?
tukkus is offline Find More Posts by tukkus
Old Nov 19, 2009, 09:09 PM
dirtybird is online now
Find More Posts by dirtybird
United States, AZ, Queen Creek
Joined Aug 2004
The manufacturer specs. are no load. You could load the servo yourself and check how it would affect the response time. You might find some surprising info.
dirtybird is online now Find More Posts by dirtybird
Old Nov 20, 2009, 02:14 AM
Hubei Province
Joined Sep 2009
Dr.Servo S1 can really let you know the real running speed of the servo,not only the speed that manufacturer boasts.
Besides,our S1 also could test with full load,because our sensor uses segregation design.
Tiffany
Old Nov 20, 2009, 11:16 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Tiffany
Could you attach a User Manual type document or file, could be zipped ?
Is it also a "standard" servo tester with ppm signal generator + potentiometer ?
Louis
Fourdan is offline Find More Posts by Fourdan
Old Nov 22, 2009, 09:43 PM
Hubei Province
Joined Sep 2009
Originally Posted by Fourdan View Post
Hi Tiffany
Louis
PLS SEE THE ATTACHMENT.
Tiffany
Old Nov 23, 2009, 12:07 AM
Hubei Province
Joined Sep 2009
Hi Tiffany
Louis
This is new and noval,with high-performance gyro seneor integrated,so it can accuratelly test the running speed and others that couldn't been really tested before.
Old Nov 23, 2009, 06:10 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Tiffany
Hi Tiffany
I have downloaded and read the doc
I would have a preference for a device with USB link and PC software
(just an interface between PC software - USB and a servo + gyro + possible extra optical/magnetic sensors)
Just my opinion
Louis
Old Nov 23, 2009, 07:48 PM
Hubei Province
Joined Sep 2009
Hi Tiffany
Just my opinion
Louis
Hi,Louis
Thank you so much for your suggestion.
This device has original features and functions.But we will consider your suggestion in the next upgrading.
TKS!
Discussion expert servo arms EZ63 Radios 4 Aug 14, 2015 06:54 AM
For Sale new price "Expert" rx,battery & servo's lla Aircraft - General - Radio Equipment (FS/W) 4 Dec 15, 2009 02:47 PM
Wanted EXPERT SL260 Servo kenair Aircraft - General - Radio Equipment (FS/W) 0 Nov 01, 2009 11:00 AM
Help! Expert Servo S-91BB Clavin01 Flight Accessories 0 Sep 22, 2009 03:06 PM
Sold JR 8700G - Hi Speed Tail Rotor Servo heychas Aircraft - General - Radio Equipment (FS/W) 0 Sep 07, 2009 01:41 PM
